Updates for opsi 4.2 in testing and stable
News and announcements
Dear opsi users,
with this release we have published new packages for opsi 4.2 in testing and stable.
In the opsi-Configed 4.2.21.1 (testing & stable) released as a hotfix, a number of problems have been fixed.
Updated packages in opsi 4.2 testing:
Localboot packages Windows:
* opsi-configed (4.2.21.1-1)
* opsi-client-agent (4.2.0.53-1)
* opsi-script (4.12.9.0-3)
Localboot packages Linux:
Localboot packages macOS:
Updated packages in opsi 4.2 stable:
Server packages:
* opsiconfd (4.2.0.306-1)
* opsi-utils (4.2.0.201-1)
With kind regards
Changelogs:
opsi-configed (4.2.21.1) 	EXPERIMENTAL; urgency=medium
* Fix client selection dialog for non MySQL
-- Jan Schneider <j.schneider@uib.de> Wed, 14. Apr 2023 08:00:00 +0200
opsi-configed (4.2.21.0) 	EXPERIMENTAL; urgency=medium
* Improve messagebus connection handling, auto reconnect
* Improve 2FA handling, add password dialog
* Do not process expired messagebus messages
* Fix SLF4J warnings
* Fix UpdateCommand casting error
* Correct order of action requests in combobox
* Fix boolean table cell renderer (WAN column in client table)
* Do not show essential / devel log messages in GUI
-- Jan Schneider <j.schneider@uib.de> Wed, 12. Apr 2023 17:00:00 +0200
opsi-client-agent (4.2.0.53-1) stable; urgency=low
  * Update opsiclientd to 4.2.0.143
-- Jan Schneider <j.schneider@uib.de> Fri, 14 Apr 2023 11:30:00 +0100
opsi-client-agent (4.2.0.52-1) stable; urgency=low
  * Update opsiclientd to 4.2.0.142 (improvement in product caching)
  * Update opsi-script to 4.12.9.0 (compatibility with opsi 4.3)
  * Some improvements in installation procedure rebustness
-- Nils Doerrer <n.doerrer@uib.de> Wed, 12 Apr 2023 13:30:00 +0100
opsi-client-agent (4.2.0.51-1) stable; urgency=low
  * Update opsiclientd to 4.2.0.141
-- Jan Schneider <j.schneider@uib.de> Thu, 02 Apr 2023 10:00:00 +0100
opsi-script (4.12.9.0) urgency=medium
  Fixes:
    remove possible memory leaks
    remove TQProgressBar to fix memory leaks
    fix in handling profiles, avoid empty string in the profilelist [W]
  Changes:
      replace deprecated API methods, adaptations for opsi 4.3
-- j.werner <j.werner@uib.de> 11 April 2023
opsiconfd (4.2.0.306-1) stable; urgency=medium
  * Improvement:  New configed links
 -- uib GmbH <info@uib.de>  Sat, 11 Mar 2023 09:35:54 +0100
opsi-utils (4.2.0.201-1) stable; urgency=medium
  * Improvement:  updated opsi-cli to 4.2.0.6
 -- uib GmbH <info@uib.de>  Tue, 04 Apr 2023 16:00:03 +0200
opsi-utils (4.2.0.200-1) stable; urgency=medium
  * No public changes
 -- uib GmbH <info@uib.de>  Fri, 31 Mar 2023 09:31:46 +0200
opsi-utils (4.2.0.199-1) stable; urgency=medium
  * Improvement:  change opsi-sever.repo autoUpdate/install to false
 -- uib GmbH <info@uib.de>  Tue, 28 Mar 2023 15:46:42 +0200
opsi-utils (4.2.0.198-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Tue, 28 Mar 2023 09:04:48 +0000
opsi-utils (4.2.0.197-1) stable; urgency=medium
  * Improvement:  Use repositoryRemoteUrl for depot connection
  * Improvement:  updated python-opsi to 4.2.0.320
 -- uib GmbH <info@uib.de>  Thu, 23 Mar 2023 19:09:52 +0100
