Ubuntu 22-04 Server support and opsi 4.2 updates
Verfasst: 12 Mai 2022, 12:51
dear opsi users,
hereby we officially release the opsi server support for ubuntu 22-04 and also some updates in opsi 4.2 testing and stable.
Important notices for this release:
* opsi is now running officially on ubuntu 22-04 servers. On machines that are running ubuntu 22-04 the installation process is similar to another ubuntu release. However currently we recommend to wait with an upgrade from ubuntu 20-04 to 22-04 until the first official LTS or point release.
* the opsipxeconfd now also contains the machine mac address saved in the opsi backend in the named pipe. This is used to fix problematic MAC Passthrough drivers.
* the opsi-linux-bootimage reads the aforementioned mac address from the named pipe and spoofs it if the external network devices mac address doesn't match with the given one. This step is needed because of problems with the MAC Passthrough and the associated network driver.
Updates iin testing:
Windows Netboot:
* wipedisk (2.3-3)
Linux Netboot:
* ubuntu (4.2.0.4-2)
* wipedisk (2.3-3)
opsi Server:
* opsi-server (4.2.0.68-1)
* redis (6.0.16-1)
* opsiconfd (4.2.0.260-1)
* opsi-utils (4.2.0.168-1)
Updates in stable:
Linux Netboot:
* opensusel15-3 (4.2.0.1-7)
* ubuntu (4.2.0.4-1)
opsi Server:
* opsi-linux-bootimage (20220428-1)
Regards
Mathias Radtke
Changelogs
Windows Netboot:
* wipedisk (2.3-3)
Linux Netboot:
* wipedisk (2.3-3)
opsi Server:
* redis (6.0.16-1)
Updates in stable:
Linux Netboot:
opsi Server:
Regards
Mathias Radtke
Changelogs
wipedisk (2.3-3) testing; urgency=low
* added some more debug output
-- Mathias Radtke <m.radtke@uib.de> Fri Apr 22 2022 10:00:00 +0200
wipedisk (2.3-2) testing; urgency=low
* reworked enhanced erase output
-- Mathias Radtke <m.radtke@uib.de> Thu Apr 21 2022 15:48:00 +0200
ubuntu (4.2.0.4-2) testing; urgency=low
* corrected usage of source for opsi-linux-client-agent installation
-- Mathias Radtke <m.radtke@uib.de> Thu Apr 7 09:45:16 2022 +0200
ubuntu (4.2.0.4-1) testing; urgency=low
* added Jammy Jellyfish (22.04) debootstrap script
-- Mathias Radtke <m.radtke@uib.de> Tue Apr 05 11:20:00 2022 +0100
opsi-server (4.2.0.68-1) stable; urgency=medium
* Improvement: opsi_auth kerb5 no_ccache
-- uib GmbH <info@uib.de> Thu, 05 May 2022 14:53:06 +0200
opsi-server (4.2.0.67-1) stable; urgency=medium
* Improvement: Update default backend config files
-- uib GmbH <info@uib.de> Thu, 31 Mar 2022 13:09:46 +0200
opsi-linux-bootimage (20220428-1) testing; urgency=low
* mac address spoofing only when enx* device is used
* kernel 5.17.5
-- Mathias Radtke <m.radtke@uib.de> Thu, 28 Apr 2022 11:40:00 +0100
opsi-linux-bootimage (20220425-1) testing; urgency=low
* updated python-opsi
* kernel 5.17.4
-- Mathias Radtke <m.radtke@uib.de> Mon, 25 Apr 2022 10:28:00 +0100
opensusel15-3 (4.2.0.1-7) testing; urgency=low
opsipxeconfd (4.2.0.30-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 02 May 2022 08:17:48 +0200
opsipxeconfd (4.2.0.29-1) stable; urgency=medium
* Improvement: revert change to backend_getLicensingInfo call
-- uib GmbH <info@uib.de> Tue, 26 Apr 2022 16:00:57 +0200
opsipxeconfd (4.2.0.28-1) stable; urgency=medium
* Improvement: fix bug with backend_getLicensingInfo
-- uib GmbH <info@uib.de> Tue, 19 Apr 2022 14:13:24 +0200
opsiconfd (4.2.0.260-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 09 May 2022 17:29:35 +0000
opsiconfd (4.2.0.259-1) stable; urgency=medium
* Feature: Show JSONRPC method documentation in Admin interface if available
* Improvement: Add buttons to change terminal font size
-- uib GmbH <info@uib.de> Wed, 04 May 2022 12:11:50 +0000
opsiconfd (4.2.0.258-1) stable; urgency=medium
* Bugfix: Fix grafana auto login / set-cookie
-- uib GmbH <info@uib.de> Fri, 29 Apr 2022 12:42:15 +0000
opsiconfd (4.2.0.257-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Tue, 26 Apr 2022 21:24:52 +0200
opsi-utils (4.2.0.168-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 09 May 2022 19:27:24 +0200
opsi-utils (4.2.0.167-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 02 May 2022 07:48:01 +0200
opsi-utils (4.2.0.166-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Wed, 27 Apr 2022 10:04:35 +0200
redis (5:6.0.16-1) stable; urgency=medium
* New upstream release.
-- Jan Schneider <j.schneider@uib.de> Wed, 04 May 2022 17:28:00 +0100
