Updates for opsi 4.2 in testing and stable
Verfasst: 07 Sep 2022, 13:27
Dear opsi users,
with this release we have published new packages for opsi 4.2 in testing and stable.
* The new opsi-linux-bootimage contains a new SHIM file,
which reenable the secure boot functionality on computers with topical firmware
and on machines that got the Microsoft Secureboot DBX Update from 12.8.2022.
In order to be sure to provide the secure boot functionality, this new bootimageis published in testing and stable.
* With new netboot products in stable we provide the possibility to install the following Linux Distributions:
mint21, Alma9/Rocky9/Redhat9 und SLES15-4, opensusel15-4
* Using the testing repository, the opsi-server might now installed on:
* The new opsi-client-agent in testing provides a new notifier with a better handling of high dpi monitors and scaling
* The new opsipxeconfd in testing contains a fundamental change:
The boot configurations are no longer created as named pipes but as normal files.
Thus the configuration files can be read by all programs without having to use specially adapted versions.
The boot configurations created by opsipxeconfd are automatically removed after they are read.
The created boot configurations are also automatically removed when opsipxeconfd is stopped and will be recreated after a restart.
* The macOS product: m-xcode-tools_13.4-1 is needed for the installation on the upcomming macOS release 13 (Ventura).
New packages in Testing:
Windows Localboot:
* opsi-client-agent 4.2.0.40-1
* opsi-wim-capture 4.2.0.2-1
* opsi-script-beautifier_4.2.0.3-1
* opsi-auto-update_4.2.0.2-1
opsi-local-image Localboot:
* opsi-local-image-wim-capture 4.2.0.2-1
Linux Localboot:
macOS Localboot:
* m-xcode-tools_13.4-1
Windows Netboot:
* windows_nt6 4.2.0.3-3
opsi-local-image Netboot:
* opsi-local-image-backup 4.2.0.1-2
* opsi-local-image-delimage 4.2.0.1-1
* opsi-local-image-prepare 4.2.0.0-2
* opsi-local-image-restore 4.2.0.4-2
* opsi-local-image-ubuntu 4.2.0.4-5
Linux Netboot:
* alma8 4.2.0.3-4
* alma9 4.2.0.3-4
* debian9 4.2.0.1-11
* debian10 4.2.0.1-11
* debian11 4.2.0.1-11
* debian 4.2.0.3-7
* mint20-1 4.2.0.3-2
* mint20-2 4.2.0.3-2
* mint20-3 4.2.0.3-2
* mint21 4.2.0.3-2
* opensusel15-3 4.2.0.2-4
* opensusel15-4 4.2.0.2-4
* redhat8 4.2.0.3-4
* redhat9 4.2.0.3-4
* rocky8 4.2.0.3-4
* rocky9 4.2.0.3-4
* sles12sp3 4.2.0.2-3
* sles12sp4 4.2.0.2-3
* sles12sp5 4.2.0.2-3
* sles15-1 4.2.0.2-3
* sles15-2 4.2.0.2-3
* sles15-3 4.2.0.2-3
* sles15-4 4.2.0.2-3
* ubuntu 4.2.0.4-5
* ubuntu18-04 4.2.0.1-11
* ubuntu20-04 4.2.0.1-11
* ubuntu22-04 4.2.0.1-11
* ucs44 4.2.0.1-7
* ucs50 4.2.0.1-9
Server:
* opsi-linux-bootimage (20220905-1)
* opsiconfd (4.2.0.286-1)
* opsipxeconfd (4.2.0.31-1)
* opsi-directory-connector (47.8-1)
misc:
* opsi-quickinstall (4.2.0.8-1)
https://download.uib.de/opsi4.2/testing/quickinstall/
New packages in Stable:
Windows Localboot:
* hwaudit 4.2.0.1-1
* windows10-enablement 21h2-2
* opsi-vhd-control 4.2.0.3-1
Linux Localboot:
* hwaudit 4.2.0.1-1
* opsi-linux-client-agent 4.2.0.28-1
Macos Localboot:
* hwaudit 4.2.0.1-1
* opsi-mac-client-agent 4.2.0.20-1
Windows Netboot:
* windows_nt6 4.2.0.3-2
Linux Netboot:
* alma9 4.2.0.3-3
* debian 4.2.0.3-5
* mint20-1 4.2.0.3-1
* mint20-2 4.2.0.3-1
* mint20-3 4.2.0.3-1
* mint21 4.2.0.3-1
* opensusel15-3 4.2.0.2-3
* opensusel15-4 4.2.0.2-3
* redhat9 4.2.0.3-3
* rocky9 4.2.0.3-3
* sles15-4 4.2.0.2-2
* ubuntu 4.2.0.4-4
opsi Server:
* opsiconfd (4.2.0.285-1)
* opsi-windows-support (4.2.0.3-1)
misc:
nothing
with kind regards
detlef oertel
Die Changelogs:
Windows Localboot:
Linux Localboot:
macOS Localboot:
Windows Netboot:
Linux Netboot:
* alma8 4.2.0.3-4
* alma9 4.2.0.3-4
* debian 4.2.0.3-7
* mint21 4.2.0.3-2
* redhat8 4.2.0.3-4
* redhat9 4.2.0.3-4
* rocky8 4.2.0.3-4
* rocky9 4.2.0.3-4
* ubuntu 4.2.0.4-5
* ucs44 4.2.0.1-7
* ucs50 4.2.0.1-9
Server:
misc:
Windows Localboot:
* hwaudit 4.2.0.1-1
Linux Localboot:
* hwaudit 4.2.0.1-1
Macos Localboot:
* hwaudit 4.2.0.1-1
Windows Netboot:
Linux Netboot:
* alma9 4.2.0.3-3
* debian 4.2.0.3-5
* mint21 4.2.0.3-1
* redhat9 4.2.0.3-3
* rocky9 4.2.0.3-3
* ubuntu 4.2.0.4-4
opsi Server:
misc:
nothing
with kind regards
detlef oertel
Die Changelogs:
windows10-enablement (21h2-2) stable; urgency=medium
* Added comparison of the current build number with the required build number
* The upgrade will fail if the required build number is not met
* The required hotfixes for the current ReleaseID will be displayed
* Tested on win10-1903, win10-x64-1903, win10-2004, win10-x64-2004, win10-20h2, win10-x64-20h2, win10-21h1, win10-x64-21h1
-- Matthias Knauer <m.knauer@uib.de> Thu, 28 Jul 2022 11:11:11
opsi-script-beautifier (4.2.0.3-1)
* accept *.opsiinc as opsi-script extension
* add opsi-logo to the package
-- d.oertel <d.oertel@uib.de> Mon , 08 Aug 2022 15:00:00 + 0100
opsi-auto-update (4.2.0.2-1) stable; urgency=low
* use: reloadProductList / isSuspended
instead of ImmediateReboot
if possible
* remove 'DefFunc setProductsToUninstall' (now in lib uib_backend)
* fix comment line at WAN mode
-- detlef oertel <d.oertel@uib.de> Fri, 22 Jul 2022 15:00:00 +0200
opsi-linux-bootimage (20220905-1) testing; urgency=low
* updated shimx64.efi.signed
* renamed grubx64.efi to opsi-netboot.efi
-- Mathias Radtke <m.radtke@uib.de> Mon, Sep 05 2022 12:45:00 +0200
l-debuntu-upgrade (4.2.0.2-1) stable; urgency=low
* focal to jammy upgrade added
-- Mathias Radtke <m.radtke@uib.de> Wed, 04 May 2022 09:30:00 +0200
opsi-local-image (4.2.0.4-5) testing; urgency=low
* fix in opsisetuplib
in checkModules(modules2check)
* uses backend_getLicensingInfo()
in removeFromUefiBootOrder(label)
and removeFromUefiBootNext(label)
* initialize labelID
* handle empty labelID
-- detlef oertel <d.oertel@uib.de> Thu, 25 Aug 2022 15:00:00 +0200
windows_nt6 (4.2.0.3-3) testing; urgency=low
windows_nt6 (4.2.0.3-2) testing; urgency=low
* updated create_driver_links and show_drivers to not use deprecated logger calls
-- Mathias Radtke <m.radtke@uib.de> Tue Aug 9 15:35:47 2022 +0200
opsi-local-image-windows_nt6 (4.2.0.3-3) testing; urgency=low
opsi-local-image-windows_nt6 (4.2.0.3-2) testing; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Tue Aug 9 15:36:02 2022 +0200
alma8/9 (4.2.0.3-4) testing; urgency=low
alma8/9 (4.2.0.3-3) testing; urgency=low
* updated grubx64.efi
-- Mathias Radtke <m.radtke@uib.de> Wed May 25 09:02:13 2022 +0200
debian (4.2.0.3-7) testing; urgency=low
debian (4.2.0.3-6) testing; urgency=low
* corrected syntax error
-- Mathias Radtke <m.radtke@uib.de> Tue, Aug 23 08:45:00 2022 +0200
debian (4.2.0.3-5) testing; urgency=low
* corrected usage of debian security repo when using bullseye as release
-- Mathias Radtke <m.radtke@uib.de> Tue Aug 02 12:19:00 2022 +0200
debian (4.2.0.3-4) testing; urgency=low
* not setting actionprogress anymore
-- Mathias Radtke <m.radtke@uib.de> Wed May 18 16:02:13 2022 +0200
debian9/10/11 (4.2.0.1-11) testing; urgency=low
debian9/10/11 (4.2.0.1-10) testing; urgency=low
debian9/10/11 (4.2.0.1-9) testing; urgency=low
mint20-1/2/3 (4.2.0.3-2) testing; urgency=low
mint20-1/2/3 (4.2.0.3-1) testing; urgency=low
* added new property: use_nonfree
-- Mathias Radtke <m.radtke@uib.de> Fri Aug 05 08:20:00 2022 +0200
mint20-1/2/3 (4.2.0.2-3) testing; urgency=low
* RAM check as we need 4GB or RAM
mint21 (4.2.0.3-2) testing; urgency=low
mint21 (4.2.0.3-1) testing; urgency=low
opensusel15-3/4 (4.2.0.2-4) testing; urgency=low
opensusel15-3/4 (4.2.0.2-3) testing; urgency=low
opensusel15-3/4 (4.2.0.2-2) testing; urgency=low
sles12sp3/4/5 (4.2.0.2-3) testing; urgency=low
sles12sp3/4/5 (4.2.0.2-2) testing; urgency=low
sles15-1/2/3/4 (4.2.0.2-3) testing; urgency=low
sles15-1/2/3/4 (4.2.0.2-2) testing; urgency=low
redhat8/9 (4.2.0.3-4) testing; urgency=low
redhat8/9 (4.2.0.3-3) testing; urgency=low
redhat8/9 (4.2.0.3-2) testing; urgency=low
rocky8/9 (4.2.0.3-4) testing; urgency=low
rocky8/9 (4.2.0.3-3) testing; urgency=low
rocky8/9 (4.2.0.3-2) testing; urgency=low
ubuntu (4.2.0.4-5) testing; urgency=low
ubuntu (4.2.0.4-4) testing; urgency=low
* not adding archive.canonical.com as sources.list entry
-- Mathias Radtke <m.radtke@uib.de> Fri Jun 24 12:15:00 2022 +0200
ubuntu (4.2.0.4-3) testing; urgency=low
ubuntu18-04(20-04/22-04 (4.2.0.1-11) testing; urgency=low
ubuntu18-04/20-04/22-04 (4.2.0.1-10) testing; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Wed May 25 10:02:13 2022 +0200
ubuntu18-04/20-04/22-04 (4.2.0.1-9) testing; urgency=low
ucs44 (4.2.0.1-7) testing; urgency=low
ucs44 (4.2.0.1-6) testing; urgency=low
ucs50 (4.2.0.1-9) testing; urgency=low
ucs50 (4.2.0.1-8) testing; urgency=low
opsi-quickinstall (4.2.0.8-1) experimental; urgency=low
* new: AlmaLinux 9, Rocky 9 and RHEL 9 added to supported distributions
* change: Download opsi-script now directly from download.opensuse.org as tar.gz and delete it again after the installation
(the way before was to add a repository from download.opensuse.org and install opsi-script on the system)
* fix gui: Use root rights in all parts of OpsiPackageDownloader so that downloading the latest l-opsi-server works correctly
-- Anja-Melanie Schmitz <a.schmitz@uib.de> Fri, 26 Aug 2022 12:30
opsi-local-image-backup (4.2.0.1-2) testing; urgency=low
opsi-local-image-delimage (4.2.0.1-1) testing; urgency=low
opsi-local-image-prepare (4.2.0.0-2) testing; urgency=low
opsi-local-image-restore (4.2.0.4-2) stable; urgency=low
opsi-local-image-ubuntu (4.2.0.4-5) testing; urgency=low
opsi-local-image-ubuntu (4.2.0.4-4) stable; urgency=low
* try use with jammy (22.04)
* based on ubuntu (4.2.0.4-4)
-- detlef oertel <d.oertel@uib.de> Thu, 18 Aug 2022 15:00:00 +0200
opsi-directory-connector (48.1-1) stable; urgency=medium
* Feature: Stop synchronisation when the client limit is reached
* Bugfix: fix default log file
-- uib GmbH <info@uib.de> Wed, 24 Aug 2022 15:26:17 +0200
opsi-directory-connector (48.0-1) stable; urgency=medium
* Improvement: use new license check
-- uib GmbH <info@uib.de> Thu, 17 Feb 2022 13:24:16 +0000
opsipxeconfd (4.2.0.31-1) stable; urgency=medium
* Use boot config files instead of pipes
-- uib GmbH <info@uib.de> Thu, 25 Aug 2022 09:14:55 +0200
opsiconfd (4.2.0.286-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 05 Sep 2022 11:45:17 +0000
opsiconfd (4.2.0.285-1) stable; urgency=medium
* Bugfix: Fix admin interface logout button
* Bugfix: updated opsicommon to 4.2.0.293 - fixed jsonrpc cleanup
-- uib GmbH <info@uib.de> Wed, 17 Aug 2022 21:50:18 +0200
opsi-vhd-control (4.2.0.3-1) stable; urgency=low
* fixes for win10
* winpetask : use $snapshotDriveLetter$ (T)
* update "check module activation"
; the combination win11 and not uefi is not possible
; on win11 we have to use powershell (diskpart is not possible)
; and powershell has no way to get a mbr disk guid
-- detlef oertel <d.oertel@uib.de> Mon, 1 Aug 2022 15:00:00 +0000
hwaudit (4.2.0.1-1) stable; urgency=low
* updated python packages, fixed device discovery for linux
-- Nils Doerrer <n.doerrer@uib.de> Tue, 09 Aug 2022 12:00:00 +0100
opsi-wim-capture (4.2.0.2-1) stable; urgency=low
* setup.opsiscript: check modules via uib_backend.opsiscript:check_moduls_activation
-- detlef oertel <d.oertel@uib.de> Tue, 22 Aug 2022 15:00:00 +0000
m-xcode-tools 13.4-1 stable urgency=low
* Updated to Comamnd Line Tools 13.4
* if macos > 12 use 14_beta_5
* macosinstalllib removed (is part of opsi-script)
-- d.oertel <d.oertel@uib.de> Mon, 22 Aug 2022 15:00:00 + 0100
opsi-client-agent (4.2.0.40-1) stable; urgency=low
* Updated opsi-notifier to 4.2.0.10 (block-login-notifier fix)
* Updated opsiclientd to 4.2.0.129 (clear_product_cache datastructure cleanup)
-- Nils Doerrer <n.doerrer@uib.de> Tue, 30 Aug 2022 17:00:00 +0100
opsi-linux-client-agent (4.2.0.28-1) stable; urgency=low
* Updated opsiclientd to 4.2.0.128 (fixed colliding startup event handling, fixed handling of opsiclientd.depot_server.url)
-- Nils Doerrer <n.doerrer@uib.de> Mon, 15 Aug 2022 16:00:00 +0100
opsi-mac-client-agent (4.2.0.20-1) stable; urgency=low
* Improved uninstallation
