Hotfix Release: opsi-linux-bootimage
Verfasst: 16 Okt 2023, 10:31
Dear opsi users,
we hereby release a hotfix for the opsi-linux-bootimage.
Back in september 2022 we renamed the grub bootloader from grubx64.efi to opsi-netboot.efi.
Most of you didn't notice the change, as we advise to use the UEFI bootfile shimx64.efi.signed as a DHCP bootfile for UEFI clients.
There are still some installations that use grubx64.efi as a UEFI DHCP startfile. THis hotfix is intended for such environments.
This hotfix creates a symbolic link from grubx64.efi to opsi-netboot.efi to ease the process of the change back in september 2022.
Regards
EDIT:
Currently the Open BuildService is expecting some outtages. Therefore it can take some time until the package is finally available
Regards
EDIT:
The backend server hosting the home:* projects has currently not a working storage system.
We expect to bring the data back, but it is currently disabled to avoid lockups in the rest of the system.
opsi-linux-bootimage (20231013-1) testing; urgency=high
* postinst: create grubx64.efi symlink
-- Mathias Radtke <m.radtke@uib.de> Fri, 13 Oct 2023 13:41:00 +0200
opsi-linux-bootimage (20230920-1) testing; urgency=low
* postinst: removing double quotes in fileadmingroup name if present
-- Mathias Radtke <m.radtke@uib.de> Wed, 20 Sep 2023 13:22:00 +0200
