How do i activate hwaudit and swaudit
htaute
Beitrag von htaute »
I have installed Opsi v3.3 on a VM server and ran service_setup.cmd on my pc. In the Opsi Config editor i see that my pc was added as a client. How do i activate hwaudit/hwinvent and swaudit as i cannot seem to gather it out of the installation manual?
Re: How do i activate hwaudit and swaudit
see chapter
3.2.6. Product configuration
for hwaudit/swaudit
and
3.2.7. Netboot products
for hwinvent
in the opsi-manual-v33-en.pdf
regards,
htaute
In the Product Configuration the installation_state is not_installed. Must i change it to another state and must i change the action_request as well?
wardenik
Beitrag von wardenik »
No, just change the action to setup.
You have to set an action request.
The instllation status is always the result of an action performed.
htaute
I have done as suggested ie changing the "action request" for hwaudit, swaudit and python to setup but still no joy. If i change the :installation state" to installed it actualy gives me the version and package. They say Python is a prerequirement for hwaudit and swaudit.
htaute hat geschrieben:They say Python is a prerequirement for hwaudit and swaudit.
It is.
j.schneider hat geschrieben:You have to set an action request.
and save inconfiged.
Restart your opsi-Client and pheck/post c:\tmp\logoblog.txt and c:\tmp\instlog.txt
regards
htaute
Thank you all for your patience and assistance. Bardo, I looked at the logonlog.txt and saw that there was no WINS entry for the server so it could not connect to the share to do the setups required. After creating a WINS entry everything ran well. Thanks again.
Regards
Henri Taute
