Installation on PC startup
denmarknian
Beitrag von denmarknian »
I noticed that only "On demand" (execute now) is working for me. If I have a pending installation , when I restart the PC it didn't install automatically. How can I enable it? Thank you.
ueluekmen
Re: Installation on PC startup
Beitrag von ueluekmen »
Have you deactivated the gui_startup Event?
denmarknian
Yes, I'll try it. I read it from the manual also. I'm not sure if the configuration is available from the Configed instead of updating the opsicondf.conf at the client side.
