set $INST_vcredistx86_installed$ = "false"
if GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}] DisplayVersion") = "9.0.30729.4148"
comment "vcredistx86 Version 9.0.30729.4148 is installed"
set $INST_vcredistx86_installed$ = "true"
if GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}] DisplayVersion") = "9.0.21022"
comment "vcredistx86 Version 9.0.21022 is installed"
if GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9BE518E6-ECC6-35A9-88E4-87755C07200F}] DisplayVersion") = "9.0.30729.6161"
comment "vcredistx86 Version 9.0.30729.6161 is installed"
if GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9A25302D-30C0-39D9-BD6F-21E6EC160475}] DisplayVersion") = "9.0.30729"
comment "vcredistx86 Version 9.0.30729 is installed"
if GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5DA8F6CD-C70E-39D8-8430-3D9808D6BD17}] DisplayVersion") = "9.0.30411"
comment "vcredistx86 Version 9.0.30411 is installed"
if GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E503B4BF-F7BB-3D5F-8BC8-F694B1CFF942}] DisplayVersion") = "9.0.21022.218"
comment "vcredistx86 Version 9.0.21022.218 is installed"
n.wenselowski hat geschrieben:
thanks for bringing this to our attention. I will talk to the others about this.
The new code seems to just add further versions to check for. Is this correct?
Any news?
Any news?
We talked about it and Erol wanted to explain this in more depth than I am able to do but currently he is too busy making customers happy.
Iirc correctly we are currently sticking with an older version of vcredist because of the way we build the binaries but wanted to check if switching to a newer version is possible while staying on Python 2. For Python 3 switching to a newer version is not seen as a problem but we aren't there yet.
n.wenselowski hat geschrieben:We talked about it and Erol wanted to explain this in more depth than I am able to do but currently he is too busy making customers happy.
I don't want you to go a new version, I only want to check for other versions of the same visual c++ runtime 2008.
So it's only the script that changes, not a binary. We're installing visual c++ runtime 2008 9.0.30729.6161 every time after the opsi-client-agent has been installed. So this version also works without changed binaries.
It's not tested yet and will only work if you use opsi-script => 4.12.x
Thank you for the hint and feedback are everytime welcome.
Für den professionellen Einsatz und individuelle Beratung empfehlen wir einen Support-Vertrag und eine Schulung. Gerne informieren wir Sie zu unserem Angebot.
ueluekmen hat geschrieben:Hey, sorry for the delay. I think you are right. I have build a new Version: https://download.uib.de/opsi4.1/experim ... .0-22.opsi
Thanks! I will hopefully be able to test this soon.
