efibootmgr streikt auf HP ProBook 450 G9
kinzi
Beitrag von kinzi »
Hello,
wir haben brandneue HP ProBook 450 G9 in zwei verschiedenen Varianten:
  • P/N 4D3W9AV (CPU: 12th Gen Intel(R) Core(TM) i3-1215U)
  • P/N 674N0AV (CPU: 12th Gen Intel(R) Core(TM) i5-1235U)
Die i3-Varianten installieren win10-x64 einwandfrei, bei den i5-Varianten kommt es zu einem Fehler bereits im Boot-Image, wenn die PE-Partition dem Boot-Menü hinzugefüt werden soll, siehe:
(11384)   [6] [2022-07-22 13:52:17.437] [               ] Executing: /bin/efibootmgr -v   (Posix.py:980)
(11385)   [6] [2022-07-22 13:52:17.438] [               ] Using encoding 'UTF-8'   (Posix.py:1007)
(11386)   [7] [2022-07-22 13:52:18.596] [               ] >>> BootCurrent: 0001   (Posix.py:1053)
(11387)   [7] [2022-07-22 13:52:18.596] [               ] >>> Timeout: 0 seconds   (Posix.py:1053)
(11388)   [7] [2022-07-22 13:52:18.596] [               ] >>> BootOrder: 0001,0000,0003,0004,0005,0002   (Posix.py:1053)
(11389)   [7] [2022-07-22 13:52:18.596] [               ] >>> Boot0000* SAMSUNG MZVLQ256HBJD-00BH1-S672NS0T562680	PciRoot(0x0)/Pci(0x6,0x2)/Pci(0x0,0x0)/NVMe(0x1,00-25-38-D5-21-44-FE-D0)N.....YM....R,Y.....ISPH   (Posix.py:1053)
(11390)   [7] [2022-07-22 13:52:18.596] [               ] >>> Boot0001* IPV4 Network - Realtek PCIe GBE Family Controller	PciRoot(0x0)/Pci(0x1c,0x7)/Pci(0x0,0x0)/MAC(5c60ba5fdd74,0)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y.....ISPH   (Posix.py:1053)
(11391)   [7] [2022-07-22 13:52:18.597] [               ] >>> Boot0002* IPV6 Network - Realtek PCIe GBE Family Controller	PciRoot(0x0)/Pci(0x1c,0x7)/Pci(0x0,0x0)/MAC(5c60ba5fdd74,0)/IPv6([::]:<->[::]:,0,0)N.....YM....R,Y.....ISPH   (Posix.py:1053)
(11392)   [7] [2022-07-22 13:52:18.597] [               ] >>> Boot0003  USB:  	PciRoot(0x0)/Pci(0x14,0x0)N.....YM....R,Y.....ISPH   (Posix.py:1053)
(11393)   [7] [2022-07-22 13:52:18.597] [               ] >>> Boot0004  USB NETWORK BOOT:  	PciRoot(0x0)/Pci(0x0,0x0)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y.....ISPH   (Posix.py:1053)
(11394)   [7] [2022-07-22 13:52:18.597] [               ] >>> Boot0005  USB NETWORK BOOT:  	PciRoot(0x0)/Pci(0x0,0x0)/IPv6([::]:<->[::]:,0,0)N.....YM....R,Y.....ISPH   (Posix.py:1053)
(11395)   [7] [2022-07-22 13:52:18.597] [               ] >>>    (Posix.py:1053)
(11396)   [7] [2022-07-22 13:52:18.597] [               ] Exit code: 0   (Posix.py:1060)
(11397)   [5] [2022-07-22 13:52:18.597] [               ] setting winpe to the top of winpe boot order   (setup.py:1790)
(11398)   [7] [2022-07-22 13:52:18.597] [               ] Removing LD_LIBRARY_PATH from env for subprocess   (Posix.py:893)
(11399)   [6] [2022-07-22 13:52:18.597] [               ] Executing: /bin/efibootmgr -c --disk /dev/nvme0n1 --part 5 -L opsitempwinpe --loader \\EFI\\boot\\bootx64.efi   (Posix.py:980)
(11400)   [6] [2022-07-22 13:52:18.598] [               ] Using encoding 'UTF-8'   (Posix.py:1007)
(11401)   [7] [2022-07-22 13:52:19.444] [               ] >>> Could not prepare Boot variable: Invalid argument   (Posix.py:1053)
(11402)   [7] [2022-07-22 13:52:19.444] [               ] >>>    (Posix.py:1053)
(11403)   [7] [2022-07-22 13:52:19.444] [               ] Exit code: 5   (Posix.py:1060)
(11404)   [2] [2022-07-22 13:52:20.448] [               ] Command '/bin/efibootmgr -c --disk /dev/nvme0n1 --part 5 -L opsitempwinpe --loader \\EFI\\boot\\bootx64.efi' failed (5):
(11405)   Could not prepare Boot variable: Invalid argument
(11406)      (Logger.py:344)
(11407)   Traceback (most recent call last):
(11408)     File "run-master", line 1683, in <module>
(11409)     File "/tmp/setup.py", line 1806, in <module>
(11410)       execute('/bin/efibootmgr -c --disk %s --part %s -L opsitempwinpe --loader \\\\EFI\\\\boot\\\\bootx64.efi' % (disk.device, winpePartitionNumber))
(11411)     File "OPSI/System/Posix.py", line 1068, in execute
(11412)   RuntimeError: Command '/bin/efibootmgr -c --disk /dev/nvme0n1 --part 5 -L opsitempwinpe --loader \\EFI\\boot\\bootx64.efi' failed (5):
(11413)   Could not prepare Boot variable: Invalid argument
(11414)
(11415)   [7] [2022-07-22 13:52:20.449] [               ] Backend: <JSONRPCBackend()>   (run-master:1738)
(11416)   [7] [2022-07-22 13:52:20.449] [               ] ProductId: win10-x64   (run-master:1739)
(11417)   [7] [2022-07-22 13:52:20.449] [               ] ClientId: amt001455.amt.cic.fldk.net   (run-master:1740)
(11418)   [7] [2022-07-22 13:52:20.449] [               ] ProductOnClient: <ProductOnClient(clientId='amt001455.amt.cic.fldk.net', productId='win10-x64', installationStatus='unknown', actionRequest='none')>   (run-master:1741)
(11419)   [6] [2022-07-22 13:52:20.449] [               ] Updating productOnClient: {'targetConfiguration': None, 'installationStatus': 'unknown', 'actionRequest': 'none', 'lastAction': None, 'actionProgress': '', 'actionResult': 'failed', 'productVersion': None, 'packageVersion': None, 'modificationTime': None, 'actionSequence': None, 'productId': 'win10-x64', 'productType': 'NetbootProduct', 'clientId': 'amt001455.amt.cic.fldk.net', 'type': 'ProductOnClient'}   (run-master:1753)
(11420)   [6] [2022-07-22 13:52:20.449] [               ] JSONRPC request to https://10.2.32.51:4447/rpc: ip_version=4, id=25, method=productOnClient_updateObjects, Content-Type=application/msgpack, Content-Encoding=lz4, timeout=(10, 300)   (jsonrpc.py:429)
(11421)   [7] [2022-07-22 13:52:20.450] [               ] Resetting dropped connection: 10.2.32.51   (connectionpool.py:273)
(11422)   [7] [2022-07-22 13:52:20.450] [               ] Using ip version 4   (jsonrpc.py:240)
(11423)   [7] [2022-07-22 13:52:20.473] [               ] https://10.2.32.51:4447 "POST /rpc HTTP/1.1" 200 25   (connectionpool.py:456)
(11424)   [6] [2022-07-22 13:52:20.473] [               ] Got response status=200, Content-Type=application/msgpack, Content-Encoding=, duration=0.024s   (jsonrpc.py:452)
(11425)   [5] [2022-07-22 13:52:20.473] [               ] EXITING   (run-master:1759)
(11426)   [5] [2022-07-22 13:52:20.473] [               ] Writing log to service   (run-master:1765)
OPSI-Linux-Bootimage ist bereits auf Testing aktualisiert (opsi-linux-bootimage_20220617-1_all.deb, 17-Jun-2022 10:30). Die restlichen Pakete sind auf "OPSI 4.2 Stable"-Stand, das Netboot-Produkt ist win10-x64_4.2.0.2-1.
Auffallend ist, dass in der "Hardware-Info" beim i5 keine Sektion "Festplatte" und keine Sektion "SCSI-Controller" zu finden ist. Beim i3 findet sich eine Festplatte ...
Name	SAMSUNG MZVLQ256HBJD-00BH1
Beschreibung	Laufwerk
Hersteller	(Standardlaufwerke)
Modell	SAMSUNG MZVLQ256HBJD-00BH1
Seriennummer	0025_38D5_2145_28C9.
Größe	238.468 GByte
Cylinder	31130
Heads	255
Sektoren	500103450
Partitionen	3
... und ein SCSI-Controller ...
Name	Standardmäßiger NVM Express-Controller
Beschreibung	Standardmäßiger NVM Express-Controller
Hersteller	Standardmäßiger NVM Express-Controller
Gerätetyp	PCI
Hersteller-ID	144D
Geräte-ID	A809
Subsystem-Hersteller-ID	A801
Subsystem-Geräte-ID	144D
Revision	00
Ich habe den "efibootmgr" auch manuell verwendet, er lässt gar keine Operationen (außer -v) zu, auch das Löschen von Booteinträgen quittiert er mit "Invalid Argument", obwohl das NVM-Device im Bootimage durchaus sichtbar ist.
Viellleicht hilft ein neuerer Kernel was?
kinzi
Re: efibootmgr streikt auf HP ProBook 450 G9
hast du zufällig append Parameter "acpi=off" gesetzt?
Fallls ja, entferne ihn und versuche es erneut
kinzi
Beitrag von kinzi »
Hola,
Nicht, dass ich wüsste. Jedenfalls ist
opsi-linux-bootimage.append
leer bzw. nicht gesetzt.
kinzi
kinzi
Beitrag von kinzi »
Ach ja, Platte nullen mit "dd" habe ich natürlich auch schon hinter mir ...
kinzi
Beitrag von kinzi »
Niemand eine Idee?
du könntest versuchen mit den opsi-linux-bootimage.append Parametern acpi=off und/oder noapic zu spielen. Vielleicht lösen sie das Problem auf diesen Maschinen.
kinzi
Beitrag von kinzi »
OK, mache ich mal.
Danke einstweilen.
kinzi
kinzi
Beitrag von kinzi »
also apci=off und noapic bringen nix.
Es sieht so aus, als sähe efibootmgr (Version 17) die EFI-Partition, die vom OPSI-BI angelegt wird, nicht. Ich kann diese Partition aber ganz normal manuell mounten.
Wenn ich im Bootimage auf die Konsole wechsle und manuell "efibootmgr" mit den ganzen Parametern aufrufe, bekomme ich den gleichen Fehler:
Could not prepare Boot variable: invalid argument
Egal, wie viele Parameter ich weglasse. Nur wenn ich nur efibootmgr aufrufe, zeigt dieser schön die Boot-Konfiguration an.
Ich raff's nicht.
kinzi
The problem is probably caused by how HP implemented uefi.
kinzi
Beitrag von kinzi »
Hmmm ... they failed just in a particular model?
Possibly ... but not very likely.
I'd presume there is a hardware component which is not correctly detected by the OPSI boot image, since it's brand new hardware.
Just tried to use efibootmgr v18 in boot image but no luck due to libraries mismatch. Will give a live system a try.
