Actualisations pour opsi 4.2 dans stable et testing
Verfasst: 07 Dez 2021, 22:16
Chers utilisateurs d'opsi,
nous publions d'autres paquets pour opsi 4.2 dans opsi et testing.
## stable
### opsi-server:
- opsipxeconfd 4.2.0.21
- opsi-directory-connector 47.4-1
- opsi-utils 4.2.0.139
- opsiconfd 4.2.0.216
## testing:
### opsi-server:
- opsi-utils 4.2.0.142
- opsi-server 4.2.0.59
- redis-timeseries 1.4.11.0
Cordialement
Fabian Kalweit
## stable
### opsi-server:
## testing:
### opsi-server:
Cordialement
Fabian Kalweit
opsiconfd (4.2.0.216-1) stable; urgency=medium
* Improvement: Log rotation for client logs
-- uib GmbH <info@uib.de> Thu, 25 Nov 2021 12:09:45 +0100
opsiconfd (4.2.0.215-1) stable; urgency=medium
* Bugfix: Skip server certificate check if ssl in skip-setup
-- uib GmbH <info@uib.de> Wed, 24 Nov 2021 10:05:48 +0100
opsiconfd (4.2.0.214-1) stable; urgency=medium
* Bugfix: added postinst fix for SSL library incompatibility of SLES15-X
-- uib GmbH <info@uib.de> Thu, 18 Nov 2021 15:51:04 +0000
opsiconfd (4.2.0.213-1) stable; urgency=medium
* Bugfix: Update python-opsi to fix onetime password auth
-- uib GmbH <info@uib.de> Mon, 15 Nov 2021 18:24:06 +0100
opsi-directory-connector (47.4-1) stable; urgency=medium
* No public changes
-- uib GmbH <info@uib.de> Mon, 11 Oct 2021 09:54:00 +0000
opsi-directory-connector (47.2-1) stable; urgency=medium
* Bugfix: fix error log
-- uib GmbH <info@uib.de> Fri, 08 Oct 2021 14:24:35 +0000
opsipxeconfd (4.2.0.21-1) stable; urgency=medium
* Improvement: Update python-packages
* Improvement: Use new licensing info if available
-- uib GmbH <info@uib.de> Mon, 15 Nov 2021 10:39:41 +0100
opsipxeconfd (4.2.0.20-1) stable; urgency=medium
* Improvement: arm64 build
-- uib GmbH <info@uib.de> Wed, 22 Sep 2021 14:21:32 +0200
opsi-utils (4.2.0.142-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Thu, 18 Nov 2021 15:50:46 +0000
opsi-utils (4.2.0.138-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 15 Nov 2021 12:11:03 +0100
opsi-utils (4.2.0.137-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 08 Nov 2021 18:38:22 +0100
opsi-utils (4.2.0.136-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Thu, 04 Nov 2021 19:20:13 +0100
opsi-utils (4.2.0.135-1) stable; urgency=medium
* Bugfix: fixed opsiwakeupclients jsonrpc connection check
-- uib GmbH <info@uib.de> Wed, 03 Nov 2021 16:42:39 +0100
opsi-utils (4.2.0.134-1) stable; urgency=medium
* Improvement: updated python-opsi to 4.2.0.249 (fixed opsi-package-updater behaviour on flat repositories)
* Improvement: prohibit accidently registering the confserver as depot at itself, import fix in opsi-python
-- uib GmbH <info@uib.de> Wed, 13 Oct 2021 13:05:06 +0200
opsi-utils (4.2.0.133-1) stable; urgency=medium
* No public changes
-- uib GmbH <info@uib.de> Mon, 11 Oct 2021 12:22:48 +0200
opsi-utils (4.2.0.132-1) stable; urgency=medium
* Bugfix: removed legacy logger calls, minor cleanup
-- uib GmbH <info@uib.de> Mon, 11 Oct 2021 10:33:47 +0200
opsi-utils (4.2.0.131-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Fri, 08 Oct 2021 09:07:22 +0200
opsi-utils (4.2.0.130-1) stable; urgency=medium
* Improvement: Update python-opsi
-- uib GmbH <info@uib.de> Tue, 21 Sep 2021 12:33:06 +0200
opsi-server (4.2.0.59-1) stable; urgency=medium
* Improvement: New default values for hostRpcTimeout and maxConnections
-- uib GmbH <info@uib.de> Thu, 07 Oct 2021 14:45:10 +0200
opsi-server (4.2.0.58-1) stable; urgency=medium
* Bugfix: ucs join script udm groups/group modify
-- uib GmbH <info@uib.de> Tue, 07 Sep 2021 14:16:10 +0200
