UCS4.1 netboot product and updated packages in stable
News and announcements
Dear opsi users
hereby we publish the ucs41 netboot product and updated packages in stable.
The ucs41 netboot product leaves the testing area and is available in our stable packages.
With this product one can install an Univention UCS operating System with the following roles:
  • domaincontroller master
    domaincontroller slave
    domaincontroller backup
    memberserver
With the aid of out opsi-linux-client.agent one can administrate these UCS machines.
Additionally we provide a downloadable local http repository. This repository provides all packages for a successful Univention UCS Installation directly installs ucs 4.1-4
http://download.uib.de/opsi4.0/products ... epository/
Please use the porperty online_repository to provide the necessary information for your ucs41 product installation
Here is the list of all updated stable packages:
  • Serverside:
    opsipxeconfd (4.0.7.5-3)
    Clientside:
    ucs41 (4.0.7.1-7)
    l-opsi-server 4.0.7.1-7
CAUTION: We are actively working on an opsi support on UCS memberserver roles. They are currently not supported.
Cheers
Changelogs
l-opsi-server 4.0.7.1-7; stable; urgency=low
  * ucs memberserver: not setting clientconfig.depot.user manually
  * new properties: myIPNumber, myIPName default=auto=standard name and address (do 06.01.2017)
-- M.Radtke <m.radtke@uib.de> Thu, 19 Jan 2017 14:03:00 +0100
l-opsi-server 4.0.7.1-6; stable; urgency=low
  * added sles12sp2/leap42.2 compatability
  * ucs memberserver: using passwd file for all password changes
  * ucs installation: added opsi-linux-support
-- M.Radtke <m.radtke@uib.de> Wed, 04 Jan 2017 16:20:00 +0100
l-opsi-server 4.0.7.1-5; stable; urgency=low
  * added changes in ShellInAnIcon_add_adminuser_ucs to support memberserver role
  * removed gpg check when installing opsi products from OpenSUSE Buildservice
  * added better handling of ucs domaincontroller_backup opsi installation
  * added correct centos6 handling
-- M.Radtke <m.radtke@uib.de> Fr, 23 Sep 2016 09:15:00 +0200
l-opsi-server 4.0.7.1-4; testing; urgency=low
  * redhat/centos 6 compatability (downloadonly plugin seems broken)
  * added ucs memberserver workaround
-- M.Radtke <m.radtke@uib.de> Tue, 23 Jun 2016 14:00:00 +0100
l-opsi-server 4.0.7.1-3; testing; urgency=low
  * fix: dhcp stop start instead of restart, restart doesnt work sometimes
  * fix: wrong sequence of arguments at getValueFromFile
  * sles11sp4: noerror on p7zip
  * sles11sp4: noerror on failed first xinetd restart
  * sles11sp4: use ShellInAnIcon_add_adminuser_pwdutils
  * ucs41: corrected handling when not running on domaincontroller_master
-- d.oertel <d.oertel@uib.de> Thu, 23 Jun 2016 15:00:00 + 0100
l-opsi-server 4.0.7.1-2 ; testing ; urgency=low
  * fix: ShellInAnIcon_install_dhcp_suse / ShellInAnIcon_install_opsi_suse
-- d.oertel <d.oertel@uib.de> Wed, 22 Jun 2016 15:00:00 + 0100
l-opsi-server 4.0.7.1-1 ; testing ; urgency=low
  * new property install_and_configure_dhcp (default=false)
  * new property: gateway (for dhcp)
  * property backend now with default=file
  * property product_depot_base_url removed
-- d.oertel <d.oertel@uib.de> Wed, 08 Jun 2016 15:00:00 + 0100
opsipxeconfd (4.0.7.5-3) stable; urgency=medium
  * debian/ubuntu: added missing esac in postrm
 -- Mathias Radtke <m.radtke@uib.de>  Thu, 08 Dec 2016 13:39:34 +0100
opsipxeconfd (4.0.7.5-2) experimental; urgency=medium
  * opsipxeconfd.spec: deactivated removing su line from logrotate on SLES11SP4
 -- Mathias Radtke <m.radtke@uib.de>  Thu, 08 Dec 2016 10:33:37 +0100
opsipxeconfd (4.0.7.5-1) stable; urgency=medium
  * opsipxeconfd.spec: added detection of SLES12SP2 & OpenSUSE Leap42.2
 -- Mathias Radtke <m.radtke@uib.de>  Wed, 07 Dec 2016 10:45:36 +0100
opsipxeconfd (4.0.7.4-2) experimental; urgency=medium
  * Integrating with systemd.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 18 Oct 2016 17:14:34 +0200
opsipxeconfd (4.0.7.4-1) testing; urgency=medium
  * Internal refactoring to have many small methods instead of a few
    huge.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 04 Oct 2016 16:18:18 +0200
opsipxeconfd (4.0.7.3-2) stable; urgency=medium
  * RPM postinst: only remove "su" from logrotate config on RHEL 6 / CentOS 6.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 04 Oct 2016 15:48:24 +0200
opsipxeconfd (4.0.7.3-1) stable; urgency=medium
  * Do not fail when reading configuration of writer for status.
  * Do not truncate output of 'status' command.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Thu, 29 Sep 2016 11:18:34 +0200
opsipxeconfd (4.0.7.2-1) testing; urgency=medium
  * Making oct values Python 3 compatible.
  * Various internal refactorings.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 09 Sep 2016 11:11:47 +0200
ucs41 (4.0.7.1-7) stable; urgency)low
  * control: removed ftp.debian.org -> <OPSISERVER>/opsi/univention-repository/mirror/4.1/maintained/4.1-4/
-- Mathias Radtke <m.radtke@uib.de> Mon Jan 30 15:53:00 2017 +0100
ucs41 (4.0.7.1-6) stable; urgency=low
  * opsisetuplib.py: syncing disks before use
-- Mathias Radtke <m.radtke@uib.de> Mon Jan 23 10:31:20 2017 +0100
ucs41 (5.0.7.1-5) stable; urgency=low
  * updated initrd + kernel to ucs 4.1.4
-- Mathias Radtke <m.radtke@uib.de> Thu, 19 Jan 15:43:00 2017 +0100
ucs41 (4.0.7.1-4) stable; urgency=low
  * installing samba4 packages for domaincontroller_master in rc.local
  * new property: external_nameserver
    Helps to install direct a correct name server in complicated nat environments
  * change property ucs_master_admin_passw to ucs_master_admin_passwdord (auto confidential in configed)
-- Detlef Oertel <d.oertel@uib.de>  Tue, 17 Jan 2017:15:00:00 +0100
ucs41 (4.0.7.1-3) stable; urgency=low
  * opsisetuplib, opsipreparelib: added eMMC compatability & EFI partitioning fix when not running on sda devic
  * removed ^M chars from rc.local
-- Mathias Radtke <m.radtke@uib.de> Fri Nov 11 12:25:18 2016 +0100
ucs41_4.0.7.1-2 stable; urgency=low
  * added memberserver_profile to install memberserver
-- Mathias Radtke <m.radtke@uib.de>  Thu, 10 Aug 2016 11:35:00 +0200
ucs41_4.0.7.1-1 stable; urgency=low
  * joining with domaincontroller_master when ucs_role is different
  * added univention-join command with correct params to rc.local first boot
  * removing unneded opsi-client-agent architecture binaries
  * removed property opsi_online_repository
  * Property: install_opsi-client-agent default changed to true
-- Mathias Radtke <m.radtke@uib.de>  Thu, 30 Jun 2016 15:36:00 +0200
