Updates 4.2 stable and testing
Verfasst: 21 Dez 2022, 10:43
Dear opsi users,
today we have released more packages for opsi 4.2 in testing and stable.
The new opsi-setup-detector hereby published in testing, has a bundle of interesting new features:
* Integration of 'install with logged on user'
* Reworked Templates
* Choice between different 'Template Channels'
* Use of the opsi-webservice in order to buld and install opsipackages
* Optional code additions dor special use cases:
* Support of a custom directory
* Install from a local, temporary directory
* Handle licenskeys
* DesktopIcon
* Customize Profile
You will find a detailed documentation here:
https://docs.opsi.org/opsi-docs-en/4.2/ ... si-package
opsi-script 4.12.7.4 (Windows, Linux and MacOS) now allows you to submit your scripts to a syntax check. Furthermore, version 4.12.7.4 contains some bug fixes, especially for registry handling regarding hexdeciaml values and the regedit export format (Windows).
More information can be found in the changelogs and in the respective manuals.
In opsiconfd 4.2.0.298 we fixed a bug in the webdav file browser at the admin page.
Additionally it can handle a new parameter allow_host_key_only_auth. This parameter can be set in the opsiconfd.conf to allow renamed clients to still be authenticated (via opsi-host-key). With opsi-client-agent 4.2.0.43-3, opsi-linux-client-agent 4.2.0.31-1 and opsi-mac-client-agent 4.2.0.23-1 clients authenticated this way automatically assume the new host-Id. This mechanic can be used to rename clients.
New Packages in Testing:
windows localboot:
* opsi-setup-detector 4.2.1.12-1
* opsi-client-agent 4.2.0.43-3
* opsi-script 4.12.7.4-3
* opsi-winst 4.12.7.4-3
* opsi-cli 4.2.0.3-1
Linux localboot:
Macos Localboot:
opsi-local-image Netboot:
* opsi-vhd-win10-x64 4.2.0.3-7
* opsi-vhd-win11-x64 4.2.0.3-7
New Packages in Stable:
Windows Localboot:
Linux Localboot:
* opsi-linux-client-agent 4.2.0.31-1
Macos Localboot:
* opsi-mac-client-agent 4.2.0.23-1
opsi-local-image Localboot:
* opsi-vhd-control 4.2.0.4-1
Server:
* opsi-directory-connector 48.1
* opsiconfd 4.2.0.298
I wish you all a merry Christmas and good start with 2023.
Best regards,
Nils Dörrer
Changelogs:
* Handle licenskeys
* DesktopIcon
* Customize Profile
windows localboot:
Linux localboot:
Macos Localboot:
Windows Localboot:
Linux Localboot:
Macos Localboot:
Server:
Best regards,
Nils Dörrer
Changelogs:
vhd-windows (4.2.0.3-7) testing; urgency=low
* nt6.opsiscript: Do not hide vhd container partition in uefi: gptAttribute = 0
* nt6.opsiscript: failed try: get driver information via wmi from Win32_PnPEntity
-- detlef oertel <d.oertel@uib.de> Mon, 05 Dec 2022 15:00:00 +0200
opsi-setup-detector (4.2.1.12-1) stable; urgency=low
* template fixes for 'with user': avoid isFatlError while local install
* osdcreate: add 'DefVar $LicenseError$' on property 'SecretLicense_or_Pool'
* osdform: BtCreateProductClick: reset exitcode before (repeated) build
* osdform: Typo Desktopicon
* uninstallProg now holds the complete, absolut path
* osbasedata: TSetupFile: uninstallProg, TargetProg, installDirectory should not be quoted
use SetUninstallProg, SetTargetProg, SetInstallDirectory to write property
* osdform: setup(1-3): hints for uninstallProg, TargetProg, installDirectory
* new translation files (de/en)
-- Detlef Oertel <d.oertel@uib.de> Fri, 09 Dec 2022 : 15:00:00 +0200
opsi-setup-detector (4.2.1.11-1) stable; urgency=low
* template fixes for 'with user': using new msi del style
* osdcreate: createClientFiles: with user:
support msi variant for del
-- Detlef Oertel <d.oertel@uib.de> Mon, 05 Dec 2022 : 15:00:00 +0200
opsi-vhd-control (4.2.0.4-1) stable; urgency=low
* uib_bootutils : new: hidePartition2, noAutomountPartition
* setup.opsiscript: fixes for MBR BIOS
* fix fouble declaration of $list§
-- detlef oertel <d.oertel@uib.de> Tue, 29 Nov 2022 15:00:00 +0000
opsi-client-agent (4.2.0.43-3) stable; urgency=low
* Rebuilt opsi-notifier with proper meta information ahd sha256 hash in signature
* Rebuilt opsi-systray with proper meta information ahd sha256 hash in signature
-- Nils Doerrer <n.doerrer@uib.de> Mon, 05 Dec 2022 17:00:00 +0100
opsi-client-agent (4.2.0.43-2) stable; urgency=low
* Rebuilt opsiclientd with proper meta information ahd sha256 hash in signature
* Rebuilt oca-installation-helper with proper meta information ahd sha256 hash in signature
-- Nils Doerrer <n.doerrer@uib.de> Thu, 01 Dec 2022 10:30:00 +0100
opsi-client-agent (4.2.0.43-1) stable; urgency=low
* Update opsiclientd to 4.2.0.132 (win11 mshotfix caching, blocking runAsOpsiSetupUser)
* Update opsi-deploy-client-agent to 4.2.0.23 (fixed --use-ip-address)
* Update oca-installation-helper to 4.2.0.24 (create host groups if not existing, delete WAN cache on install)
-- Nils Doerrer <n.doerrer@uib.de> Thu, 24 Nov 2022 17:30:00 +0100
opsi-linux-client-agent (4.2.0.31-1) stable; urgency=low
-- Nils Doerrer <n.doerrer@uib.de> Fri, 25 Nov 2022 18:00:00 +0100
opsi-mac-client-agent (4.2.0.23-1) stable; urgency=low
opsi-directory-connector (48.1-1) stable; urgency=medium
* Feature: Stop synchronisation when the client limit is reached
* Bugfix: fix default log file
-- uib GmbH <info@uib.de> Wed, 24 Aug 2022 15:26:17 +0200
opsi-directory-connector (48.0-1) stable; urgency=medium
* Improvement: use new license check
-- uib GmbH <info@uib.de> Thu, 17 Feb 2022 13:24:16 +0000
opsiconfd (4.2.0.298-1) stable; urgency=medium
* Bugfix: webdav dir browser
-- uib GmbH <info@uib.de> Wed, 14 Dec 2022 11:03:06 +0000
opsiconfd (4.2.0.297-1) stable; urgency=medium
* Improvement: updated python-opsi to 4.2.0.318 to allow control files in toml format
-- uib GmbH <info@uib.de> Fri, 09 Dec 2022 13:30:27 +0000
opsi-script (4.12.7.4-3) urgency=medium
Fix:
registry exportformat: hexdecimal values are now handled correctly
-- j.werner <j.werner@uib.de> 14 December 2022
opsi-script (4.12.7.3-3) urgency=medium
Fix:
- registry exportformat: hexdecimal values with letters throw no syntax errors anymore
- lib: uib_macosinstalllib.opsiscript: fixes whitespace handling in deffunc install_macos_app($myapp$ : string) : string
opsi-script (4.12.7.2-3) urgency=medium
New:
Parser [W/L/M]:
- Syntax Check: if testsyntax is set (via config or opsi-script-gui -> Button Test Syntax)
only the syntax of the script is tested. The script is not excecuted.
Fixes:
Parser [W/L/M]:
- fix in OpsiServiceCall section
xml2 [W]:
- attribute sequence
- makeNodePathWithTextContent:
- additional parameter for strictmode
- use strictmode parameter for node creation
LinkFolder [W/L/M]:
- In DeleteShellLink use GetSpecialFolderPath instead of hard-coded path to handle all kinds of base folders
-- j.werner <j.werner@uib.de> 05 Dec 2022
opsi-cli (4.2.0.3-1) stable; urgency=medium
* Bugfix: fixed uninstall-where-only-uninstall
* Feature: added self show-structure command
* Feature: added messagebus terminal command
* Improvement: added messagebus command
-- uib GmbH <info@uib.de> Tue, 13 Dec 2022 17:21:26 +0100
