OpsiWebManager
Verfasst: 12 Dez 2011, 12:00
von Antoine GUEVARA
OpsiWebManager (OWM) is a web interface which permit you to interact with OPSI.
I'm currently working on this interface so all the features are not yet available.
You can :
Manage clients ( create/show detail/remove/wakeup/shutdown/reboot)
Manage Opsi Package ( show/create(alpha)/remove(alpha) )
Manage Backups ( show/detail with description )
View configuration of OPSI
This interface is develop in PHP/JQuery with the Symfony2 framework
Link
https://github.com/darkounet/OpsiWebManager
UPDATE :
21/12/2011 :
You can now import a list of client via a .csv file.
Re: OpsiWebManager
Verfasst: 14 Dez 2011, 15:51
von adlerweb
I guess thats called "great minds think alike" ;). I started a similar ui based on PHP and DOJO some time ago. Hadn't uploaded it since its just some basic (and poorly written) poc-stuff and i had no time to really start writing useable code. I uploaded the code now at https://github.com/adlerweb/OohJa Screen1 Screen2 but i guess there is not much to copy since its mainly just Copy/Paste.
BTT: I installed your UI on a machine (and translated your installation guide) but ran into a problem: i can change settings under app.php/configuration/modifier/ but they dont get saved and no server URL = no data. Is this online-config-feature missing? If not: Where are settings supposed to be saved? Edit: Never mind - i used RPC calls and didn't notice you're using exec(). Had to configure sudo... Added to german and english setup guide
Re: OpsiWebManager
Verfasst: 14 Dez 2011, 23:19
von Antoine GUEVARA
Hi, thx for your translation of Wiki.
My OWM is in alpha version, so it's normal if you can't modify the configuration via /configuration/modifier/
I will try to use RPC to view the difference between exec().
Antoine
Re: OpsiWebManager
Verfasst: 05 Mär 2013, 10:47
von Zakyl
Bonjour,
Je suis désolé si ça parait un peu bête mais je n'arrive pas à mettre en place OWM ^^' Je ne connais pas Symfony et du coup je suis un peu perturbé.
J'ai mis en place Symfony d'après le readme.md du package OWM, je suis donc sur ma page Symfony (http://ip/Symfony/web/app_dev.php/) bien configurée, mais ensuite ? Que faire du package OWM ? Comment l'intégrer ?
Merci !
Re: OpsiWebManager
Verfasst: 05 Mär 2013, 15:14
von Antoine GUEVARA
Bonjour,
Avez vous suivi le wiki ? dans la partie installation ? le readme de base est celui pour installer Symfony et non pour l'installation d'OWM ( je vais corriger cela ) :)
De plus OWM a recu quelque changement depuis la version qui est sur github, je suis actuellement en train de faire une refonte complete du système OWM afin d'apporter encore plus de fonctionnalité ( support mobile/tablette ).
N'hesitez pas a faire du feedback.
Antoine GUEVARA
Re: OpsiWebManager
Verfasst: 05 Mär 2013, 16:15
von Zakyl
Ah, non, pas vu ^^'
Bon, du coup je suis le Wiki, mais j'ai pas mal d'erreurs qui ne me permettent pas d'installer OWM :( :
- sudo pecl install yaml-0.6.3 :
No releases available for package "pecl.php.net/yaml"
install failed
Du coup j'ai installé yaml en le téléchargeant la version 1.1.0
- git clone git://github.com/darkounet/OpsiWebManager.git
Cloning into OpsiWebManager...
github.com[0: 207.97.227.239]: errno=Connection refused
fatal: unable to connect a socket (Connection refused)
J'ai téléchargé l'archive .zip puis ai décompressé le dossier OpsiWebManager dans /var/www/
- php app/console assets:install --symlink web/
[code]PHP Fatal error:  Class 'Symfony\Component\Filesystem\Filesystem' not found in /var/www/OpsiWebManager/app/cache/dev/appDevDebugProjectContainer.php on line 219
[/code]
- Access the WebUI via http://localhost/OpsiWebManager/web/app.php/
Du coup je n'affiche rien
Ces erreurs viennent d'un truc que j'ai mal configuré ? :/
