opsi 4.2 on ARM and more updates in testing/stable
Verfasst: 06 Okt 2021, 11:59
Dear opsi users
hereby we release updated packges in opsi 4.1 and opsi 4.2 in testing and stable
Important notices for this release:
Alma Linux and Rocky Linux are now officially supported ad opsi servers in opsi 4.2 stable
With opsi 4.1 we introduced ARM (armv7) packages on Debian 8, 9 and 10. Within the process of the creation of opsi 4.2 most of the server scripts like opsiconfd or opsi-setup were build as binary files. However these did not work on ARM devices. We did put in a lot of work to make ARM work with opsi 4.2. We hereby release tetsing support for Debian 9, 10 and 11 on AARCH64 ARM devices.
"The last Windows" successor Windows 11 and Windows Server 2022 are now available within the stable packages.
Linux netboot packages sometimes failed to install the opsi-linux-client-agent properly due to networking problems. These packages now have a small addition to verify network connection to the opsi config-server before starting the opsi-linux-client-agent installation.
Updated packages in testing:
Windows Localboot:
* opsi-configed 4.1.9.11.1-1
* opsi-script 4.12.4.28
* opsi-winst 4.12.4.28
Linux Localboot:
opsi-local-image Localboot:
* none
macOS Localboot:
Windows Netboot:
* none
Linux Netboot:
* alma8 4.2.0.1-3
* centos70 4.2.0.1-4
* centos8 4.2.0.1-3
* debian 4.2.0.1-2
* debian10 4.2.0.1-4
* debian9 4.2.0.1-4
* debian11 4.2.0.1-4
* mint20-1 4.2.0.1-2
* mint20-2 4.2.0.1-2
* opensusel15-2 4.2.0.1-3
* opensusel15-3 4.2.0.1-3
* redhat70 4.2.0.1-4
* redhat8 4.2.0.1-3
* rocky8 4.2.0.1-3
* sles12sp* 4.2.0.1-3
* sles15-1 4.2.0.1-2
* sles15-2 4.2.0.1-2
* sles15-3 4.2.0.1-2
* ubuntu 4.2.0.1-2
* ubuntu18-04 4.2.0.1-4
* ubuntu20-04 4.2.0.1-4
* ucs44 4.2.0.1-2
opsi-local-image Netboot:
* opsi-local-image-backup 4.2.0.1-1
* opsi-local-image-restore 4.2.0.1-1
* opsi-local-image-backup-starter 4.2.0.1-1
opsi Server:
* opsi-linux-bootimage 20210920-1 (opsi 4.2)
opsi Manuals:
* none
Updated packages in stable:
Windows Localboot:
* none
Linux Localboot:
* l-opsi-server 4.2.0.5-2
* none
macOS Localboot:
* none
Windows Netboot:
* win11-x64 4.2.0.1-4
* win2022 4.2.0.1-4
* wipedisk 2.2-1
Linux Netboot:
* wipedisk 2.2-1
* none
opsi Server:
* none
opsi Manuals:
* none
With kind regards
the opsi Team
Mathias Radtke
Hier kommen die
Changelogs
Windows Localboot:
Linux Localboot:
* none
macOS Localboot:
Windows Netboot:
* none
Linux Netboot:
* alma8 4.2.0.1-3
* centos8 4.2.0.1-3
* debian 4.2.0.1-2
* debian9 4.2.0.1-4
* redhat8 4.2.0.1-3
* rocky8 4.2.0.1-3
* ubuntu 4.2.0.1-2
* ucs44 4.2.0.1-2
opsi Server:
opsi Manuals:
* none
Windows Localboot:
* none
Linux Localboot:
* none
macOS Localboot:
* none
Windows Netboot:
* win2022 4.2.0.1-4
* wipedisk 2.2-1
Linux Netboot:
* wipedisk 2.2-1
* none
opsi Server:
* none
opsi Manuals:
* none
With kind regards
the opsi Team
Mathias Radtke
Hier kommen die
Changelogs
opsi-script (4.12.4.28) stable; urgency=low
* osparser: do XMLPatch2Main: new xml2-section commands:
* setNodePair <keyNodeName> <keyNodeTextContent> <valueNodeName> <valueNodeTextContent>
used for Apple info.plist
* osxmlsections: TuibXMLDocument: new:
setNodePair(keyNodeName: string; keyNodeTextContent: string;
valueNodeName: string; valueNodeTextContent: string): boolean;
* Execwith: if there is a parameter '/HookScript <path to script file>',
then the existing 'script file' will be called with the temporary file
as parameter before passing it to the interpreter.
The call of the hookscript has a 40 sec Timeout
* osfunc: additional log at FileCheckDate
* DPI awareness True/PM_V2
* osparser: doAktionen: FBatchOberflaeche.LoadSkin(''); and Processmess to reload DPI scaling
* osparser: execPowershellCall has now additionl parameter optionstr that may hold additional
execwith parameters
* osparser: getDecimalCompareSign (used by compareDotSeperatedNumbers):
now support leading zeros (then it will handled as float starting with 0.)
now support a letter as last part of the number (1.0.23b like is used at openssl versions)
* osparser: executewith: call powershell scripts with -file parameter in order to get the correct exitcode
* osparser: fix Access Violation in CreateAndProcessScript on empty scriptfiles.
-- d.oertel <d.oertel@uib.de> Tue, 31 Aug 2021 15:00
opsi-configed (4.1.9.11.1-1) TESTING; urgency=medium
* avoiding NPE when used with an opsi-client-agent without property
on_shutdown_install"
-- r.roeder <r.roeder@uib.de> Fri, 01 Oct 2021 17:10:40 +0100
opsi-configed (4.1.9.10.1-2) EXPERIMENTAL; urgency=medium
* Linux script uses 64 bit bundled java
-- r.roeder <r.roeder@uib.de> Tue, 17 Aug 2021 13:10:40 +0100
opsi-configed (4.1.9.10.1-1) EXPERIMENTAL; urgency=medium
* merging with lz4 patch
-- r.roeder <r.roeder@uib.de> Fri, 23 Jul 2021 11:10:40 +0100
alma8 (4.2.0.1-3) testing; urgency=low
* patching configserver ip address into olca-install.service file
-- Mathias Radtke <m.radtke@uib.de> Mon Sep 27 14:13:18 2021 +0200
centos70/redhat70 (4.2.0.1-4) testing; urgency=low
debian/ubuntu (4.2.0.1-2) testing; urgency=low
* fixed error on new opsi-linux-client-agent
-- Mathias Radtke <m.radtke@uib.de> Fri Oct 01 14:00:00 2021 +0200
debian9/10/11 (4.2.0.1-4) testing; urgency=low
mint20-1/20-2 (4.2.0.1-2) testing; urgency=low
opensusel15-2/15-3 (4.2.0.1-3) testing; urgency=low
sles12* (4.2.0.1-3) testing; urgency=low
sles15* (4.2.0.1-3) testing; urgency=low
ubuntu18-04/20-04 (4.2.0.1-4) testing; urgency=low
ucs44 (4.2.0.1-2) testing; urgency=low
windows (4.2.0.1-4) testing; urgency=low
* fixed opsi-python test in postinst
-- Mathias Radtke <m.radtke@uib.de> Thu Aug 19 10:16:31 2021 +0200
l-opsi-server (4.2.0.5-2); testing; urgency=low
* fixed error with l-opsi-server-quick-install
-- Mathias Radtke <m.radtke@uib.de> Thu, 30 Sep 2021 12:00:00 +0200
opsi-local-image-backup/restore (4.2.0.1-1) stable; urgency=low
* fix progressbar output
-- detlef oertel <d.oertel@uib.de> Mon, 12 Jul 2021 15:00:00 +0200
opsi-local-image-backup-starter (4.2.0.1-1) stable; urgency=low
* fixed productName
* shebang fix
-- detlef oertel <d.oertel@uib.de> Tue, 27 Jul 2021 15:00:00 +0200
opsi-linux-bootimage (20210920-1) testing; urgency=low
* using SMB vers=3 instead of vers=3.0
-- Mathias Radtke <m.radtke@uib.de> Mon, 20 Sep 2021 14:55:00 +0200
opsi-linux-bootimage (20210916-1) testing; urgency=low
* added wimlib
* added hivex
* added patch for better Hpyer-V support
-- Mathias Radtke <m.radtke@uib.de> Thu, 16 Sep 2021 10:30:00 +0200
opsi-linux-bootimage (20210906-1) testing; urgency=low
* Allow to process file and kernel params at once
* made link detection faster
-- Jan Schneider <j.schneider@uib.de> Mon, 06 Sep 2021 16:09:00 +0200
