tftp options
tftp options
If I update opsi the tftp files get changed.
For instance, this file: /tftpboot/linux/pxelinux.cfg/default.menu
I always have to change this line:
append initrd=miniroot-x64.bz2 video=vesa:ywrap,mtrr vga=791 quiet splash --no-log console=tty1 console=ttyS0
I change it so it looks like this:
append initrd=miniroot-x64.bz2 video=vesa:ywrap,mtrr vga=791 lang=en --no-log console=tty1 console=ttyS0
If I do not set lang=en I get the german version of the bootimage. Great, but not really workable for me.
I also remove quiet and splash, because sometimes the whole thing hangs and I can see it hangs on something, and restart the whole thing.
Is there a standard way to change these values so I do not have to change it every once in a while?
Or make it some sort of property that allows you to set the language and whether or not quiet and splash is enabled.
Re: tftp options
hi
you can use the bootimage.append within the host-parameters
Cheers
Re: tftp options
That would work for lang=en, but I hope noquiet and nosplash override the normal quiet and splash options.
I am going to test this out, will report back.
Re: tftp options
m.radtke hat geschrieben:you can use the bootimage.append within the host-parameters
This seems to work on the named pipes (01-macaddress), but the default.menu does not seem to get updated.
ueluekmen
Re: tftp options
Beitrag von ueluekmen »
That's right, you have to patch the default-Files manually.
Re: tftp options
That's why this topic is in this subforum :D :D
Re: tftp options
I don't see us updating the default files.
Could it help for your case if we'd set quiet and splash through the host parameters and make our default entry smaller?
This probably would be something to discuss internally before attempting to do so but I see it's appeal.
With kind regards
Re: tftp options
n.wenselowski hat geschrieben:Could it help for your case if we'd set quiet and splash through the host parameters and make our default entry smaller?
Yes, that would work for those things. However, this does not change the language, and I can read German, but not every international customer is able to.
Re: tftp options
By teh way, what's wrong with running a little bit of sed when these options are set? I really wish I could code this for you, but my skills with sed and awk are terrible :( :(
