opsi 4.0: Updates in testing:
Verfasst: 13 Dez 2017, 13:35
Dear opsi users
Hereby we release some updates for testing packages and some new testing packages.
These are the final opsi 4.0 testing updates for the packages that are released as testing in the last weeks.
At the moment we plan to release these packages as stable on Tuesday 19.12.2017.
New in testing is the package opsi-local-image-restore_4.0.7.4-5.
We removed the property 'method' in this package and the method
'partclone-image-restore' will be always used.
The background is that the method "rsync-partclone-image" has no relevant
speed advantages on SATA hard disks but may destroy windows 10 file system
because it fails on symlinks and junctions.
Happy Testing
In details:
As testing we publish:
Netboot products in the version 4.0.7.4-7
win10_4.0.7.4-7.opsi
win10-captured_4.0.7.4-7.opsi
win10-x64_4.0.7.4-7.opsi
win10-x64-captured_4.0.7.4-7.opsi
win2008-r2_4.0.7.4-7.opsi
win2012_4.0.7.4-7.opsi
win2012-r2_4.0.7.4-7.opsi
win2016_4.0.7.4-7.opsi
win7_4.0.7.4-7.opsi
win7-captured_4.0.7.4-7.opsi
win7-x64_4.0.7.4-7.opsi
win7-x64-captured_4.0.7.4-7.opsi
win81_4.0.7.4-7.opsi
win81-captured_4.0.7.4-7.opsi
win81-x64-captured_4.0.7.4-7.opsi
win81--x64-captured_4.0.7.4-7.opsi
Localboot products
opsi-winst 4.12.0.11
opsi-client-agent_4.0.7.24-2
opsi-script-test 4.12.0.11
opsi-linux products:
Linux Netboot products:
debian (4.0.7.2-5)
sles12sp1 (4.0.7.2-3)
Linux Localboot products
l-system-update 4.0.7.1-6
l-ssh-root-login (1.0-3)
opsi-local-image:
opsi-local-image-restore_4.0.7.4-5.opsi
opsi-local-image-win10_4.0.7.4-5.opsi
opsi-local-image-win10-capture_4.0.7.4-5.opsi
opsi-local-image-win10-x64_4.0.7.4-5.opsi
opsi-local-image-win10-x64-capture_4.0.7.4-5.opsi
opsi-local-image-win7_4.0.7.4-5.opsi
opsi-local-image-win7-capture_4.0.7.4-5.opsi
opsi-local-image-win7-x64_4.0.7.4-5.opsi
opsi-local-image-win7-x64-capture_4.0.7.4-5.opsi
opsi-local-image-win81_4.0.7.4-5.opsi
opsi-local-image-win81-capture_4.0.7.4-5.opsi
opsi-local-image-win81-x64_4.0.7.4-5.opsi
opsi-local-image-win81-x64-capture_4.0.7.4-5.opsi
Server packages:
none
detlef oertel
Changelogs:
opsi-client-agent (4.0.7.24-2) stable; urgency=low
* update to opsi-script 4.12.0.11
-- Detlef Oertel <d.oertel@uib.de> Tue, 12 Dec 2017:15:00:00 +0200
opsi-client-agent (4.0.7.24-1) stable; urgency=low
* update to opsi-notifier 4.0.7.3
* notifier_json: method choicesChanged ; fixes #3196
* notifierguicontrol: objectByIndex: do not crash on wrong ini content ; fixes #3156
* dpi awareness: Vista-8:off; 8.1+:per Monitor
* new dir c:\opsi.org\applog which is open for user and should have the logs from systray and kiosk-client
* update to opsi_client_systray 4.0.7.3
* oslog: changed logging to c:\opsi.org\applog
* DataModuleCreate: initlogging: logfilename := 'systray-' + GetUserName_ ;
* DataModuleCreate: setlogvel to 7
* DataModuleCreate: check for opsiclientd
* update to opsiclientkiosk 4.0.7.12
* ockdata: initlogging: logfilename := 'kiosk-' + GetUserName_ +'.log';
* ockdata: readconf: setlogvel to 7
* code cleanup
* ockdata: main: check for opsiclientd ; fixes #3225
* use delete in Files_redist_cleanup_c / Files_redist_cleanup_d ; fixes #3227
-- Detlef Oertel <d.oertel@uib.de> Tue, 05 Dec 2017:15:00:00 +0200
opsi-client-agent (4.0.7.23-4) stable; urgency=low
* remove of some del -s Options (bug created in last Version)
* removed unused section DosInAnIcon_lock_opsiclientd_conf
* unused file opsicliend.reg
-- Detlef Oertel <d.oertel@uib.de> Mon, 06 Oct 2017:15:00:00 +0200
opsi-client-agent (4.0.7.23-3) stable; urgency=low
* use 'sc failure' to configure opsiclientd service restarts after failure
* use allway -c option in delete and copy to avoid not wanted reboots
-- Detlef Oertel <d.oertel@uib.de> Mon, 02 Oct 2017:15:00:00 +0200
opsi-client-agent (4.0.7.23-2) stable; urgency=low
* Files_del_systray: Fixed wrong path.
* Trying to kill notifier.exe before copying
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 28 Sep 2017:14:00:00 +0200
opsi-winst/opsi-script (4.12.0.11) stable; urgency=low
* Additional fix for Support brackets '[]' in Registry keys
* osfunc: function posFromEnd(const substr : string; const s : string) : integer;
* osparser: doRegistryHack: openkey, deletekey in Registry sections
* osparser: evaluatestring: GetRegistryStringValue*
-- Detlef Oertel <d.oertel@uib.de> Wed, 12 Dec 2017:15:00:00 +0200
opsi-winst/opsi-script (4.12.0.10) stable; urgency=low
* osdefinedfunctions: TOsDefinedFunction.call: free local Vars on leaving the function; fixes #3230
* Fix call of defined functions inside if statement ; fixes #3232
* osdefinedfunctions: call: new param Nestlevel
* osparser: evaluatestring: new param Nestlevel (to use while call defined function)
* osparser: producestringlist: new param Nestlevel (to use while call defined function)
* osparser: doSetVar: new param Nestlevel (to use while call evaluatestring/producestringlist)
* Support brackets '[]' in Registry keys ; fixes #2825
* Encoding Parameter for sections which modify files (patches,Patchtext,...); references #3140
* osencoding: LoadFromFileWithEncoding
* osparser: doIniFilesPatchesMain: shortcut for utf8
* other encoding Problems:
* osencoding: reencode: encode by Default to utf8 which is the internal encoding
* osencoding: LoadFromFileWithEncoding (more changes)
-- Detlef Oertel <d.oertel@uib.de> Wed, 06 Dec 2017:15:00:00 +0200
opsi-winst/opsi-script (4.12.0.9) stable; urgency=low
* osmain: log command line parameter of opsi-script call
* osmain: startprogrammodes: fix for /productid (bug created with /logproductid)
-- Detlef Oertel <d.oertel@uib.de> Mon, 06 Nov 2017:15:00:00 +0200
opsi-winst/opsi-script (4.12.0.8) stable; urgency=low
* start to wor on new modifier '/encoding <encoding>' for patches sections
* osparser: fix Message 'ReportMessages' changed to 'ScriptErrorMessages'
* osparser: fix Message 'ScriptErrorMessages' 'is set to' true/false was wrong
* osparser: tsImportLib: replace constants
opsi-local-image-restore (4.0.7.4-5) stable; urgency=low
* remove method "rsync-partclone-image"
* remove property method
* change setup.py
* now always using method 'partclone-image-restore'
-- detlef oertel <d.oertel@uib.de> Fri, 08 Dec 2017 15:00:00 +0200
windows (4.0.7.4-7) / opsi-local-image (4.0.7.4-5)
* deleting unattend.xml in cleanup script
-- Mathias Radtke <m.radtke@uib.de> Thu Nov 30 14:01:28 2017 +0200
windows (4.0.7.4-6) stable; urgency)low
* nt6.py: support for #@installdiskindex*# placeholder in unattend.xml
* nt6.xml: support for #@installdiskindex*# placeholder in unattend.xml
-- Detlef Oertel <d.oertel@uib.de> Thu, 09 Nov 2017:15:00:00 +0200
windows (4.0.7.4-5) stable; urgency)low
* nt6.py: lookup table for localized adminstrator accounts
* nt6.opsiscript: call setup.exe from installfiles_dir
* nt6.xml: use #@adminName*# instead of 'administrator'
* win2016: default password is Nt123?
-- Detlef Oertel <d.oertel@uib.de> Thu, 02 Nov 2017:15:00:00 +0200
windows (4.0.7.4-4) stable; urgency)low
* nt6.py: minor fixes
* nt6.opsiscript: minor fixes
* opsisetuplib.py: minor fixes
-- Detlef Oertel <d.oertel@uib.de> Thu, 12 Oct 2017:15:00:00 +0200
windows (4.0.7.4-3) stable; urgency)low
* nt6.py: check if correct opsi-script is available
* nt6.py: check for <productid>.png or windows.png' before copy
* nt6.opsiscript: check for <productid>.png or windows.png' before ShowBitmap
* Makefile: copy windows.png as windows.png (makes work with derivated products easyer)
* nt6.py: Show message about productId_ver-ver on clientId
* removed property: blockalignment - now always true
windows (4.0.7.4-2) experimental; urgency)low
* merge from 4.0.7.1-10: nt6.py check for opsi version opsi 4.1 compatible
* nt6.py: make sure that encodedPcpatchPassword is defined
* uefi: create system partition: more info
-- Detlef Oertel <d.oertel@uib.de> Thu, 05 Oct 2017:15:00:00 +0200
windows (4.0.7.4-1) experimental; urgency)low
* integrate use of opsi-script in winpe part
* new nt6.opsiscript
* modified nt6.py: changed work.cmd additonal opsi-script-infos.ini
* new property: multi_disk_mode with values: ["0","1","2","3","prefer_ssd","prefer_rotaional"]
Fallback is first disk
* moving postinst stuff from c:\tmp to c:\opsi.org\log
* removed setwallpaper, opsimbr.exe
* fix 99_cleanup.cmd: path to 64bit shutdown.exe
* opsisetuplib.py: added sleep prior making NTFS partition (mr 4.0.7.1-9)
* update pci.ids, usb.ids ; fixes: #2747
* new property: administrator_password ; fixes: #2396
* new property: winpe_dir ;default=auto; auto=winpe or winpe_uefi, if not auto: used for mbr and uefi; fixes: #2922
* winpe_uefi is a symlink to winpe by default ; fixes: #2863
* postinst and preinst now created from postinst_nt6 and preinst_nt6
* nt5 stuff removed
* winpe* is backuped and restored in preinst/postinst
* create winpe_uefi as symlink if not existing (do)
* postinst.cmd now also allows calling powershell scripts (*.ps1) ; fixes: #2677
-- Detlef Oertel <d.oertel@uib.de> Thu, 24 Aug 2017:15:00:00 +0200
opsi-wim-capture (4.0.7.2-7) stable; urgency=low
* suspends the product if event on_shutdown is detected and < win8.1
* capture.opsiscript: no more setloglevel
-- detlef oertel <d.oertel@uib.de> Mo, 06 Nov 2017 15:00:00 +0000
opsi-wim-capture (4.0.7.2-6) stable; urgency=low
* set opsi-clonezilla property disk_device and use 'diskdevice' in property runcommand
* uefi support
* multi disk support
-- detlef oertel <d.oertel@uib.de> Mo, 30 Oct 2017 15:00:00 +0000
opsi-wim-capture (4.0.7.2-5) stable; urgency=low
* more fixes for win < 8.1
* more fixes for more than one disk
-- detlef oertel <d.oertel@uib.de> Wed, 25 Oct 2017 15:00:00 +0000
opsi-wim-capture (4.0.7.2-4) stable; urgency=low
* fix: added declaration for $aktNumber$
-- rupert roeder <r.roeder@uib.de> Wed, 25 Oct 2017 09:45:00 +0000
opsi-wim-capture (4.0.7.2-3) stable; urgency=low
* fix at "Check for active (boot) disk ..."
-- detlef oertel <d.oertel@uib.de> Mon, 23 Oct 2017 15:00:00 +0000
opsi-wim-capture (4.0.7.2-2) stable; urgency=low
* new property image_flag: Flag will be set after capture
* set flag also after creat via dism
* update auf wimlib 1.12
-- detlef oertel <d.oertel@uib.de> Wed, 04 Oct 2017 15:00:00 +0000
opsi-wim-capture (4.0.7.2-1) stable; urgency=low
* try to include sysprep logs
* call method updateWIMConfig
* fixed ShellInAnIcon_imagex_flags
* fix create work.cmd for different netboot product versions
* start opsi-script in PE with /logproductid
* stop service tiledatamodelsvc before sysprep
* use powershell to get boot drive
* do not use WINDOWS Label to get captutre Drive Letter
-- detlef oertel <d.oertel@uib.de> Wed, 06 Sep 2017 15:00:00 +0000
opsi-wim-capture (4.0.7.1-5) stable; urgency=low
* workaround for setProductActionRequestWithDependencies (none Bug)
-- detlef oertel <d.oertel@uib.de> Thu, 20 Jul 2017 15:00:00 +0000
opsi-clonezilla (4.0.7.2-4) stable; urgency=low
* quickfix smb1 fallback
-- detlef oertel <d.oertel@uib.de> Wed, 25 Nov 2017 15:00:00 +0200
debian (4.0.7.2-5) stable; urgency=low
* Debian9 now installs with working network confiuration
-- Mathias Radtke <m.radtke@uib.de> Wed nov 23 15:20:00 +0100
sles12sp1 (4.0.7.2-3) stable; urgency=low
* replaced opsi4.0 check with an opsi4.x check
-- Mathias Radtke <m.radtke@uib.de> Wed Oct 4 13:43:06 2017 +0200
l-ssh-root-login (1.0-3) stable; urgency=low
* added debian9 compatability
-- Mathias Radtke <m.radtke@uib.de> Wed, 26 Jul 2017 13:28:00 +0200
l-ssh-root-login (1.0-2) stable; urgency=low
* PermitRootLogin prohibit-password now detected
-- Mathias Radtke <m.radtke@uib.de> Mon, 13 Feb 2017 14:55:00 +0100
l-system-update 4.0.7.1-6 stable urgency=low
* Requiring opsi-winst/opsi-script 4.11.6.
* Cleaned up script.
* RedHat: Running yum makecache before attempting to update.
* UCS: Refactored waiting for package lock.
* Increased initial waiting time for the package lock.
* Running on an unsupported distro family will fail.
-- Niko Wenselowski <m.radtke@uib.de> Thu, 17 Nov 2017 12:40:07 +0100
l-system-update 4.0.7.1-5 stable urgency=low
* univention upgrade: retrying twice when failed to upgrade
-- Mathias Radtke <m.radtke@uib.de> Thu, 09 Nov 2017 16:10:00 +0100
opsi-script-test (4.12.0.11-1) stable; urgency=low
* registry:
* fix for Support brackets '[]' in Registry keys ; fixes #2825
-- detlef oertel <d.oertel@uib.de> Tue, 12 Dec 2017 15:00:00 +0200
opsi-script-test (4.12.0.10-1) stable; urgency=low
* test local functions:
* Testing repeated function call with local variables
* Testing fuction call while if
* registry:
-- detlef oertel <d.oertel@uib.de> Mon, 06 Dec 2017 15:00:00 +0200
opsi-script-test (4.12.0.8-1) stable; urgency=low
* test encoding:Patches /encoding "ucs2be"
-- detlef oertel <d.oertel@uib.de> Mon, 23 Oct 2017 15:00:00 +0200
Happy Testing
In details:
win7_4.0.7.4-7.opsi
Localboot products
debian (4.0.7.2-5)
opsi-local-image:
Server packages:
none
detlef oertel
Changelogs:
* code cleanup
* change setup.py
* nt5 stuff removed
* uefi support
* registry:
* registry:
