opsi-boot-image
ckruijntjens
opsi-boot-image
Beitrag von ckruijntjens »
hi all,
I start opsi-boot-image true tftpserver. how can i change the keyboard layout in the boot image?
Kind regards,
Chris Kruijntjens.
Re: opsi-boot-image
Hi Chris,
you can set the Server Host-Parameter
opsi-linux-bootimage.append to
lang=en
to set it to english.
Regards
ckruijntjens
Re: opsi-boot-image
Where is this file opsi-linux-bootimage.append
i can not find it on my server? where do i need to create it?
Re: opsi-boot-image
This is a host parameter.
You can change these host parameters via the opsi config editor.
ckruijntjens
Re: opsi-boot-image
This is not working for me. I am booting the boot image directly from my pxe server with the follwing parameters. (this used to work) until now
:Opsi
kernel http://192.168.2.10/install-x64 initrd=miniroot-x64.bz2 lang=eng video=vesa:ywrap,mtrr vga=791 quiet splash --no-log console=tty1 console=ttyS0 service=https://192.168.2.10:4447/rpc
initrd http://192.168.2.10/miniroot-x64.bz2
boot
however now the keyboard language when booted is de. (i use ipxe for booting the opsi boot image)
ckruijntjens
Re: opsi-boot-image
Nobody that can help me?
Re: opsi-boot-image
you can edit the file that gets requested via the TFTP and add the lang=en option
ckruijntjens
Re: opsi-boot-image
I append these to the kernel. everything is working except the lang=eng
ckruijntjens
Re: opsi-boot-image
Sorry,
Allredeay found the bug. Ik made a error. Ik used lang=eng. Ik changed it to lang=en
Now it is working. Thanks all
