opsi Packages for 4.0.6 testing and stable (pre Release 4.0.7)
Verfasst: 06 Jun 2016, 15:54
Dear opsi users,
The new release 4.0.7 opsi approaches.
opsi 4.0.7 will bring a new boot image,
which unfortunatly is not entirely compatible with the current Netbootproducts.
To avoid sudden incompatibilities when changing
we bring now all essential Netproducts to testing with one variant, which works with both the current and also with the
4.0.7 version.
And for the products published on 06.03.2016 as testing, we are also publishing them as stable and free.
As testing we publish the following:
Netboot:
* Various Windows NT6 4.0.6.2-6
opsi-local-image:
* Various opsi-local image windows NT6 (4.0.6.1-4)
* Opsi-local image windows XP
* Opsi-local-image-prepare (4.0.6.1-3)
* Opsi-local-image-opensuse13-2 (4.0.6.2-4)
* Opsi-local-image-ubuntu (4.0.6.1-4)
opsi-linux:
* Debian (4.0.6.1-3)
* Ubuntu (4.0.6.1-6)
* Debian7 (4.0.6-5)
* Debian8 (4.0.6-5)
* Ubuntu14-04 (4.0.6-6)
* Ubuntu15-10 (4.0.6-6)
* Ubuntu16-04 (4.0.6-6)
* Centos70 (4.0.6.2-3)
* Redhat70 (4.0.6.2-3)
* Opensuse13-2 (4.0.6.2-6)
* Opensuse42-1 (4.0.6.2-6)
* Sles12 (4.0.6.2-6)
* Sles12sp1 (4.0.6.2-6)
* L-desktop 4.0.6.1-1
The Testing opsi products can be found at:
http://download.uib.de/opsi4.0/testing/opsi-v406/
As stable we publish:
Localboot:
* Config-win10 (4.0.6-7)
* Opsi-wim-capture (4.0.6.1-6)
* Opsi-winst (4.11.5.20-1)
opsi-local-image:
* Opsi-local-image-prepare (4.0.6.1-2)
* Opsi-local-image-ubuntu (4.0.6.1-3)
opsi-linux:
* Ubuntu14_04 (4.0.6-5)
* Ubuntu15_10 (4.0.6-5)
* Debian7 (4.0.6-4)
* Debian8 (4.0.6-4)
As always, kind regards,
Martin Scalese
changelogs:
Netboot:
windows (4.0.6.2-6) experimental; urgency = low
* Setup.py: corrected NVME disk handling in EFI mode
- Mathias Radtke <m.radtke@uib.de> Wed May 25 17:08:51 +0200 2016
windows (4.0.6.2-5) stable; urgency = low
* Writing product id, product version, package version and hostid at the log start
* Setting dataPartitionPreserve = 'never' if (windows partition size == "100%")
* Fix in postinst_win: removing property installfiles_dir
* Opsisetuplib.py: Bypassing errorwhen removing empty directories in / dev
- Detlef Oertel <d.oertel@uib.de> Wed, 12 May 2016: 15: 00: 00 +0200
windows (4.0.6.2-4) stable; urgency = low
* Internal, experimental and undocumented (my vanish without notice):
If there are multiple dirs matching installfiles * (installfiles? *)
a property is installfiles_dir creasted Which give The Possibility
to choose between different installation medias
- Detlef Oertel <d.oertel@uib.de> Wed, 20 Apr 2016: 15: 00: 00 +0200
Localboot:
config-win10 (4.0.6-7) stbale; urgency = low
* Added new property to disable the OneDrive application
- Mathias Radtke <m.radtke@uib.de> Mon, 23 Mar 2016 08:42:00 + 0100
opsi-wim-capture (4.0.6.1-6) stable; urgency = low
* Fix: Property descriptions in controlfile
- Detlef oertel <d.oertel@uib.de> Fri, April 29, 2016 15:00:00 +0000
opsi-wim-capture (4.0.6.1-5) stable; urgency = low
* Fix: change unwanted spaces from clonezilla_imagefile to '_'
- Detlef oertel <d.oertel@uib.de> Mon, 18 April 2016 15:00:00 +0000
opsi-winst / opsi script (4.11.5.20-2) stable; urgency = low
* This Changelog shorted Because it exceeded the maximum length of a text field in MariaDB
- Detlef Oertel <d.oertel@uib.de> Thu, 21 Apr 2016: 15: 00: 00 +0200
opsi-winst / opsi script (4.11.5.20) stable; urgency = low
* More logging to find bug: loginscrpits do not always can Impersonate (uib # 2015121410000075):
* Osfuncwin2: Impersonate2User: change parameters / add usercontextsid
* Osfuncwin2: Impersonate2User: more logging if userContext not found
* Osparser: doLinkFolderActions: if runLoginScripts: call Impersonate2User with usercontextsid
- Detlef Oertel <d.oertel@uib.de> Fri 08 Apr 2016: 15: 00: 00 +0200
opsi-local-image:
opsi-local-image-capture (4.0.6.1-6) stable; urgency = low
- Detlef oertel <d.oertel@uib.de> Mon, 17 May 2016 15:00:00 +0200
opsi-local-image-prepare (4.0.6.1-3) stable; urgency = low
* LvmClearVolumeGroups ()
opsi-local-image-prepare (4.0.6.1-2) stable; urgency = low
* New property delay_for_reboot (Time in seconds before reboot (to give time to handle setup_after_install))
- Detlef oertel <d.oertel@uib.de> Fri, April 29, 2016 15:00:00 +0200
opsi-local-image- (windows *) (4.0.6.1-5) stable; urgency = low
- Mathias Radtke <m.radtke@uib.de> Fri, April 13, 2016 14:00:00 +0200
opsi-local-image-ubuntu (4.0.6.1-4) stable; urgency = low
* Some more dependencies for opsi-linux-client-agent (do)
opsi-local-image-ubuntu (4.0.6.1-3) stable; urgency = low
* Release: added wily and xenial, removed: quantal, raring saucy
* Multiple ports from ubuntu (4.0.6.1-5)
- Detlef Oertel <d.oertel@uib.de> Fri, 22 Apr 2016: 15: 00: 00 +0200
opsi-local-image-opensuse13-2 (4.0.6.2-4) stable; urgency = low
* Use kexec from boot image
opsi-linux:
Linux * stable; urgency = low:
debian (4.0.6.1-3)
ubuntu (4.0.6.1-6)
debian7 (4.0.6-5)
debian8 (4.0.6-5)
ubuntu14-04 (4.0.6-6)
ubuntu15-10 (4.0.6-6)
ubuntu16-04 (4.0.6-6)
centos70 (4.0.6.2-3)
redhat70 (4.0.6.2-3)
opensuse13-2 (4.0.6.2-6)
opensuse42-1 (4.0.6.2-6)
sles12 (4.0.6.2-6)
sles12sp1 (4.0.6.2-6)
changelog entry:
debian8_4.0.6-4 stable; urgency = low
debuntu.py: removed static variable RELEASEID
- Mathias Radtke m.radtke@uib.de Wed, 04 May 2016 09:45:00 +0200
ubuntu14_04_4.0.6-5 testing; urgency = low
ubuntu15_10_4.0.6-5 testing; urgency = low
debian7_4.0.6-4 testing; urgency = low
l-desktop 4.0.6.1-1; testing; urgency = low
* No ppa for cinnamon since 14:10
* Enhanced error handling in shell calls
* Detect opsiclientd
- D.oertel <d.oertel@uib.de> Fri, 13 May 2016 13:08:36 + 0100
4.0.7 version.
Netboot:
opsi-local-image:
opsi-linux:
* Debian7 (4.0.6-5)
* Debian8 (4.0.6-5)
Localboot:
opsi-local-image:
opsi-linux:
* Debian7 (4.0.6-4)
* Debian8 (4.0.6-4)
Martin Scalese
changelogs:
Netboot:
Localboot:
opsi-local-image:
opsi-linux:
debian (4.0.6.1-3)
ubuntu (4.0.6.1-6)
debian7 (4.0.6-5)
debian8 (4.0.6-5)
sles12 (4.0.6.2-6)
changelog entry:
