Installation on PC startup
Verfasst: 20 Jun 2015, 13:54
von denmarknian
I noticed that only "On demand" (execute now) is working for me. If I have a pending installation , when I restart the PC it didn't install automatically. How can I enable it? Thank you.
Re: Installation on PC startup
Verfasst: 22 Jun 2015, 10:20
von ueluekmen
Have you deactivated the gui_startup Event?
Verfasst: 23 Jun 2015, 14:34
von denmarknian
Yes, I'll try it. I read it from the manual also. I'm not sure if the configuration is available from the Configed instead of updating the opsicondf.conf at the client side.
