Mozilla Firefox Version 52.2.1esror54.0.1-1
KrawczykHIS
Beitrag von KrawczykHIS »
Hallo liebes UIB-Team,
mir ist ein Fehler bei der Installation aufgefallen. Folgende Property-Konfiguration wurden geändert:
*firefox-version: esr
*install_architecture: 64
folgendes finde ich in den Logdatei:
[5] [Jul 11 11:14:28:398] [firefox] Execution of Files_copy_local
[6] [Jul 11 11:14:28:400] [firefox] Copying p:\firefox\de64\Firefox Setup 52.2.1esr.exe -----> c:\opsi.org\tmp\
[5] [Jul 11 11:14:28:400] [firefox] 0 File(s) found
[6] [Jul 11 11:14:28:404] [firefox] No (non-directory) file with mask p:\firefox\de64\Firefox Setup 52.2.1esr.exe found
[5] [Jul 11 11:14:28:404] [firefox] 0 File(s) treated
[5] [Jul 11 11:14:28:406] [firefox]
[5] [Jul 11 11:14:28:406] [firefox] Execution of Winbatch_firefox
[4] [Jul 11 11:14:28:406] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:28:810] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:29:212] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:29:616] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:30:020] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:30:424] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:30:826] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:31:228] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:31:631] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:32:033] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe -retrying
[4] [Jul 11 11:14:32:435] [firefox] Warning: file not found :c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe - giving up
[6] [Jul 11 11:14:32:435] [firefox] Call ""c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe" -ms"
[6] [Jul 11 11:14:32:435] [firefox] Waiting until the called process is finished
[6] [Jul 11 11:14:32:435] [firefox] Start process as invoker: SYSTEM
[3] [Jul 11 11:14:32:435] [firefox] Exception in StartProcess_cp: Failed to execute "c:\opsi.org\tmp\\Firefox Setup 52.2.1esr.exe" -ms : 2
Der komplette Log steht hinter diesen Link zur Verfügung: https://myshare.his.de/index.php/s/UvOQxeFIQj0EFy1 (Kennwort: opsi)
Leider fand ich kein Upload im Forum. :oops:
Viele Grüße aus Hannover,
Patrick
Re: Mozilla Firefox Version 52.2.1esror54.0.1-1
Hallo Patrick,
ja, das wird noch nicht abgefangen...
- das firefox Standard Paket ist nur 32-Bit
- wenn man künftig z.B. 3264-Bit Paket deutsch haben will, so muss man einmalig
a) das passende Paket herunterladen (z.Zt. deu3264/firefox_52.2.0esror54.0-1~deu3264.opsi im Unterverzeichnis deu3264)
b) anschliessend die verwendete Konfigurationsdatei des opsi-product-updater dahingehend anpassen, dass
dass in der
- bisherigen Sektion für das Standard-Abo
"firefox" ausgeschlossen wird
excludes = firefox
und am einfachsten dupliziert ma die bisherige Sektion mit einem anderen Namen und dem Eintrag
; The base url of a product package repository
baseUrl = http://download.uib.de
; Comma separated directories to include in search for product packages
; Use / if search should be done in baseUrl
dirs = abo/standard/opsi4/deu3264
und nicht excludiertem firefox
Entschuldigung!
Fehler unsererseits (falsche bzw. fehlende 64-Bit binaries) sollte jetzt behoben sein z.B. in
/deu3264/firefox_52.2.1esror54.0.1-2~deu3264.opsi
