Dosbatch section no longer shows "cmd" windows !
Verfasst: 29 Nov 2023, 15:25
in the installation of a localboot product with a "dosbatch" section, the "cmd" window does not appear : the commands are executed but I do not see the result.
I often use this type of section, ended with a "pause", for debugging purposes...
What can I do ?
Best regards.
What can I do ?
Best regards.
