Netboot, localboot product group
loggenk
Beitragvon loggenk » 13 Jan 2015, 08:30
It seems great for me if i can image a system without configuring everything.
I mean when the system is a notebook i also will install the Intel Wireless Pro, but if the system is a desktop i don't need the Intel Wireless.
If the system doesn't have 4 GB memory i don't want the 64-bit version, but the X86 version.
Greetings,
Kees...
Re: Netboot, localboot product group
Beitragvon n.wenselowski » 13 Jan 2015, 10:22
Hello Kees,
intelligent systems sound great :)
I am not sure if we ever get to the point where we have an solution for everyone but I can image working towards your goal with the already existing methods. You could write a custom netboot products whose only purpose is to analyse the hardware it is running on and then, depending on what is found, does set the appropriate products to setup in opsi.
How does this sound?
With kind regards
loggenk
Beitragvon loggenk » 13 Jan 2015, 10:23
Hi Niko. I will give it a try. Thanks for your suggestion
Greetings,
Kees...
Beitragvon SisterOfMercy » 23 Jan 2015, 13:28
loggenk hat geschrieben:If the system doesn't have 4 GB memory i don't want the 64-bit version, but the X86 version.
Why not? Running only 64-bit does cut down on the number of things you have to keep in working order ;)
And even for systems with only 4 GB of memory a 64-bit OS can be helpful, a process is limited to 2 GB of memory.
