Updates 4.2 stable and testing
News and announcements
fkalweit
Beitrag von fkalweit »
Dear opsi users,
today we have released more packages for opsi 4.2 in testing and stable.
Important announcement about Secureboot
The use of Secureboot with opsi is chargeable since the development of the extension. The licence status is checked in opsi-linux-bootimage. Unfortunately, in the past there was an error in the check and machines with activated Secureboot but not licensed extension could still be installed in Secureboot mode.
With the current opsi-linux-bootimage this error has been fixed and the check works correctly again. This now leads to an error message appearing for Netboot installations in Secureboot mode and unlicensed extensions, which indicates the lack of licensing.
The solution for this error message is to buy the Secureboot extension or disable Secureboot in the UEFI.
opsi license
We are currently revising the format of the opsi licence file (/etc/opsi/modules) and in this context there are some changes in the licence checks in Stable and Testing.
Old licences (module files) will continue to work.
With the new testing procedure, the client limits of the licences will be checked correctly.
This means that if there are not enough licences for a module, the corresponding module will be switched off.
Of course, there is some goodwill in the number of clients.
If you currently have more clients than your licence allows, there are several possibilities:
- Buy additional licences
- Remove clients you do not need
- Request a temporary activation from us to clarify whether or not additional licences should be purchased.
If you have any problems, we will of course be happy to help you.
Please contact us directly via sales(at)uib.de.
stable
Linux Netboot:
- debian (4.2.0.3-2)
- ubuntu (4.2.0.3-2)
- pcmemtest (1.4-1)
- wipedisk (2.3-1)
Server:
- opsiconfd (4.2.0.245-1)
- opsi-utils (4.2.0.161-1)
- opsi-server (4.2.0.64-1)
- opsipxeconfd (4.2.0.26)
- opsi-directory-connector (47.8-1)
- zsync-curl (0.6.2-3)
## testing:
Windows Localboot:
- windows10-upgrade (21h2-1)
- windows11-upgrade (21h2-1)
- opsi-client-agent (4.2.0.25-1)
Linux Localboot:
- opsi-linux-client-agent (4.2.0.19-1)
- l-opsi-server (4.2.0.6-3)
Macos Localboot:
- opsi-mac-client-agent (4.2.0.13-1)
Linux Netboot:
- sles12sp3 (4.2.0.1-7)
- sles12sp4 (4.2.0.1-7)
- sles12sp5 (4.2.0.1-7)
- sles15-1 (4.2.0.1-6)
- sles15-2 (4.2.0.1-6)
- sles15-3 (4.2.0.1-6)
- mint20-1 (4.2.0.1-5)
- mint20-2 (4.2.0.1-5)
- mint20-3 (4.2.0.1-5)
- ucs50 (4.2.0.1-7)
Server:
With kind regards
Fabian Kalweit
Changelogs:
sles12sp3/4/5 (4.2.0.1-7) testing; urgency=low
  * changed linux-client-agent installation
 -- Mathias Radtke <m.radtke@uib.de> Wed Mar 09 08:30:00 2022 +0200
sles15-1/2/3 (4.2.0.1-7) testing; urgency=low
  * version bump for consistency
 -- Mathias Radtke <m.radtke@uib.de> Wed Mar 09 08:1:00 2022 +0200
mint20-1/2/3 (4.2.0.1-5) testing; urgency=low
  * corrected behaviour when using installation_method = reboot
 -- Mathias Radtke <m.radtke@uib.de> Thu Mar 03 10:40:00 2022 +0200
ucs50 (4.2.0.1-7) testing; urgency=low
  * removed script from 4.2.0.1-6, replaced with another one
 -- Mathias Radtke <m.radtke@uib.de> Tue Feb 01 17:05:00 2022 +0200
ucs50 (4.2.0.1-6) testing; urgency=low
  * using postinst script to run join scripts and make Administrator account work
 -- Mathias Radtke <m.radtke@uib.de> Tue Jan 18 09:27:00 2021 +0200
ucs50 (4.2.0.1-5) testing; urgency=low
  * updated to ucs501
 -- Mathias Radtke <m.radtke@uib.de> Wed Dec 15 10:12:00 2021 +0200
ucs50 (4.2.0.1-4) testing; urgency=low
  * changed preseed/post installation command to adapt to other clientconfig.configserver.urls
 -- Mathias Radtke <m.radtke@uib.de> Tue Nov 16 15:34:49 2021 +0200
debian (4.2.0.3-2) testing; urgency=low
  * ubuntu.py: only setting locales for en and from language property
 -- Mathias Radtke <m.radtke@uib.de> Mon Feb 28 10:11:00 2022 +0200
debian (4.2.0.3-1) testing; urgency=low
  * opsipreparelib: wiping offsets when calling lcreate
  * 01_quota.sh: calling with quotaon -Pv
  * ubunut.py: corrected quota handling
  * cleanup of unused and commented code
 -- Mathias Radtke <m.radtke@uib.de> Mon Feb 14 13:27:00 2022 +0200
debian (4.2.0.2-3) testing; urgency=low
  * installing linux-client-agent via olca-install.service
  * new property enable_quota to support quota handling
 -- Mathias Radtke <m.radtke@uib.de> Wed Feb 09 11:50:00 2022 +0200
ubuntu (4.2.0.3-2) testing; urgency=low
ubuntu (4.2.0.3-1) testing; urgency=low
ubuntu (4.2.0.2-3) testing; urgency=low
wipedisk (2.3-1) testing; urgency=low
  * checking if NVME can be wiped
  * running sgdisk --zap-all anyway
 -- Mathias Radtke <m.radtke@uib.de> Tue Mar 01 2022 09:45:00 +0200
pcmemtest (1.4-1) testing
 * initial release
 -- Mathias Radtke <m.radtke@uib.de> Wed, 02 Sep 2021 15:55:00 +0200
l-opsi-server (4.2.0.6-3); testing; urgency=low
  * made some adaptations to wotk with UCS5.0-1 Systems
 -- Mathias Radtke <m.radtke@uib.de> Tue, 01 Feb 2022 17:08:00 +0200
l-opsi-server (4.2.0.6-2); testing; urgency=low
  * opening port 445 on UCS Systems
 -- Mathias Radtke <m.radtke@uib.de> Fri, 07 Jan 2022 11:46:00 +0200
l-opsi-server (4.2.0.6-1); testing; urgency=low
  * added support for UCS 5.0
 -- Mathias Radtke <m.radtke@uib.de> Fri, 17 Dec 2021 10:50:00 +0200
opsi-linux-client-agent (4.2.0.19-1) testing; urgency=low
  * Added version file opsi-client-agent.version for conditioned installation
  * Fixed session-handling for Installation service calls
  * Updated oca-installation-helper to 4.2.0.16
-- Nils Doerrer <n.doerrer@uib.de> Mon, 07 Mar 2022 14:00:00 +0100
opsi-linux-client-agent (4.2.0.18-1) testing; urgency=low
  * Updated opsiclientd to 4.2.0.110 (fixed jsonrpc logging)
-- Nils Doerrer <n.doerrer@uib.de> Thu, 24 Feb 2022 16:00:00 +0100
opsi-linux-client-agent (4.2.0.17-1) testing; urgency=low
  * Updated opsiclientd to 4.2.0.109 (reworked opsi-setup-user cleanup and service connection timeouts)
  * Updated oca-installation-helper to 4.2.0.15 (new parameters --dns-domain, --finalize, --read-conf-files)
  * Updated opsi-deploy-client-agent 4.2.0.18 (suse fix for smbclient call)
-- Nils Doerrer <n.doerrer@uib.de> Thu, 24 Feb 2022 10:00:00 +0100
opsi-mac-client-agent (4.2.0.13-1) stable; urgency=low
-- Nils Doerrer <n.doerrer@uib.de> Mon, 07 Mar 2022 18:00:00 +0100
opsi-mac-client-agent (4.2.0.12-1) stable; urgency=low
opsi-mac-client-agent (4.2.0.11-1) stable; urgency=low
  * Updated opsiclientd to 4.2.0.109 (fixed user_logged_in check, reworked opsi-setup-user cleanup and service connection timeouts)
-- Nils Doerrer <n.doerrer@uib.de> Thu, 17 Feb 2022 16:30:00 +0100
opsi-client-agent (4.2.0.25-1) stable; urgency=low
  * Fixed postinst for first time installation
  * Updated oca-installation-helper to 4.2.0.16 (new parameter --install-condition)
opsi-client-agent (4.2.0.24-1) stable; urgency=low
opsi-client-agent (4.2.0.23-1) stable; urgency=low
  * Removed Kiosk Migration. Do not install this package over opsi-client-agent < 4.1.1.18 (serverside) if using kiosk!
-- Nils Doerrer <n.doerrer@uib.de> Tue, 08 Feb 2022 11:00:00 +0100
windows10-upgrade (21h2-2) testing; urgency=low
    * IMPORTANT: Requires opsiclientd version 4.2.0.104 or higher
    * IMPORTANT: Requires opsi-script version 4.12.4.35-6 or higher
    * Added additional checks for opsiSetupUser leftovers
    * Added check for empty values in Disable UAC section
    * Added include for setupact.log
    * Updated the documentation
    * Tested on win7, win7-x64, win81, win81-x64, win10-2015, win10-x64-2015, win10-2016, win10-x64-2016, win10-2019, win10-x64-2019, win10-2021, win10-x64-2021, win10-21h1, win10-x64-21h1
-- Matthias Knauer <m.knauer@uib.de> Thu, 17 Feb 2022 11:11:11 +0000
windows11-upgrade (21h2-1) testing; urgency=low
    * Initial package
    * Tested on win10-21h1, win10-x64-21h1
-- Matthias Knauer <m.knauer@uib.de> Wed, 09 Feb 2022 11:11:11 +0000
opsiconfd (4.2.0.245-1) stable; urgency=medium
  * Improvement:  Always wait for session to be stored in redis
 -- uib GmbH <info@uib.de>  Wed, 09 Mar 2022 11:54:51 +0100
opsiconfd (4.2.0.244-1) stable; urgency=medium
  * Bugfix:  Fix reading RedisTimeSeries data
 -- uib GmbH <info@uib.de>  Fri, 25 Feb 2022 12:19:58 +0100
opsiconfd (4.2.0.243-1) stable; urgency=medium
  * Improvement:  Update python-opsi-common (4.2.0.276 -> 4.2.0.277)
 -- uib GmbH <info@uib.de>  Fri, 25 Feb 2022 00:15:52 +0000
opsiconfd (4.2.0.242-1) stable; urgency=medium
  * Improvement:  Add licensing tab
  * Improvement:  Impove grafana setup
  * Improvement:  Update python-opsi-common (4.2.0.275 -> 4.2.0.276)
  * Bugfix:  Fix creating grafana dashboard user
 -- uib GmbH <info@uib.de>  Thu, 24 Feb 2022 21:41:43 +0100
opsiconfd (4.2.0.241-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Thu, 24 Feb 2022 10:06:04 +0000
opsiconfd (4.2.0.240-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Wed, 23 Feb 2022 12:54:12 +0000
opsiconfd (4.2.0.239-1) stable; urgency=medium
  * Improvement:  Add config admin-interface-terminal-shell
  * Improvement:  Use configured user shell
 -- uib GmbH <info@uib.de>  Mon, 21 Feb 2022 16:25:54 +0100
opsiconfd (4.2.0.238-1) stable; urgency=medium
  * Improvement:  Update python-opsi (4.2.0.272 -> 4.2.0.273)
  * Bugfix:  Fix nagios disk usage check
 -- uib GmbH <info@uib.de>  Mon, 21 Feb 2022 11:44:38 +0000
opsiconfd (4.2.0.237-1) stable; urgency=medium
  * Improvement:  Improve terminal latency
  * Feature:  Allow to disable admin interface features
  * Improvement:  Admin page hash links
  * Feature:  Terminal file upload
 -- uib GmbH <info@uib.de>  Fri, 18 Feb 2022 15:52:01 +0000
opsiconfd (4.2.0.236-1) stable; urgency=medium
  * Feature:  Add terminal application
  * Improvement:  Log config on setup
 -- uib GmbH <info@uib.de>  Mon, 14 Feb 2022 15:56:44 +0100
opsiconfd (4.2.0.235-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Tue, 08 Feb 2022 12:15:12 +0100
opsiconfd (4.2.0.234-1) stable; urgency=medium
  * Improvement:  Updated python packages
  * Improvement:  Show days until cert renewal in admin interface
 -- uib GmbH <info@uib.de>  Mon, 07 Feb 2022 13:13:14 +0100
opsiconfd (4.2.0.233-1) stable; urgency=medium
  * Feature:  Add WebDAV link on admin interface
  * Improvement:  Config file is optional
 -- uib GmbH <info@uib.de>  Wed, 02 Feb 2022 07:55:59 +0100
opsiconfd (4.2.0.232-1) stable; urgency=medium
  * Improvement:  Update python pacakages
  * Feature:  Add central webdav share /webdav
 -- uib GmbH <info@uib.de>  Fri, 28 Jan 2022 17:31:41 +0100
opsiconfd (4.2.0.231-1) stable; urgency=medium
  * Improvement:  Recreate server cert if ca is renewed
 -- uib GmbH <info@uib.de>  Wed, 26 Jan 2022 11:40:26 +0000
opsiconfd (4.2.0.230-1) stable; urgency=medium
  * Improvement:  Check server cert against ca
  * Improvement:  Improve ssl info in admin interface
  * Improvement:  Version 4.2.0.230 running with python 3.10
  * Improvement:  Update fastapi to 0.73
 -- uib GmbH <info@uib.de>  Tue, 25 Jan 2022 15:11:45 +0100
opsiconfd (4.2.0.229-1) stable; urgency=medium
  * No public changes
 -- uib GmbH <info@uib.de>  Fri, 21 Jan 2022 10:14:02 +0100
opsiconfd (4.2.0.228-1) stable; urgency=medium
  * No public changes
 -- uib GmbH <info@uib.de>  Wed, 12 Jan 2022 18:31:52 +0100
opsiconfd (4.2.0.227-1) stable; urgency=medium
  * Improvement:  Recreate server cert if key or cert unreadable
  * Improvement:  Check server cert and key mismatch
 -- uib GmbH <info@uib.de>  Wed, 12 Jan 2022 12:51:23 +0100
opsiconfd (4.2.0.226-1) stable; urgency=medium
  * Improvement:  Add lsb-release to dependencies
  * Bugfix:  Fix setting RLIMIT_NOFILE
 -- uib GmbH <info@uib.de>  Wed, 05 Jan 2022 22:23:14 +0100
opsiconfd (4.2.0.225-1) stable; urgency=medium
  * Improvement:  Log System Volume Information MKCOL error with debug level
  * Bugfix:  Make /public readonly
 -- uib GmbH <info@uib.de>  Wed, 22 Dec 2021 14:55:39 +0100
opsiconfd (4.2.0.224-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Fri, 17 Dec 2021 18:46:56 +0100
opsi-utils (4.2.0.161-1) stable; urgency=medium
  * Improvement:  changed logging config to always use logfile (parameter or default)
 -- uib GmbH <info@uib.de>  Mon, 07 Mar 2022 18:18:46 +0100
opsi-utils (4.2.0.160-1) stable; urgency=medium
  * Improvement:  updated python packages, added importhook for pyasn1_modules
 -- uib GmbH <info@uib.de>  Wed, 02 Mar 2022 15:32:44 +0100
opsi-utils (4.2.0.159-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Fri, 25 Feb 2022 01:20:28 +0100
opsi-utils (4.2.0.158-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Thu, 24 Feb 2022 15:44:59 +0100
opsi-utils (4.2.0.157-1) stable; urgency=medium
  * Improvement:  Updating python-opsi (4.2.0.274 -> 4.2.0.275)
 -- uib GmbH <info@uib.de>  Thu, 24 Feb 2022 11:02:12 +0100
opsi-utils (4.2.0.156-1) stable; urgency=medium
  * Improvement:  opsi-setup: do not create default log file /tmp/opsi-setup.log
  * Improvement:  Update python-opsi 4.2.0.272 -> 4.2.0.273
 -- uib GmbH <info@uib.de>  Tue, 22 Feb 2022 07:47:14 +0100
opsi-utils (4.2.0.155-1) stable; urgency=medium
  * Improvement:  Upgrade python and python packages
  * Improvement:  Build with python 3.10
 -- uib GmbH <info@uib.de>  Fri, 18 Feb 2022 16:57:21 +0100
opsi-utils (4.2.0.154-1) stable; urgency=medium
  * Improvement:  Change defaults for --log-file and --log-level
 -- uib GmbH <info@uib.de>  Tue, 15 Feb 2022 19:12:19 +0100
opsi-utils (4.2.0.153-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Mon, 07 Feb 2022 13:14:40 +0100
opsi-server (4.2.0.64-1) stable; urgency=medium
  * Improvement:  Auto set signed-by option in opsi.list
 -- uib GmbH <info@uib.de>  Fri, 11 Feb 2022 11:05:31 +0100
opsi-server (4.2.0.62-1) stable; urgency=medium
  * Improvement:  Install opsi-obs.gpg key on debian-like dists
 -- uib GmbH <info@uib.de>  Tue, 25 Jan 2022 20:23:21 +0100
opsi-server (4.2.0.61-1) stable; urgency=medium
  * Improvement:  Require opsiconfd >= 4.2.0.228 and opsi-utils >= 4.2.0.149
  * Improvement:  New default hostcontrol.conf for the new config format
  * Improvement:  dynamic depot by network subnetwork match
 -- uib GmbH <info@uib.de>  Thu, 20 Jan 2022 13:53:50 +0100
opsi-server (4.2.0.60-1) stable; urgency=medium
  * Improvement:  Remove methods setGeneralConfig and setGeneralConfigValue
  * Bugfix:  getHostGroupTree_hash
  * Bugfix:  Remove invalid escape sequences in opsihwaudit.conf
 -- uib GmbH <info@uib.de>  Mon, 20 Dec 2021 10:25:23 +0100
opsi-server (4.2.0.59-1) stable; urgency=medium
  * Improvement:  New default values for hostRpcTimeout and maxConnections
 -- uib GmbH <info@uib.de>  Thu, 07 Oct 2021 14:45:10 +0200
opsi-server (4.2.0.58-1) stable; urgency=medium
  * Bugfix:  ucs join script udm groups/group modify
 -- uib GmbH <info@uib.de>  Tue, 07 Sep 2021 14:16:10 +0200
opsi-server (4.2.0.57-1) stable; urgency=medium
  * Improvement:  Fix method setProductActionProgress with empty string as progress
 -- uib GmbH <info@uib.de>  Mon, 06 Sep 2021 07:22:49 +0200
opsipxeconfd (4.2.0.26-1) stable; urgency=medium
  * Improvement:  New default log file /var/log/opsi/opsipxeconfd/opsipxeconfd.log
 -- uib GmbH <info@uib.de>  Fri, 18 Feb 2022 07:27:25 +0100
opsipxeconfd (4.2.0.25-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Thu, 17 Feb 2022 14:47:52 +0100
opsipxeconfd (4.2.0.24-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Thu, 03 Feb 2022 13:20:04 +0100
opsi-directory-connector (47.8-1) stable; urgency=medium
  * Improvement:  use new license check
 -- uib GmbH <info@uib.de>  Thu, 17 Feb 2022 13:24:16 +0000
opsi-directory-connector (47.7-1) stable; urgency=medium
  * Feature:  config delete_empty_groups
 -- uib GmbH <info@uib.de>  Tue, 25 Jan 2022 12:56:19 +0000
