Dear opsi Users,
during the testingperiod of 4.0.7 we have modified some products.
As testing we publish today:
OS-packages :
* python-opsi 4.0.7.17-1
* opsi-linux-support 4.0.7-5
Localboot:
* opsi-client-agent_4.0.7.3-1
Netboot:
* opsi-clonezilla_4.0.7.2-2
opsi-linux:
* sles12sp1_4.0.7.1-2
* sles12_4.0.7.1-2.opsi
* redhat70_4.0.7.1-3.opsi
* l-jedit_5.3-6
* l-opsi-server_4.0.7.1-4.opsi
opsi-local-image:
* opsi-local-image-opensuse13-2_4.0.7.1-1
* opsi-local-image-ubuntu_4.0.7.1-1
* opsi-local-image-restore_4.0.7.1-2
* opsi-local-image-backup_4.0.7.2-2
* opsi-local-image-delimage_4.0.7.1-1
* opsi-local-image-capture_4.0.7.1-1
* opsi-local-image-prepare_4.0.7.1-1
You can find the testing-packages here:
http://download.uib.de/opsi4.0/testing/ ... /products/
kindly regards
erol ueluekmen
Changelogs:
Server:
python-opsi (4.0.7.17-1) stable; urgency=medium
* OPSI.Util: Refactored encryptWithPublicKeyFromX509CertificatePEMFile
and decryptWithPrivateKeyFromPEMFile.
-- Niko Wenselowski <n.wenselowski@uib.de> Thu, 18 Aug 2016 10:10:53 +0200
python-opsi (4.0.7.16-1) testing; urgency=medium
* OPSI.System.Posix: new function isOpenSUSELeap.
* OPSI.Util.Task.Rights: Improved support for openSUSE Leap.
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 15 Aug 2016 16:53:24 +0200
python-opsi (4.0.7.15-1) stable; urgency=medium
* corrected opsi-set-rights for openSUSE
-- Mathias Radtke <m.radtke@uib.de> Wed, 10 Aug 2016 13:44:48 +0200
python-opsi (4.0.7.14-1) stable; urgency=medium
* OPSI.Util.Task.Rights: Corrected path for UCS.
-- Niko Wenselowski <n.wenselowski@uib.de> Fri, 05 Aug 2016 15:56:55 +0200
opsi-linux-support (4.0.7-5) stable; urgency=medium
* Better out-of-the-box experience for UCS.
* SUSE: do not alter default options.
-- Niko Wenselowski <n.wenselowski@uib.de> Fri, 05 Aug 2016 15:46:46 +0200
opsi-linux-support (4.0.7-4) testing; urgency=medium
* Refactored RPM postinst.
-- Niko Wenselowski <n.wenselowski@uib.de> Thu, 28 Jul 2016 17:13:41 +0200
opsi-linux-support (4.0.7-3) testing; urgency=medium
* SLES11 should now run out of the box.
* Repaired support for CentOS / RHEL 7.
* Fixed accidently broken support for CentOS / RHEL 6.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 27 Jul 2016 16:56:50 +0200
opsi-linux-support (4.0.7-2) testing; urgency=medium
* Better support for CentOS / RHEL 6.
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 25 Jul 2016 16:26:05 +0200
opsi-linux-support (4.0.7-1) experimental; urgency=medium
* Better support for SLES 11.
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 25 Jul 2016 12:07:11 +0200
opsi-linux-support (1.0-10) testing; urgency=medium
* Re-release for rebuild.
-- Niko Wenselowski <n.wenselowski@uib.de> Thu, 21 Jul 2016 17:41:40 +0200
Localboot:
opsi-client-agent (4.0.7.3-1) stable; urgency=low
* opsiclientd 4.0.87
* OpsiLoginBlocker version 1.2.1.0 fixes for early unblock
-- Erol Ueluekmen <e.ueluekmen@uib.de> Mon, 22 Aug 2016:22:50:00 +0200
opsi-client-agent (4.0.7.2-1) stable; urgency=low
* opsiclientkiosk.exe 4.0.7.2: --lang Option
-- Detlef Oertel <d.oertel@uib.de> Mon, 08 Aug 2016:15:00:00 +0200
opsiclientd (4.0.87) stable; urgency=medium
* verifyServerCert and verifyServerCertbyCA fix
* fixes for proxySupport
-- Erol Ueluekmen <e.ueluekmen@uib.de> Mon, 22 Aug 2016 22:10:51 +0200
Netboot:
opsi-clonezilla (4.0.7.2-2) stable; urgency=low
* more logging (free -m / ls -l on mountpoint)
-- detlef oertel <d.oertel@uib.de> Mo, 22 Aug 2016 15:00:00 +0200
opsi-clonezilla (4.0.7.2-1) stable; urgency=low
* adding drbl-2.20.11.tar.bz2 (xenial / opsi 4.0.7)
* update to clonezilla 3.21.13
* update perl
* new properties: disk_number, part_number to better support non standard disks
* mount image share before the libs are extracted
-- detlef oertel <d.oertel@uib.de> Thu, 18 Aug 2016 15:00:00 +0200
opsi-clonezilla (4.0.7.1-1) stable; urgency=low
* adding clonezilla 3.21.10 for bootimage >= 20160517 (xenial / opsi 4.0.7)
-- detlef oertel <d.oertel@uib.de> Fri, 20 May 2016 15:00:00 +0200
opsi-linux:
l-opsi-server 4.0.7.1-4; testing; urgency=low
* redhat/centos 6 compatability (downloadonly plugin seems broken)
* added ucs memberserver workaround
-- M.Radtke <m.radtke@uib.de> Tue, 23 Jun 2016 14:00:00 +0200
sles12_4.0.7.1-2 stable; urgency=low
* removed hard coded kexec depot copy
-- Mathias Radtke <m.radtke@uib.de> Mon, 8 Aug 2016 13:20:00 +0200
sles12sp1_4.0.7.1-2 stable; urgency=low
-- Mathias Radtke <m.radtke@uib.de> 8 Aug 2016 13:20:00 +0200
redhat70_4.0.7.1-3 stable; urgency=low
* redhat70.cfg: removing rhel-7-server-rt-beta-rpms repository as it is (currently) broken
-- Mathias Radtke <m.radtke@uib.de> Mon, 22 Aug 2016 12:00:00 +0200
redhat70_4.0.7.1-2 stable; urgency=low
* removed hard coded kexec from depot, replaced with bootimage kexec
opsi-local-image:
opsi-local-image-backup (4.0.7.2-2) stable; urgency=low
* new opsisetuplib.py
* use getPartitionDevicePath(disk.device, PartitionNumber) where needed
—detlef oertel <d.oertel@uib.de> Wed, 10 Aug 2016 15:00:00 +0200
opsi-local-image-backup (4.0.7.2-1) stable; urgency=low
* for ext4: clonemethod = u’--dev-to-dev --restore_raw_file’
—detlef oertel <d.oertel@uib.de> Mo, 08 Aug 2016 15:00:00 +0200
opsi-local-image-capture (4.0.7.1-1) stable; urgency=low
-- detlef oertel <d.oertel@uib.de> Wed, 10 Aug 2016 15:00:00 +0200
opsi-local-image-delimage (4.0.7.1-1) stable; urgency=low
opsi-local-image-delimage (4.0.6.1-1) stable; urgency=low
* link opsisetuplib.py from os-products
* update opsisetuplib.py
-- detlef oertel <d.oertel@uib.de> Tue, 04 Aug 2015 15:00:00 +0200
opsi-local-image-prepare (4.0.7.1-1) stable; urgency=low
opsi-local-image-restore (4.0.7.1-2) stable; urgency=low
opsi-local-image-restore (4.0.7.1-1) stable; urgency=low
* do not load own partclone package (0.2.58) for bootimage >= 20160517
-- detlef oertel <d.oertel@uib.de> Wed, 18 May 2016 15:00:00 +0200
Packages for 4.0.7 in Testing
