Opsi: Windows 10 UEFI Boot
Verfasst: 18 Mai 2021, 12:44
Hello,
I'm trying to setup Windows 10 on ESXi-VM version 7.0.2 u with OPSI, everything works great with BIOS boot! But it doesn't work with UEFI Boot and always hangs with "Fetching Netboot Image" with a black screen.
The following is in / var / log / syslog:
How can I get rid of this problem?
Thanks!
Apr 20 16:23:47 opsiserver in.tftpd[23353]: RRQ from 10.22.30.101 filename linux/pxelinux.cfg/shimx64.efi.signed
Apr 20 16:23:47 opsiserver in.tftpd[23353]: tftp: client does not accept options
Apr 20 16:23:47 opsiserver in.tftpd[23354]: RRQ from 10.22.30.101 filename linux/pxelinux.cfg/shimx64.efi.signed
Apr 20 16:23:47 opsiserver in.tftpd[23355]: RRQ from 10.22.30.101 filename linux/pxelinux.cfg/grubx64.efi
Apr 20 16:23:48 opsiserver in.tftpd[23356]: RRQ from 10.22.30.101 filename /grub/x86_64-efi/command.lst
Apr 20 16:23:48 opsiserver in.tftpd[23357]: RRQ from 10.22.30.101 filename /grub/x86_64-efi/fs.lst
Apr 20 16:23:48 opsiserver in.tftpd[23358]: RRQ from 10.22.30.101 filename /grub/x86_64-efi/crypto.lst
Apr 20 16:23:48 opsiserver in.tftpd[23359]: RRQ from 10.22.30.101 filename /grub/x86_64-efi/terminal.lst
Apr 20 16:23:48 opsiserver in.tftpd[23360]: RRQ from 10.22.30.101 filename /grub/grub.cfg
Apr 20 16:23:48 opsiserver in.tftpd[23361]: RRQ from 10.22.30.101 filename /grub/grub.cfg
Apr 20 16:23:48 opsiserver in.tftpd[23362]: RRQ from 10.22.30.101 filename /grub/grub.cfg
Apr 20 16:23:48 opsiserver in.tftpd[23363]: RRQ from 10.22.30.101 filename /grub/grub.cfg
Apr 20 16:23:48 opsiserver in.tftpd[23364]: RRQ from 10.22.30.101 filename /linux/pxelinux.cfg/01-00-50-56-85-53-fd
Apr 20 16:23:48 opsiserver in.tftpd[23365]: RRQ from 10.22.30.101 filename /linux/pxelinux.cfg/01-00-50-56-85-53-fd
Apr 20 16:23:49 opsiserver in.tftpd[23366]: RRQ from 10.22.30.101 filename /linux/pxelinux.cfg/01-00-50-56-85-53-fd
Apr 20 16:23:54 opsiserver in.tftpd[23367]: RRQ from 10.22.30.101 filename /linux/install-x64
Apr 20 16:23:54 opsiserver in.tftpd[23368]: RRQ from 10.22.30.101 filename /linux/install-x64
Apr 20 16:23:55 opsiserver in.tftpd[23369]: RRQ from 10.22.30.101 filename /linux/miniroot-x64.bz2
Thanks!
