Updates for opsi 4.1 / 4.2 stable and testing
News and announcements
Dear opsi users,
today we have released more packages for opsi 4.1 and 4.2 in testing and stable.
URGENT Ubuntu 16.04 is EOL. Our packages will still be build for this version of Ubuntu on the Open Build Service. However we do not recommend to use a non supported operating system in a productive environment.
The package wipedisk can now also correctly wipe SSDs via SATA Security Erase and NVMEs with the format command. For both mentioned the Bootimage with version 20210326 and higher is needed. Please note that wiping a SSD with Security Erase will put your machine into sleep mode for a couple of seconds if the state of the drive is listed as frozen. Do not wonder if the screen turns black and returns after a short while.
Updated packages in opsi 4.1 Stable:
Windows Netboot packages
* windows (4.1.0.2-14)
Opsi-Local-Image Netboot packages
Windows Localboot packages
* opsi-client-agent (4.1.1.32-1)
Updated packages in opsi 4.1 Testing:
Windows Netboot packages:
* wipedisk (2.1-1)
opsi Server packages:
* opsi-linux-bootimage (20210326-1)
Updated packages in opsi 4.2 Testing:
* opsiconfd (4.2.0.167-1)
* opsi-utils (4.2.0.95-1)
* opsi-server (4.2.0.51-1)
* opsi-linux-bootimage (20210426-1)
With kind regards
Changelogs:
opsi-client-agent (4.1.1.32-1) stable; urgency=low
  * Fixed opsi-deploy-client-agent
  * Updated opsiclientd to 4.2.0.70
-- Nils Dörrer <n.doerrer@uib.de> Thu, 019 Apr 2021 12:00:00 +0100
opsi-client-agent (4.1.1.31-2) stable; urgency=low
  * Fixed opsi-notifier deployment
-- Nils Dörrer <n.doerrer@uib.de> Thu, 013 Apr 2021 15:00:00 +0100
wipedisk (2.1-1) stable; urgency=low
  * now compatible with SSD enhanced erase and NVME format
 -- Mathias Radtke <m.radtke@uib.de> Fri Mar 12 2021 16:00:00 +0100
opsi-linux-bootimage (20210426-1) testing; urgency=medium
  * updated python opsi
  * PATCHA_IN provides more variables
 -- Mathias Radtke <m.radtke@uib.de> Mon, 26 Apr 2021 15:15:00 +0100
opsi-linux-bootimage (20210326-1) testing; urgency=medium
  * updated python-opsi
  * added rtc driver
  * nvme-cli added
 -- Mathias Radtke <m.radtke@uib.de> Fri, 26 Mar 2021 12:00:00 +0100
opsi-linux-bootimage (20210305-1) testing; urgency=medium
  * using resolv.conf instead of systemd stub resolver
  * kernel 5.10.20
 -- Mathias Radtke <m.radtke@uib.de>  Fri, 05 Mar 2021 12:36:37 +0100
windows (4.1.0.2-14) testing; urgency=low
  * corrected logging error on show_drivers.py
 -- Mathias Radtke <m.radtke@uib.de> Tue Mar 23 12:25:41 2021 +0200
opsiconfd (4.2.0.167-1) stable; urgency=medium
  * current version
 -- uib GmbH <info@uib.de>  Fri, 07 May 2021 10:15:13 +0200
opsiconfd (4.2.0.166-1) stable; urgency=medium
  * Feature:  Show ca and cert expiry on status page
  * Feature:  Warn if common name of CA changes
  * Feature:  Start webgui application
 -- uib GmbH <info@uib.de>  Wed, 05 May 2021 13:11:26 +0200
opsiconfd (4.2.0.164-1) stable; urgency=medium
  * Improvement:  Add missing newline in config file
 -- uib GmbH <info@uib.de>  Thu, 29 Apr 2021 13:16:47 +0200
opsiconfd (4.2.0.163-1) stable; urgency=medium
  * Feature:  Add configuration --ssl-ca-subject-cn
 -- uib GmbH <info@uib.de>  Thu, 29 Apr 2021 12:36:40 +0200
opsiconfd (4.2.0.162-1) stable; urgency=medium
  * Improvement:  Implement force-stop
  * Feature:  Add config --worker-stop-timeout and it for systemd
  * Improvement:  Update python-opsi
 -- uib GmbH <info@uib.de>  Wed, 28 Apr 2021 14:38:09 +0200
opsiconfd (4.2.0.161-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Tue, 27 Apr 2021 15:56:26 +0200
opsiconfd (4.2.0.160-1) stable; urgency=medium
  * Feature:  Limitation of the log records in redis streams
  * Improvement:  Improve zeroconf registration
 -- uib GmbH <info@uib.de>  Fri, 23 Apr 2021 18:11:04 +0200
opsi-utils (4.2.0.95-1) stable; urgency=medium
  * current version
 -- uib GmbH <info@uib.de>  Fri, 07 May 2021 10:18:40 +0200
opsi-utils (4.2.0.92-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Wed, 28 Apr 2021 14:41:22 +0200
opsi-server (4.2.0.51-1) stable; urgency=medium
  * Improvement:  New default opsi.conf
 -- uib GmbH <info@uib.de>  Wed, 28 Apr 2021 11:17:36 +0200
opsi-server (4.2.0.50-1) stable; urgency=medium
  * Feature:  Use new admingroup placeholder in acl.conf
 -- uib GmbH <info@uib.de>  Tue, 27 Apr 2021 16:58:59 +0200
