Re: microsoft visual c++ runtime 2008
Verfasst: 14 Nov 2018, 18:41
It seems to work allright.n.wenselowski hat geschrieben:Any news on this regard?
[7] [nov 14 18:16:26:932] [opsi-client-agent] (string 12)prodInfoText=PRODUCT_PROFESSIONAL_N
[6] [nov 14 18:16:26:932] [opsi-client-agent] Set $INST_ProductType$ = getValue("product_type_nr",$INST_Resultlist$)
[8] [nov 14 18:16:26:933] [opsi-client-agent] retrieving strings from $INST_Resultlist$
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 0)major_version=6
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 1)minor_version=1
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 2)build_number=7601
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 3)platform_id=2
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 4)csd_version=Service Pack 1
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 5)service_pack_major=1
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 6)service_pack_minor=0
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 7)suite_mask=256
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 8)product_type_nr=1
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 9)2003r2=false
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 10)ReleaseID=
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 11)prodInfoNumber=49
[8] [nov 14 18:16:26:933] [opsi-client-agent] (string 12)prodInfoText=PRODUCT_PROFESSIONAL_N
[6] [nov 14 18:16:26:934] [opsi-client-agent] The value of the variable "$INST_ProductType$" is now: "1"
[6] [nov 14 18:16:26:934] [opsi-client-agent] Set $INST_vcredistx86_installed$ = "false"
[6] [nov 14 18:16:26:934] [opsi-client-agent] The value of the variable "$INST_vcredistx86_installed$" is now: "false"
[6] [nov 14 18:16:26:934] [opsi-client-agent] If
[8] [nov 14 18:16:26:935] [opsi-client-agent] key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:935] [opsi-client-agent] Registry started readonly
[7] [nov 14 18:16:26:935] [opsi-client-agent] Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:935] [opsi-client-agent] Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9BE518E6-ECC6-35A9-88E4-87755C07200F}] opened
[6] [nov 14 18:16:26:935] [opsi-client-agent] Key closed
[6] [nov 14 18:16:26:936] [opsi-client-agent] GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9BE518E6-ECC6-35A9-88E4-87755C07200F}] DisplayVersion") = "9.0.30729.6161" <<< result true
[6] [nov 14 18:16:26:936] [opsi-client-agent] Then
[5] [nov 14 18:16:26:936] [opsi-client-agent] comment: vcredistx86 Version 9.0.30729.6161 is installed
[6] [nov 14 18:16:26:936] [opsi-client-agent] Set $INST_vcredistx86_installed$ = "true"
[6] [nov 14 18:16:26:937] [opsi-client-agent] The value of the variable "$INST_vcredistx86_installed$" is now: "true"
[6] [nov 14 18:16:26:937] [opsi-client-agent] EndIf
[6] [nov 14 18:16:26:937] [opsi-client-agent] If
[8] [nov 14 18:16:26:937] [opsi-client-agent] key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:937] [opsi-client-agent] Registry started readonly
[7] [nov 14 18:16:26:937] [opsi-client-agent] Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:938] [opsi-client-agent] Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}] could not be opened by RegOpenKeyEx, Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:938] [opsi-client-agent] GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}] DisplayVersion") = "9.0.30729.4148" <<< result false
[6] [nov 14 18:16:26:938] [opsi-client-agent] Then
[6] [nov 14 18:16:26:938] [opsi-client-agent] EndIf
[6] [nov 14 18:16:26:938] [opsi-client-agent] If
[8] [nov 14 18:16:26:939] [opsi-client-agent] key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:939] [opsi-client-agent] Registry started readonly
[7] [nov 14 18:16:26:939] [opsi-client-agent] Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:939] [opsi-client-agent] Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9A25302D-30C0-39D9-BD6F-21E6EC160475}] could not be opened by RegOpenKeyEx, Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:939] [opsi-client-agent] GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9A25302D-30C0-39D9-BD6F-21E6EC160475}] DisplayVersion") = "9.0.30729" <<< result false
[6] [nov 14 18:16:26:939] [opsi-client-agent] Then
[6] [nov 14 18:16:26:939] [opsi-client-agent] EndIf
[6] [nov 14 18:16:26:940] [opsi-client-agent] If
[8] [nov 14 18:16:26:940] [opsi-client-agent] key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:940] [opsi-client-agent] Registry started readonly
[7] [nov 14 18:16:26:940] [opsi-client-agent] Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:940] [opsi-client-agent] Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5DA8F6CD-C70E-39D8-8430-3D9808D6BD17}] could not be opened by RegOpenKeyEx, Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:941] [opsi-client-agent] GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5DA8F6CD-C70E-39D8-8430-3D9808D6BD17}] DisplayVersion") = "9.0.30411" <<< result false
[6] [nov 14 18:16:26:941] [opsi-client-agent] Then
[6] [nov 14 18:16:26:941] [opsi-client-agent] EndIf
[6] [nov 14 18:16:26:941] [opsi-client-agent] If
[8] [nov 14 18:16:26:942] [opsi-client-agent] key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:942] [opsi-client-agent] Registry started readonly
[7] [nov 14 18:16:26:942] [opsi-client-agent] Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:942] [opsi-client-agent] Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E503B4BF-F7BB-3D5F-8BC8-F694B1CFF942}] could not be opened by RegOpenKeyEx, Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:942] [opsi-client-agent] GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E503B4BF-F7BB-3D5F-8BC8-F694B1CFF942}] DisplayVersion") = "9.0.21022.218" <<< result false
[6] [nov 14 18:16:26:942] [opsi-client-agent] Then
[6] [nov 14 18:16:26:942] [opsi-client-agent] EndIf
[6] [nov 14 18:16:26:942] [opsi-client-agent] If
[8] [nov 14 18:16:26:943] [opsi-client-agent] key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:943] [opsi-client-agent] Registry started readonly
[7] [nov 14 18:16:26:943] [opsi-client-agent] Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:943] [opsi-client-agent] Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}] could not be opened by RegOpenKeyEx, Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:943] [opsi-client-agent] GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}] DisplayVersion") = "9.0.21022" <<< result false
[6] [nov 14 18:16:26:943] [opsi-client-agent] Then
[6] [nov 14 18:16:26:943] [opsi-client-agent] EndIf
[6] [nov 14 18:16:26:943] [opsi-client-agent] If
[6] [nov 14 18:16:26:945] [opsi-client-agent] CompareDotSeparatedNumbers($INST_NTVersion$,"4.0") <= "0" <<< result false
[6] [nov 14 18:16:26:945] [opsi-client-agent] Then
[6] [nov 14 18:16:26:945] [opsi-client-agent] EndIf
[6] [nov 14 18:16:26:945] [opsi-client-agent] If
[6] [nov 14 18:16:26:946] [opsi-client-agent] CompareDotSeparatedNumbers($INST_NTVersion$,"6.1") < "0" <<< result false
[6] [nov 14 18:16:26:946] [opsi-client-agent] Then
[6] [nov 14 18:16:26:946] [opsi-client-agent] EndIf
[6] [nov 14 18:16:26:946] [opsi-client-agent] Switch : 6.1
[6] [nov 14 18:16:26:947] [opsi-client-agent] Case : 6.1
[6] [nov 14 18:16:26:947] [opsi-client-agent] Case match: 6.1 = 6.1
[6] [nov 14 18:16:26:947] [opsi-client-agent] Set $OCD_DIST_DIR$ = "dist.win7"
[6] [nov 14 18:16:26:948] [opsi-client-agent] The value of the variable "$OCD_DIST_DIR$" is now: "dist.win7"
[6] [nov 14 18:16:26:948] [opsi-client-agent] EndCase
[6] [nov 14 18:16:26:948] [opsi-client-agent] Case : 6.2
[8] [nov 14 18:16:26:948] [opsi-client-agent] Case mismatch: 6.2 != 6.1
