Updates 4.2 stable and testing
Verfasst: 30 Mär 2023, 11:56
Dear opsi users,
today we have released more packages for opsi 4.2 in testing and stable.
Download the new opsi-Configed 4.2.20.8-1 - it's worth it: Both the login and the sizes and the positions of opening frames have been reworked so that working with the new opsi-Configed will be a more comfortable experience. We also removed unnecessary server-operations on login and reload which leads to - depending on your environment - smaller up to substantial performance boosts. We also worked on the performance on other places.
There will be some new features, too: For better security we have implemented TLS-certificate verification before every connection to a server. There are also new options for resetting products: You're now able to reset Netboot-products, too. The main frame now warns you in a button if you are getting close to - or even exceeding - the limits of the licences of opsi-modules.
Apart from that there are some minor improvements and bugfixes, for more details check the changelogs.
We have decided to publish this new version directy to stable since it fixes important bugs (for example in the depot configuration) that occure in the current stable version.
stable
Linux Localboot
- opsi-configed (4.2.20.13-1)
- l-opsi-server (4.2.0.9-2)
- opsi-setup-detector (4.2.1.17-1)
Mac:
Misc
- opsi-quickinstall (4.2.0.9-2)
Windows Localboot
Windows Netboot
- win2022 (4.2.0.3-7) X
testing:
Linux Localboot
- opsi-script (4.12.8.0-3)
- opsi-script-test (4.12.8.0-3)
Mac:
Windows Localboot
- opsi-winst (4.12.8.0-3)
- opsi-client-agent (4.2.0.50-1)
Server:
- opsiconfd 4.2.0.306)
- opsi-utils(4.2.0.199)
- opsi-linux-bootimage (20230328)
With kind regards
Fabian Kalweit
[Changelog]
stable
Linux Localboot
Mac:
Misc
Windows Localboot
Windows Netboot
testing:
Linux Localboot
Mac:
Windows Localboot
Server:
With kind regards
Fabian Kalweit
[Changelog]
psi-setup-detector (4.2.1.17-1) stable; urgency=low
* Fix: Templates: win delincmsidouble.opsiscript: fix Files_uninstall call
* Fix writing property values to control file
* osdcreate: createopsifiles
* osdcreate: opsiquotestr
* Fix writing updatescript to control file
* osdcreate: initaktproduct
-- Detlef Oertel <d.oertel@uib.de> Wed, 15 Mar 2023 : 15:00:00 +0200
opsi-setup-detector (4.2.1.16-1) stable; urgency=low
* Fix: Hint Configuration service url
* Fix: Templates: missing variable: $installerSourceDir$ in multi/declarations.opiinc
* Fix: Templates: delincmsi*: $DisplayNameRegex$: escape all regex relevant chars with '\' : '()'
* Fix: opsisetupdetector.de.po: hint for configuration service_url
* Fix: Make 'MSI Name' editable because it will become the DisplayName
* osdform FlowPanelMsiId: enabled = true
* osdform FlowPanelMsiId1: enabled = true
* osdform TIEditMsiName1: readonly = false
* osdform TIEditMsiName2: readonly = false
* osdform TIEditMsiId1: readonly = true
* osdform TIEditMsiId1: enabled = false
* osdform TIEditMsiId2: readonly = true
* osdform TIEditMsiId2: enabled = false
* Change: Property: 'Install_from_local_tmpdir' now default = True
* osdbasedata: makeproperties : myprop.boolDefault := True;
* Fix: preparation of dependency editor for meta products
* osdform: BitBtnAddDepClick
-- Detlef Oertel <d.oertel@uib.de> Fri, 10 Mar 2023 : 15:00:00 +0200
opsi-setup-detector (4.2.1.15-1) stable; urgency=low
* New: Checkbox and configuration to switch beteen silent and unattended install mode
* osdbasedata: TSetupFile: boolean property preferSilent
* osdbasedata: TConfiguration: boolean property preferSilent
* osdbasedata: hint for preferSilent
* osdform: setup[0-2]: TICheckBoxS(x)Silent
* osdform: eventhandler for TICheckBoxS(x)Silent: TICheckBoxS1SilentChange
* osdform: links and hints for TICheckBoxS(x)Silent
* osdconfigdlg: hint for preferSilent
* osdanalyzewin, osdanalyzelin: use property preferSilent to set (un)installcommandline
* fix: nogui + singleAnalyzeCreate mode: use radiobutton (from configuration) to decide build mode
* New copy existing libraries '*.opsilib' from cutom channel to clientpath
* osdcreate: createClientFiles; // additional optional files for 'custom'
-- Detlef Oertel <d.oertel@uib.de> Tue, 31 Jan 2023 : 15:00:00 +0200
opsi-script (4.12.8.0) urgency=medium
Fixes:
removeFromListByContaining: Correct removing of the last element from the list.
TOML files: Fix that all boolean values are lower case after modifications to match TOML syntax.
Actions section: Log an error if an actions section is expected but not found.
New:
General:
High DPI support for BatchGUI.
opsi-script for aarch64 (raspi 64 bit). EXPERIMENTAL!
Sections:
Primary sections: New script statement 'setdebug_lib' to set/change the config opsi-script.global.debug_lib within your script.
LinkFolder: delete_subfolder, better error reporting on non win32 systems.
-- j.werner <j.werner@uib.de> 17 March 2023
opsi-script-test (4.12.8.0-3) urgency=low
Fixes:
correct syntax errors in opsiServiceCalls.opsiscript and import_regeditformat.opsiscript
QWord_regedit_format.reg: in regedit format only hexdecimal values are allowed and only without any prefix
TOML: booleans must be lowercase
New:
test in stringlist.opsiscript:
search with string list variable containing search criteria (1, line 1) which match entries twice (line 1, line 10 )
-- jan werner <j.werner@uib.de> Tue, 07 Feb 2023
opsi-configed (4.2.20.13) EXPERIMENTAL; urgency=medium
* bugfix: Requesting session-info works now
-- n.otto <n.otto@uib.de> Wed, 29. Mar 2023 16:14:15 +0100
opsi-configed (4.2.20.12) EXPERIMENTAL; urgency=medium
* small bugfix (removed unnecessary logging-call)
-- n.otto <n.otto@uib.de> Wed, 14. Mar 2023 18:14:15 +0100
opsi-configed (4.2.20.11) EXPERIMENTAL; urgency=medium
* bugfix in licensinginfomap: works now also with users that are not opsiadmin
-- n.otto <n.otto@uib.de> Wed, 10. Mar 2023 18:14:15 +0100
opsi-configed (4.2.20.10) EXPERIMENTAL; urgency=medium
* changing loglevel colors, adapting to opsi-standards and in logpanel adapting to white background
* bugfix in "show only selected products"
-- n.otto <n.otto@uib.de> Wed, 7. Mar 2023 18:14:15 +0100
opsi-configed (4.2.20.9) EXPERIMENTAL; urgency=medium
* bugfix with option sshConnectOnStart
-- n.otto <n.otto@uib.de> Wed, 3. Mar 2023 18:14:15 +0100
opsi-configed (4.2.20.8) EXPERIMENTAL; urgency=medium
* sort remote control commands alphabetically
* center filechooser on main frame
* Bugfix: Will now keep selected clients on reload
-- n.otto <n.otto@uib.de> Wed, 1. Mar 2023 18:14:15 +0100
opsi-configed (4.2.20.7) EXPERIMENTAL; urgency=medium
* loading panel rework activity of elements on loading
-- n.otto <n.otto@uib.de> Tue, 28. Feb 2023 13:14:15 +0100
opsi-configed (4.2.20.6) EXPERIMENTAL; urgency=medium
* some small bugfixes
-- n.otto <n.otto@uib.de> Fri, 24. Feb 2023 13:14:15 +0100
opsi-configed (4.2.20.5) EXPERIMENTAL; urgency=medium
* Performance improvement: Removed all unnecessary calls of config_updateObjects on start and reload
-- n.otto <n.otto@uib.de> Tue, 21. Feb 2023 13:14:15 +0100
opsi-configed (4.2.20.4) EXPERIMENTAL; urgency=medium
* Performance improvement: Less unnecessary calls of config_updateObjects on start and reload
* don't use certificate check before server version opsi 4.2, because it would not work
* other bugfixes in certificate check
* removed option for HTTPS-compression on login-panel because we will encrypt always
opsi-configed (4.2.20.3) EXPERIMENTAL; urgency=medium
* Reworking the login panel to remove the loading frame on login
-- n.otto <n.otto@uib.de> Tue, 14. Feb 2023 13:14:15 +0100
opsi-configed (4.2.20.2) EXPERIMENTAL; urgency=medium
* Warning on button for licensing in main frame
* reworking the location of yes / no / ok ... buttons
* small changes in behaviour in frame for changing configs
-- n.otto <n.otto@uib.de> Thu, 09. Feb 2023 13:14:15 +0100
opsi-configed (4.2.20.1) EXPERIMENTAL; urgency=medium
* Reworking Loading Panel on login
* Check server TLS certficate / warn if new cert (ssh-like)
* Reworking positions and sizes of windows
* sizes of columns now will not change on reload (clientlist, Localboot products and Netboot products)
* IPv6-support in input dialogs
* new options for resetting products
* some performance boosts
* JavaFX now used to start Browser in Markdown (works better under Linux)
* Tooltip in Markdown over Links
* Small changes in Dependencies-Infos
* Bugfixes in Clientsearch
-- n.otto <n.otto@uib.de> Mon, 23. Jan 2023 13:14:15 +0100
opsi-client-agent (4.2.0.50-1) stable; urgency=low
* Update opsiclientd to 4.2.0.140
-- Jan Schneider <j.schneider@uib.de> Thu, 30 Mar 2023 07:00:00 +0100
opsi-client-agent (4.2.0.49-1) stable; urgency=low
* Update opsiclientd to 4.2.0.139
* Update opsi-deploy-client-agent to 4.3.0.0
-- Jan Schneider <j.schneider@uib.de> Thu, 23 Mar 2023 23:50:00 +0100
opsi-client-agent (4.2.0.48-1) stable; urgency=low
* Update opsiclientd to 4.2.0.138
* Use two binary dirs and a junction for opsiclientd update
-- Jan Schneider <j.schneider@uib.de> Wed, 22 Mar 2023 08:30:00 +0100
opsi-client-agent (4.2.0.47-1) stable; urgency=low
* Update opsiclientd to 4.2.0.137
-- Nils Doerrer <n.doerrer@uib.de> Thu, 09 Mar 2023 17:30:00 +0100
opsi-client-agent (4.2.0.46-1) stable; urgency=low
* Update opsiclientd to 4.2.0.136
* Use DEPOT_ID from env
-- Jan Schneider <j.schneider@uib.de> Fri, 22 Feb 2023 15:30:00 +0100
opsi-client-agent (4.2.0.45-1) stable; urgency=low
* Rework installation for newer netboot products
* Update opsiclientd to 4.2.0.134
-- Nils Doerrer <n.doerrer@uib.de> Mon, 03 Feb 2023 12:55:00 +0100
opsi-linux-bootimage (20230314-1) testing; urgency=low
* kernel 6.2.6
* updated binaries
-- Mathias Radtke <m.radtke@uib.de> Tue, Mar 14 2023 08:45:00 +0100
win2022 (4.2.0.3-7) testing; urgency=low
*typo
opsiconfd (4.2.0.306-1) stable; urgency=medium
* Improvement: New configed links
-- uib GmbH <info@uib.de> Sat, 11 Mar 2023 09:35:54 +0100
opsiconfd (4.2.0.305-1) stable; urgency=medium
* Bugfix: Fix change terminal font size
-- uib GmbH <info@uib.de> Wed, 01 Mar 2023 20:56:54 +0100
opsiconfd (4.2.0.304-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Thu, 02 Feb 2023 18:21:05 +0000
opsiconfd (4.2.0.303-1) stable; urgency=medium
* Feature: health-check --upgrade-check
* Feature: Add upgrade issues to health check
-- uib GmbH <info@uib.de> Thu, 26 Jan 2023 10:34:13 +0000
opsiconfd (4.2.0.302-1) stable; urgency=medium
* Improvement: Rework health-check data structures for opsi-cli table
-- uib GmbH <info@uib.de> Mon, 23 Jan 2023 22:00:58 +0000
opsiconfd (4.2.0.301-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 23 Jan 2023 11:01:06 +0000
opsiconfd (4.2.0.300-1) stable; urgency=medium
* Bugfix: Fix backend_getInterface
-- uib GmbH <info@uib.de> Sat, 21 Jan 2023 10:10:00 +0000
opsi-utils (4.2.0.199-1) stable; urgency=medium
* Improvement: change opsi-sever.repo autoUpdate/install to false
-- uib GmbH <info@uib.de> Tue, 28 Mar 2023 15:46:42 +0200
opsi-utils (4.2.0.198-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Tue, 28 Mar 2023 09:04:48 +0000
opsi-utils (4.2.0.197-1) stable; urgency=medium
* Improvement: Use repositoryRemoteUrl for depot connection
* Improvement: updated python-opsi to 4.2.0.320
-- uib GmbH <info@uib.de> Thu, 23 Mar 2023 19:09:52 +0100
opsi-utils (4.2.0.196-1) stable; urgency=medium
* Improvement: updated opsi-cli to 4.2.0.4
-- uib GmbH <info@uib.de> Thu, 22 Dec 2022 13:04:46 +0100
opsi-utils (4.2.0.195-1) stable; urgency=medium
* No public changes
-- uib GmbH <info@uib.de> Tue, 20 Dec 2022 14:17:41 +0100
opsi-utils (4.2.0.194-1) stable; urgency=medium
* Improvement: updated opsi-cli to 4.2.0.3, incremented version to 4.2.0.194
-- uib GmbH <info@uib.de> Wed, 14 Dec 2022 08:52:58 +0100
opsi-utils (4.2.0.193-1) stable; urgency=medium
* Feature: implemented support for control files in toml format
-- uib GmbH <info@uib.de> Fri, 09 Dec 2022 13:31:49 +0000
opsi-utils (4.2.0.192-1) stable; urgency=medium
* Improvement: updated opsi-cli to 4.2.0.1
-- uib GmbH <info@uib.de> Thu, 17 Nov 2022 14:25:52 +0100
opsi-utils (4.2.0.191-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Fri, 11 Nov 2022 13:30:24 +0100
opsi-utils (4.2.0.190-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Thu, 03 Nov 2022 11:34:15 +0100
