Updates for opsi 4.1 stable und testing
News and announcements
Dear opsi users,
today we have released more packages for opsi 4.1 in Testing and Stable.
Furthermore the documentations have been updated.
Important new features in this release:
opsi-client-kiosk (4.1.1.8-8):
Fixed an error in the skin customization,
titel and kiosk.icon will now displayed correctly.
INFO: The files for skin customization are located in:
/var/lib/opsi/depot/opsi-client-kiosk/files/app/ock_custom/skin
opsi-winst / opsi-script (4.12.4.12-1):
A lot of small fixes.
At the opsi-script for Linux and Mac you will see the following changes:
* There is no (real) opsi-script-nogui anymore
* opsi-script is now the no-gui version
* If opsi-script is called without the command line argument -silent,
so opsi-script checks if it is possible to start the gui version.
If this is possible the gui version (opsi-script-gui) will be started.
* The file opsi-script-nogui you will find only for backward compatibilty reasons
as link to opsi-script.
opsi-client-agent (4.1.1.29-1):
* New RPC methods: readConfigFile, getConfig, getConfigValue, setConfigValue
* Fixed RPC method getActiveSessions
* HTTP compression enabled by default
* Improved validation of SSL server certificates
* Information about packages to install in shutdown notifier
* New opsi-notifier fixes communication problems
* opsi-client-kiosk will be installed by the opsi-client-agent if the kiosk was used on that client and is not installed
* opsi-client-kiosk links are not removed anymore by reinstallation of the opsi-client-agent
* The default skin of the popup-notifier has been changed
* Popup messages can now be appended or prepended to existing messages
* Further optimizations in the area of WAN/PVN in combination with changing depots
* Defective SQLite databases are automatically regenerated
* Determination of the IP address and default gateway now more reliably
* opsiclientd_rpc: new commandline interface, use as admin without password
* action_processing_cancel_counter is now event specific
* New naming scheme for rotated log files
* Events will be disabled if the referenced precondition is not defined
opsi-directory-connector (36.0-1):
With this release the support for ldap3 Version 2 is fixed.
Ubuntu and Debian had a major version jump of this module
within the same distro-Release, which is unusual.
Univention UCS distributes (as of now) this module in Version 1.4.0-1.
These two versions are not compatible.
Because of that, the opsi-directory-connector is now released as binary-bundle
which brings its own variant of the current ldap3 module.
This way the opsi-directory-connector is now independent of the distro-repositories.
With this release we conclude a longer testing phase, during which we checked
the many different settings in which opsi-directory-connector can be applied.
We want to thank our partners and clients who helped us with tests and feedback
and we want to apologize for the delay which formed as for some settings,
the problems were not so easy to solve.
Nevertheless we suggest and encourage you to manually test the new
opsi-directory-connector version thoroughly to ensure that the synchronization
works properly in your environment.
opsi-directory-connector (39.0-1):
With version 39, the opsi-directory-connector, uses the loglevels 0-9 common with OPSI and no longer the Python loglevels.
There are two new configuration parameters in the *behaviour* area:
- `group_description` determines with which information the group description in OPSI should be filled. Possible values are:
- `dn`: The dn of the group will be stored in OPSI as group description.
- `directory`: The group description is read from the `description` field of the directory group.
- If the value is not set or set differently, the description is filled with the name of the group as in previous versions.
- `override_root_dir`: If `override_root_dir` is set to `true`, the groups are created in OPSI under ` GROUPS`. This option is only valid for `group_handling` `ucsatschool`. The default is `true` to mimic the previous behavior. If `override_root_dir` is set to `false` and the groups are thus stored in OPSI under `DIRECTORY`, it should be ensured that each school computer has only been assigned to one room.
Bugfix: An error in `group_handling` `ucsatschool` with empty descriptions of rooms and schools has been fixed.
Updated packages in stable:
Windows Localboot Pakete:
* hwaudit (4.1.1.4-1)
* opsi-script-beautifier (4.1.0.4-1)
* opsi-script-test (4.12.4.12-1)
* opsi-wim-capture (4.1.0.1-9)
* opsi-winst (4.12.4.12-1)
* windows10-upgrade (20.09-3)
* opsi-client-agent (4.1.1.29-1)
Linux Localboot Pakete:
* opsi-linux-client-agent (4.1.1.9-2)
* l-system-update (4.1.0.0-4)
opsi-local-image Localboot Pakete:
* opsi-local-image-wim-capture (4.1.0.1-9)
Windows Netboot Pakete:
* windows NT6 (4.1.0.2-7)
* hwinvent (4.1.0.1-3)
Linux Netboot Pakete:
* centos70 (4.1.0.2-2)
* centos8 (4.1.0.2-2)
* debian10 (4.1.0.6-3)
* debian9 (4.1.0.5-2)
* debian (4.1.0.4-1)
* opensusel15-1 (4.1.0.3-2)
* opensusel15-2 (4.1.0.3-2)
* redhat70 (4.1.0.2-2)
* redhat8 (4.1.0.2-2)
* sles12* (4.1.0.2-2)
* ubuntu (4.1.0.4-5)
* ubuntu16-04 (4.1.0.3-2)
* ubuntu18-04 (4.1.0.5-2)
* ubuntu20-04 (4.1.0.5-2)
* ucs44 (4.1.0.3-3)
opsi-local-image Netboot Pakete:
* opsi-local-image-backup (4.1.0.1-4)
* opsi-local-image-delimage (4.1.0.1-5)
* opsi-local-image-prepare (4.1.0.1-4)
* opsi-local-image-restore (4.1.0.1-4)
* windows NT6: opsi-local-image-win* (4.1.0.2-7)
* windows NT6: opsi-vhd-win10-x64 (4.1.0.2-7)
opsi Server Pakete:
* opsi-script (4.12.4.12-1)
* opsi-linux-bootimage (20201215-1)
* opsi-tftp (5.2.8-67)
opsi Manuals:
* opsi-getting-started-v4.1
* opsi-manual-v4.1
* opsi-supportmatrix
* opsi-winst / opsi-script-manual
* opsi-winst-reference-card-en
Updated packages in testing:
Windows localboot
* opsi-script-test (4.12.4.13-1)
* opsi-winst (4.12.4.13-1)
* l-opsi-server (4.2.0.2-4)
* opsi-linux-client-agent (4.1.1.11-1)
* windows NT6 (4.1.0.2-9)
* windows NT6: opsi-local-image-win* (4.1.0.2-9)
* ubuntu (4.1.0.4-6)
opsi Server Pakete:
* opsi-directory-connector (39-1)
With kind regards
Changelogs:
l-system-update 4.1.0.0-4 stable urgency=low
* corrected typo
-- Mathias Radtke <m.radtke@uib.de> Thu, 04 Feb 2021 13:34:00 +0100
l-system-update 4.1.0.0-3 stable urgency=low
* new property : allow_reboot
* check if reboot is needed
* changelog.txt created
-- d.oertel <d.oertel@uib.de> Mon, 01 Feb 2021 15:00:00 + 0100
windows10-upgrade (20.09-3) experimental; urgency=low
* IMPORTANT: Requires opsi-winst version 4.12.4.4-1 or higher
* IMPORTANT: Requires opsi-client-agent 4.1.1.16-2 or higher
* Changes to the handling of Win7/8/8.1 -> Win10 Upgrades:
* Since the opsiclientd in opsi-client-agent version 4.1.1.x-x is no longer OS specific all code for repairing the opsiclientd after a successful upgrade from pre
Win10 versions has been removed
* The symlink to the servers opsi-client-agent folder has been removed
* Running opsi-package-manager -i windows10-upgrade_20.09-3.opsi --suppress-pcf-generation is no longer needed for the WAN/VPN mode to work correctly when upgrading
from a pre Win10 version
* Moved the handling of Windows 10 OOBE Privacy Experience from the setup-local script to Sub_Prepare_AutoLogon so it will be applied before the opsiSetupUser is created
* Disabled Windows 10 First Logon Animation
* Changed some variable names
* Made some changes to the code that extracts the release id from the installfiles folder if automode = true
* Previous versions of the package expected the release id trailing directly after 'installfiles' with no further characters allowed afterwards (i.e. installfiles2009)
* Now the folder name can contain additional information as well (i.e. installfiles2009-32Bit-en)
* The release id can be placed anywhere after installfiles (i.e. installfiles-32Bit-en-2009)
* The folder name still needs to start with installfiles though! A format like 32Bit-en-2009-installfiles is not allowed!
* Added Registry_Enable_Input to update script
* In case the upgrade fails with debug=false set (keyboard and mouse disabled) and somehow the cleanup stage does not run afterwards you can set debug=true and run
the update script to enable the input again
* Increased the required available free space to 20 GB
* Updated wimlib to version 1.13.3
-- Matthias Knauer <m.knauer@uib.de> Mon, 11 Jan 2021 11:11:11 +0000
windows10-upgrade (20.09-2) experimental; urgency=low
* IMPORTANT: Requires opsi-client-agent 4.1.0.0-47 or higher
* IMPORTANT: Changes to the handling of Win7 -> Win10 Upgrades:
* The opsi-client-agent folder is now a symlink to the servers opsi-client-agent folder
* For WAN/VPN mode to work correctly the following command needs to be run manually after the package installation:
* opsi-package-manager -i windows10-upgrade_20.09-2.opsi --suppress-pcf-generation
* Changed the function to generate the opsiSetupUser password from randomstr to randomstrWithParameters to allow for customization of password parameters
* Added variable $RandomStrDigits$ for password customization
* Added variable $RandomStrLowerCases$ for password customization
* Added variable $RandomStrMinLength$ for password customization
* Added variable $RandomStrSpecialChars$ for password customization
* Added variable $RandomStrUpperCases$ for password customization
* These variables can be customized in the declarations.opsiinc file
* Added /Y parameter to the NET USER command that creates the opsiSetupUser user to support passwords that are longer than 14 characters
* Moved the re-enabling keyboard and mouse input section to stage 4 to prevent user intervention
-- Matthias Knauer <m.knauer@uib.de> Tue, 10 Nov 2020 11:11:11 +0000
opsi-template-with-admin (4.1.0.0-4) stable; urgency=low
* Requires opsi-winst version 4.12.4.4-1
* Changed the function to generate the opsiSetupAdmin password from randomstr to randomstrWithParameters to allow for customization of password parameters
* Added /Y parameter to the NET USER command that creates the opsiSetupAdmin user to support passwords that are longer than 14 characters
* Moved the re-enabling keyboard and mouse input section to stage 3 to prevent user intervention
-- matthias knauer <m.knauer@uib.de> Thu, 12 Nov 2020 11:11:11 +0000
centos70 (4.1.0.2-2) testing; urgency=low
* cpio now running without --no-absolute-filenames
-- Mathias Radtke <m.radtke@uib.de> Wed Dec 02 12:30:00 2020 +0100
centos70 (4.1.0.2-1) testing; urgency=low
* performing hwaudit
-- Mathias Radtke <m.radtke@uib.de> Thu Nov 26 10:30:00 2020 +0100
centos70 (4.1.0.1-2) testing; urgency=low
* made usage of kexec more versatile
-- Mathias Radtke <m.radtke@uib.de> Wed Oct 28 13:54:51 2020 +0200
centos8 (4.1.0.2-2) testing; urgency=low
centos8 (4.1.0.2-1) testing; urgency=low
centos8 (4.1.0.1-5) testing; urgency=low
* using shadow_password_hash function to encode passwords
-- Mathias Radtke <m.radtke@uib.de> Mon Nov 02 10:15:00 2020 +0100
centos8 (4.1.0.1-4) testing; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Wed Oct 28 13:54:51 2020 +0100
centos8 (4.1.0.1-3) stable; urgency=low
* added 'partition_disk' property
* kickstart: removed multilib file
-- Mathias Radtke <m.radtke@uib.de> Tue Oct 20 10:00:00 2020 +0200
centos8 (4.1.0.1-2) stable; urgency=low
* fixed bug with custom kickstart profile
-- Mathias Radtke <m.radtke@uib.de> Tue Oct 06 10:36:00 2020 +0200
centos8 (4.1.0.1-1) stable; urgency=low
* python3 compatible code base
-- Mathias Radtke <m.radtke@uib.de> Mon Jul 20 18:31:44 2020 +0200
debian (4.1.0.3-4) testing; urgency=low
* corrected intendation error
-- Mathias Radtke <m.radtke@uib.de> Thu Nov 26 11:48:00 2020 +0100
debian (4.1.0.3-3) testing; urgency=low
* fixed error when writing grub config
-- Mathias Radtke <m.radtke@uib.de> Tue Nov 24 15:40:00 2020 +0100
debian (4.1.0.3-2) testing; urgency=low
* fixed error with debootstrap
* fixed error when creating fstab
-- Mathias Radtke <m.radtke@uib.de> Wed Nov 18 10:45:00 2020 +0100
debian (4.1.0.3-1) stable; urgency=low
debian10 (4.1.0.6-2) testing; urgency=low
debian10 (4.1.0.6-1) testing; urgency=low
debian10 (4.1.0.5-3) testing; urgency=low
debian9 (4.1.0.5-2) testing; urgency=low
debian9 (4.1.0.5-1) testing; urgency=low
* corrected username setting
debian9 (4.1.0.4-3) testing; urgency=low
debian9 (4.1.0.4-2) testing; urgency=low
opensusel15-2 (4.1.0.3-2) testing; urgency=low
opensusel15-2 (4.1.0.3-1) testing; urgency=low
opensusel15-2 (4.1.0.2-3) testing; urgency=low
opensusel15-2 (4.1.0.2-2) testing; urgency=low
opsi-local-image-backup (4.1.0.1-4) stable; urgency=low
* removed install_localbootimage references
-- Mathias Radtke <m.radtke@uib.de> Tue 17 Nov 2020 12:24:00 +0100
opsi-local-image-backup (4.1.0.1-3) stable; urgency=low
* opsisetuplib.py: filtering empty values in blkid output
-- Mathias Radtke <m.radtke@uib.de> Tue 03 Nov 2020 12:24:00 +0100
opsi-local-image-backup (4.1.0.1-2) stable; urgency=low
* opsisetuplib.py: function checkModules now works properly w
ith python3 based bootimage
-- Mathias Radtke <m.radtke@uib.de> Mon 06 Oct 2020 12:00:00 +
0200
opsi-local-image-delimage (4.1.0.1-5) stable; urgency=low
opsi-local-image-delimage (4.1.0.1-4) stable; urgency=low
opsi-local-image-delimage (4.1.0.1-3) stable; urgency=low
* opsisetuplib.py: function checkModules now works properly with python3 based bootimage
-- Mathias Radtke <m.radtke@uib.de> Mon 06 Oct 2020 12:00:00 +0200
opsi-local-image-delimage (4.1.0.1-2) stable; urgency=low
* updating available backup space on product opsi-local-image-backup property "free_on_backup"
-- Mathias Radtke <m.radtke@uib.de> Fri 18 Sep 2020 10:40:00 +0200
opsi-local-image-prepare (4.1.0.1-4) stable; urgency=low
opsi-local-image-prepare (4.1.0.1-3) stable; urgency=low
opsi-local-image-prepare (4.1.0.1-2) stable; urgency=low
0200
opsi-local-image-restore (4.1.0.1-4) stable; urgency=low
opsi-local-image-restore (4.1.0.1-3) stable; urgency=low
opsi-local-image-restore (4.1.0.1-2) stable; urgency=low
0200
l-opsi-server (4.2.0.2-4); testing; urgency=low
* SLES specific changes
-- Mathias Radtke <m.radtke@uib.de> Tue, 02 Feb 2021 11:20:00 +0100
l-opsi-server (4.2.0.2-3); testing; urgency=low
* opsi 4.2: installing opsi-server-full
-- Mathias Radtke <m.radtke@uib.de> Mon, 01 Feb 2021 14:16:00 +0100
l-opsi-server (4.2.0.2-2); testing; urgency=low
* opsi 4.1: adds mariadb repository on RHEL7 and CentOS 7
-- Mathias Radtke <m.radtke@uib.de> Tue, 26 Jan 2021 08:45:00 +0100
l-opsi-server (4.2.0.2-1); testing; urgency=low
* now detects SLES 15 SP3
* now detects openSUSE Leap 15-3
-- Mathias Radtke <m.radtke@uib.de> Fri, 08 Jan 2021 08:45:00 +0100
l-opsi-server (4.2.0.1-4); testing; urgency=low
* enabling and starting grafana
* running opsiconfd setup to enable opsiadmin page
-- Mathias Radtke <m.radtke@uib.de> Thu, 07 Jan 2021 15:23:00 +0100
opsi-local-image (4.1.0.2-7) testing; urgency=low
* removed install_local_bootimage property
-- Mathias Radtke <m.radtke@uib.de> Mon Nov 16 16:24:40 2020 +0200
opsi-local-image (4.1.0.2-6) testing; urgency=low
* nt6.py: corrected decoding when reading cmdline
-- Mathias Radtke <m.radtke@uib.de> Tue Nov 3 13:49:47 2020 +0200
opsi-local-image (4.1.0.2-5) testing; urgency=low
* nt6: fixed error on parsing sgdisk output
* opsisetuplib: fixed Exceptions when looking for CurrentBoot
-- Mathias Radtke <m.radtke@uib.de> Thu Oct 22 13:42:48 2020 +0200
redhat70 (4.1.0.2-2) testing; urgency=low
redhat70 (4.1.0.2-1) testing; urgency=low
redhat70 (4.1.0.1-2) testing; urgency=low
redhat8 (4.1.0.2-2) testing; urgency=low
redhat8 (4.1.0.2-1) testing; urgency=low
redhat8 (4.1.0.1-3) testing; urgency=low
redhat8 (4.1.0.1-2) testing; urgency=low
redhat8 (4.1.0.1-1) stable; urgency=low
redhat8 (4.1.0.0-2) testing; urgency=low
* not using --multilib in kickstart
-- Mathias Radtke <m.radtke@uib.de> Fri Aug 16 13:50:00
redhat8 (4.1.0.0-1) testing; urgency=low
* forked from redhat70
-- Mathias Radtke <m.radtke@uib.de> Fri May 31 08:00:00 +0200
sles12 (4.1.0.2-2) testing; urgency=low
sles12 (4.1.0.2-1) testing; urgency=low
sles12 (4.1.0.1-2) testing; urgency=low
ubuntu (4.1.0.4-5) testing; urgency=low
ubuntu (4.1.0.4-4) testing; urgency=low
* security repos also use opsi_online_repsoitory
ubuntu (4.1.0.4-3) testing; urgency=low
* ubuntu: added patch to use netifnames by SirTux
-- Mathias Radtke <m.radtke@uib.de> Mon Oct 26 15:19:00 2020 +0100
ubuntu16-04 (4.1.0.3-2) testing; urgency=low
ubuntu16-04 (4.1.0.3-1) testing; urgency=low
ubuntu16-04 (4.1.0.2-3) testing; urgency=low
ubuntu18-04 (4.1.0.5-2) testing; urgency=low
ubuntu18-04 (4.1.0.5-1) testing; urgency=low
ubuntu18-04 (4.1.0.4-3) testing; urgency=low
ubuntu20-04 (4.1.0.5-2) testing; urgency=low
ubuntu20-04 (4.1.0.5-1) testing; urgency=low
ubuntu20-04 (4.1.0.4-3) testing; urgency=low
ucs44 (4.1.0.3-3) testing; urgency=low
ucs44 (4.1.0.3-2) testing; urgency=low
* rc.local: now install pkg-config before installing opsi-linux-client-agent
-- Mathias Radtke <m.radtke@uib.de> Mon Nov 30 17:17:00 +0100
ucs44 (4.1.0.3-1) testing; urgency=low
* updated to ucs 4.4-6
-- Mathias Radtke <m.radtke@uib.de> Fri Nov 27 14:00:00 2020 +0100
ucs44 (4.1.0.2-2) testing; urgency=low
ucs44 (4.1.0.2-1) stable; urgency=low
windows (4.1.0.2-7) testing; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Mon Nov 16 16:24:26 2020 +0200
windows (4.1.0.2-6) testing; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Tue Nov 3 13:49:38 2020 +0200
windows (4.1.0.2-5) testing; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Thu Oct 22 13:42:36 2020 +0200
wipedisk (1.3-1) stable; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Wed Oct 07 2020 14:00:00 +0200
wipedisk (1.2-1) stable; urgency=low
* install3264 added as pxeConfigTemplate
-- Mathias Radtke <m.radtke@uib.de> Mon Aug 17 2020 12:30:00 +0200
opsi-linux-client-agent (4.1.1.11-1) testing; urgency=medium
* updated opsiclientd to 4.2.0.66
* differentiate between system with or without gui to install only necessary packages
-- Nils Doerrer <n.doerrer@uib.de> Tue, 02 Feb 2021 15:00:00 + 0100
opsi-linux-client-agent (4.1.1.10-1) testing; urgency=medium
* updated opsi-script to 4.12.4.13
* changed uninstall to preserve opsi-script if it was installed as server-package
-- Nils Doerrer <n.doerrer@uib.de> Tue, 26 Jan 2021 10:00:00 + 0100
* opsi-deploy-client-agent is now packed as binary, so no external dependencies needed
-- Nils Doerrer <n.doerrer@uib.de> Tue, 19 Jan 2021 09:00:00 + 0100
opsi-linux-client-agent (4.1.1.9-1) testing; urgency=medium
* updated opsi-script to 4.12.4.12
* updated opsi-notifier to 4.1.1.6
-- d.oertel <d.oertel@uib.de> Thu, 17 Dec 2020 15:00:00 + 0100
opsi-linux-client-agent (4.1.1.8-1) testing; urgency=medium
* exchanged gtk2test for opsi-laz-gui-test
* updated opsiclientd to 4.2.0.53
-- Nils Doerrer <n.doerrer@uib.de> Thu, 17 Dec 2020 13:00:00 + 0100
opsi-linux-client-agent (4.1.1.7-1) testing; urgency=medium
* updated opsi-script to 4.12.4.10
* updated opsi-client-systray to 4.1.2.2
* updated opsi-notifier to 4.1.1.5
-- Nils Doerrer <n.doerrer@uib.de> Fri, 11 Dec 2020 15:00:00 + 0100
opsi-winst/opsi-script (4.12.4.13) stable; urgency=low
* osfunc: new: TUibIniFile.ReadRawSection (by j.laajili)
* new function getSectionFromIniFile based on ReadRawSection (by j.laajili)
* osxmlsections: fix for xml2 delnode
-- d.oertel <d.oertel@uib.de> Mon, 25 Jan 2021 15:00
opsi-winst/opsi-script (4.12.4.12) stable; urgency=low
* repair center batchgui on screen
* osregex: another empty string regex test
* license functions: opsiserviceuser if possible
* linux: shellBatch implemented as shellInAnIcon
* macos: osfunclin: getmyipbytarget: use path to ip command
* macos: runningWithGui also working for macos
* update opsi-script-lib
* update ssl libraries to 1.0.2u
-- d.oertel <d.oertel@uib.de> Wed, 16 Dec 2020 15:00
opsi-winst/opsi-script (4.12.4.11) stable; urgency=low
* files: copy: deny-list with '.DS_Store'
* files: on 'permission denied' call handle.exe if existing in opsi-script directory
* dosInAnIcon: if win7 and no new Arguments then call runAndCaptureOut
-- d.oertel <d.oertel@uib.de> Mon, 14 Dec 2020 15:00
opsi-winst/opsi-script (4.12.4.10) experimental; urgency=low
* macos: modify locale path for opsi-script-gui.app
* macos / linux: oscheck_gui_startable: kill opsi-laz-gui-test if not terminated
* osregex: filter empty input to avoid execeptions
-- d.oertel <d.oertel@uib.de> Thu, 26 Nov 2020 15:00
opsi-winst/opsi-script (4.12.4.9) experimental; urgency=low
* GetSectionFromIniFile: remove encoding transformation (windows only)
-- j.werner <j.werner@uib.de> Wed, 25 Nov 2020 17:39
opsi-winst/opsi-script (4.12.4.8) experimental; urgency=low
* isRegexMatch: checks if string is NOT empty before exec is executed
catchs exceptions
-- j.werner <j.werner@uib.de> Tue, 24 Nov 2020 14:55
opsi-winst/opsi-script (4.12.4.6) experimental; urgency=low
* import osprocesses
* call of opsi-laz-gui-test in extra log: ogdatei.StandardMainLogPath+'opsi-script-gui-test.log'
-- d.oertel <d.oertel@uib.de> Wed, 04 Nov 2020 15:00
opsi-winst/opsi-script (4.12.4.5) experimental; urgency=low
* the one and only project file is now opsi-script.lpi
you hav to switch zhe build mode for differen archtictures (win / mac / lin) (gui)
* the opsi-script nogui version is now opsi-script
* the opsi-script gui version is now opsi-script-gui
* opsi-script tests via opsi-laz-gui-test if a gui can be used
and if yes calls opsi-script-gui (via execv)
opsi-script-test (4.12.4.13-1) stable; urgency=low
* getsectionfrominifile
* patches (inifile) tests now in sub script patchesini.opsiscript
* switch loglevel to 5 on alltests=on
* new xml2 test delnodestrict
-- detlef oertel <d.oertel@uib.de> Tue, 29 Dec 2020 15:00:00 +0200
opsi-script-test (4.12.4.12-1) stable; urgency=low
* new bool property test_experimental
* set GetSectionFromInifile as test_experimental
* regex: more tests with empty strings
* files: add bir dir zip / unzip test
* opsi-script-test-helper update 4.1.0.2 (Linux / Windows / Mac)
* licensetests: use %opsiServiceUser%
* string tests: getmyip & co: fix error handling
* new property: test_speed (deault=false)
-- detlef oertel <d.oertel@uib.de> Wed, 16 Dec 2020 15:00:00 +0200
opsi-script-test (4.12.4.8-1) stable; urgency=low
* corrected wrong variable names in definition (test1list1 to testlist1, etc.)
* add missing definitions for stringlist (test1list1, etc.)
* add missing variable definition ($CompValue1$)
* fix dummy.ini encoding
* modified standalone test GetSectionFromInifile.opsiscript
-- jan werner <j.werner@uib.de> Wed, 25 Nov 2020 17:17:00 +0200
opsi-script-test (4.12.4.5-1) stable; urgency=low
* add test for GetSectionFromInifile
* add test for areListsEqual
-- jinene laajili <j.laajili@uib.de> Tue, 13 Nov 2020 15:00:00 +0200
opsi-script-test (4.12.4.4-2) stable; urgency=low
* fixes for Linux in patchhost tests
* Linux opsi-script-test-helper update 4.1.0.1
-- detlef oertel <d.oertel@uib.de> Tue, 03 Nov 2020 15:00:00 +0200
opsi-script-test (4.12.4.4-1) stable; urgency=low
* add isValidFQDN test
* deactivate assessment of constant %IPAddress%
* check getmyipbytarget against ipconfig (and not against %IPAddress%)
* opsi-script-test-helper update 4.1.0.1
-- detlef oertel <d.oertel@uib.de> Tue, 13 Oct 2020 15:00:00 +0200
opsi-script-test (4.12.4.1-1) stable; urgency=low
opsi-script-beautifier (4.1.0.4-1) stable; urgency=medium
* fix in: gui: added -dGUI Option to avoid writeln while GUI
-- d.oertel <d.oertel@uib.de> Wed , 16 Dec 2020 15:00:00 + 0100
opsi-script-beautifier (4.1.0.3-1) stable; urgency=medium
* gui: added -dGUI Option to avoid writeln while GUI
-- d.oertel <d.oertel@uib.de> Tue , 15 Dec 2020 15:00:00 + 0100
opsi-script-beautifier (4.1.0.2-1) stable; urgency=medium
* fix for sub and other primary sections
* added gui version
-- d.oertel <d.oertel@uib.de> Tue , 09 Nov 2020 15:00:00 + 0100
opsi-script-beautifier (4.1.0.1-1) stable; urgency=medium
* look for configuration file (beautify.ini) in program directory by default
* use last param as file argument by default
* -dOPSI -dOPSI_AS_USER
-- d.oertel <d.oertel@uib.de> Tue, 07 Apr 2020 15:00 +0100
opsi-setup-detector (4.1.0.17) stable; urgency=low
* fix on double setup
* fix fot translation of osdcheckentriesdlg
-- Detlef Oertel <d.oertel@uib.de> Tue, 10 Nov 2020 : 15:00:00 +0200
opsi-setup-detector (4.1.0.16) stable; urgency=low
* icon selection integrated (by a.schmitz)
* translations updated
* Unix: fix rights in utils dir
* set inital path to icon dir
* fix write config_version
* set config_version to 4.1.0
* fixes on icon collection diplsy while loading
-- Detlef Oertel <d.oertel@uib.de> Fri, 19 Jun 2020 : 15:00:00 +0200
opsi-wim-capture (4.1.0.1-9) stable; urgency=low
* capture.opsiscript: more Warnings on target file not found
-- detlef oertel <d.oertel@uib.de> Tue, 15 Dec 2020 15:00:00 +0000
opsi-linux-bootimage (20201215-1) testing; urgency=medium
* kernel 5.9.14
* update python-opsi (4.1.97-1)
* no more downgraded sfdisk
-- Mathias Radtke <m.radtke@uib.de> Tue, 15 Dec 2020 09:19:08 +0100
opsi-linux-bootimage (20201120-1) testing; urgency=medium
* removed references to WiFi bootimage
* adapted Microsoft Dock patch to current 5.9.3
-- Mathias Radtke <m.radtke@uib.de> Fri, 20 Nov 2020 15:33:42 +0100
opsi-linux-bootimage (20201105-1) testing; urgency=medium
* kernel 5.9.3
-- Mathias Radtke <m.radtke@uib.de> Thu, 05 Nov 2020 09:55:44 +0100
opsi-tftp-hpa (5.2.8-56) testing; urgency=medium
* spec: only using inetd on RHEL/CENTOS and OpenSUSE
-- Mathias Radtke <m.radtke@uib.de> Tue, 15 Dec 2020 12:17:01 +0100
opsi-tftp-hpa (5.2.8-55) testing; urgency=medium
* added xinetd again
-- Mathias Radtke <m.radtke@uib.de> Tue, 08 Dec 2020 14:55:23 +0100
opsi-tftp-hpa (5.2.8-54) stable; urgency=medium
* removed xinetd references
-- Mathias Radtke <m.radtke@uib.de> Mon, 16 Nov 2020 15:19:03 +0100
opsi-tftp-hpa (5.2.8-53) stable; urgency=medium
* Set default blocksize to 1024
-- Jan Schneider <j.schneider@uib.de> Thu, 05 Nov 2020 15:51:18 +0100
hwaudit (4.1.1.4-1) testing; urgency=medium
* Bugfix: fixed referential integrity bug on Windows 7 in WAN mode.
-- Nils Doerrer <n.doerrer@uib.de> Thu, 17 Dec 2020 15:00:00 +0100
hwaudit (4.1.1.3-1) testing; urgency=medium
* Bugfix: fixed nested system nodes in lshw output
* Feature: added codesigning on windows build
* Feature: use linuxPackageInstall opsiscript method
-- Nils Doerrer <n.doerrer@uib.de> Mon, 14 Dec 2020 12:00:00 +0100
hwaudit (4.1.1.2-1) testing; urgency=medium
* Improvement: restructured wmi-requests to efficiently manage multiple namespaces
* Feature: extended macOS keys in opsihwauditconf
* Feature: added macOS compatibility
* Bugfix: fixed logging format
-- Nils Doerrer <n.doerrer@uib.de> Mon, 16 Nov 2020 10:33:17 +0100
opsi-logviewer (3.1-9) STABLE; urgency=medium
* integrate macOS support
-- detlef oertel <d.oertel@uib.de> Wed, 23 Sep 2019 15:00:00 +0000
m-homebrew 4.1.0.1-1 stable urgency=low
* change from ruby to bash version
-- d.oertel <d.oertel@uib.de> Thu, 31 Dec 2010 15:00:00 + 0100
m-javavm (4.1.0.0-1) stable; urgency=medium
* switch to berw install --cask
* switch install generic actual sapmachine-sdk
-- d.oertel <d.oertel@uib.de> Thu, 31 Dec 2020 15:00:00 +0100
opsi-mac-client-agent (4.1.1.4-1) stable; urgency=medium
* opsi-script / opsi-script-gui update to 4.12.4.12
* update opsiclientd to 4.2.0.53
* update opsi-notifier to 4.1.1.6
-- d.oertel <d.oertel@uib.de> Mon, 21 Dec 2020 15:00:00 + 0100
opsi-mac-client-agent (4.1.1.3-1) stable; urgency=medium
* opsi-script / opsi-script-gui update to 4.12.4.10
* postinst hardlink opsi-script to opsi-script-nogui
* fix font defaults in notifier event.ini
* add opsi-laz-gui-test 4.1.0.0
* update opsiclientd to 4.2.0.36
* add opsi-client-systray 4.1.2.2
* add opsiclientd_event_starter 4.1.01
* update opsi-notifier to 4.1.1.5
* tests with on_shutdown
* do not recursive chown opsisetupadmin:admin /var/opsisetupadmin
(this would try to chown the mounted opsi_depot share)
* added complete uib opsi-script lib
-- d.oertel <d.oertel@uib.de> Sun, 06 Dec 2020 15:00:00 + 0100
opsi-client-kiosk (4.1.1.8-8) experimental; urgency=low
slightly cleanup setup32.opsiscript
-- Jan Werner j.werner@uib.de Fri, 18 Dec 2020 13:11:00 +0000
opsi-client-kiosk (4.1.1.8-7) experimental; urgency=low
change behavour if files are copied which are in use: now a reboot is requested
-- Jan Werner j.werner@uib.de Thu, 17 Dec 2020 17:26:00 +0000
opsi-client-kiosk (4.1.1.8-6) experimental; urgency=low
Adminmode: fix issue that Icon/Screenshot image was deleted if the same image was used for different products and than for one of these products the image was changed
-- Jan Werner j.werner@uib.de Wed, 17 Dec 2020 09:28:00 +0000
opsi-client-kiosk (4.1.1.7-6) experimental; urgency=medium
remove set kiosk to setup part from postinst (functionality now coverd by opsi-client-agent package >= 4.1.1.18-1)
-- Jan Werner j.werner@uib.de Wed, 14 Dec 2020 15:19:00 +0000
opsi-client-kiosk (4.1.1.7-3) experimental; urgency=low
small fixes in skin (header title/kiosk.icon are now displayed correct)
if kiosk migration from client-agent package occured (folder migration exist in the opsi-client-kiosk folder on depot) set the opsi-client-kiosk to setup for all clients where software-on-demand.active=true.
-- Jan Werner j.werner@uib.de Thu, 03 Dec 2020 15:33:00 +0000
python-opsi (4.1.1.97-1) testing; urgency=medium
* Validation of filters and attributes in backend getObject methods to prevent SQL injection attacks
* OPSI.System.Posix: removed sfdisk downgrade functions
-- Jan Schneider <j.schneider@uib.de>, Mathias Radtke <m.radtke@uib.de> Wed, 14 Dec 2020 12:30:00 +0000
opsi-configed (4.1.9.8.3-4) TESTING; urgency=medium
* script bugfixes
-- r.roeder <r.roeder@uib.de> Tue, 05 Jan 2020 17:10:40 +0100
opsi-configed (4.1.9.8.3-3) TESTING; urgency=medium
* script bugfixes
-- r.roeder <r.roeder@uib.de> Tue, 01 Dec 2020 12:10:40 +0100
opsi-configed (4.1.9.8.3-2) TESTING; urgency=medium
* integrating macos variant
opsi-configed (4.1.9.8.3-1) TESTING; urgency=medium
* icon and text editing
opsi-configed (4.1.9.8.1-1) TESTING; urgency=medium
* invert selection function for host table
opsi-configed (4.1.9.7.2-1) TESTING; urgency=medium
* improving logging for inconsistent swaudit entries
-- r.roeder <r.roeder@uib.de> Tue, 24 Nov 2020 16:10:40 +0100
opsi-configed (4.1.9.7.1-1) TESTING; urgency=medium
* suppressing underscores at the end of group names in client tree
opsi-configed (4.1.9.6.1-ff) EXPERIMENTAL; urgency=medium
* new construction of windows/linux/macos cases
-- r.roeder <r.roeder@uib.de> Fr, 20 Nov 2020 16:10:40 +0100
opsi-configed (4.1.9.6.1-2) EXPERIMENTAL; urgency=medium
* custom java for linux
-- r.roeder <r.roeder@uib.de> Mon, 02 Nov 2020 16:10:40 +0100
opsi-configed (4.1.9.6.1-1) EXPERIMENTAL; urgency=medium
* Search, reload and group functions for netboot products introduced
opsi-configed (4.1.9.5.5-1) TESTING; urgency=medium
opsi-configed (4.1.9.5.5-2) EXPERIMENTAL; urgency=medium
* old version of setup32.ins restored
-- r.roeder <r.roeder@uib.de> Thu, 15 Oct 2020 16:10:40 +0100
* bugs in GlobalSoftwareInfo layout repaired
opsi-configed (4.1.9.5.4-2) TESTING; urgency=medium
* updated translation files for French and English
opsi-configed (4.1.9.5.3-2) TESTING; urgency=medium
* removing old fallback_tlsv and replacing it by fallback__tlsv as well in the setup script
-- r.roeder <r.roeder@uib.de> Mon, 28 Sep 2020 12:10:40 +0100
opsi-configed (4.1.9.5.3) TESTING; urgency=medium
* internal updating of the new tables
-- r.roeder <r.roeder@uib.de> Tue, 22 Sep 2020 12:10:40 +0100
opsi-configed (4.1.9.5.1) EXPERIMENTAL; urgency=medium
* licence management: special tables for collective assignment of similar
sw-ids to a licencepool
-- r.roeder <r.roeder@uib.de> Wed, 26 Aug 2020 12:10:40 +0100
opsi-configed (4.1.9.4.0-1) EXPERIMENTAL; urgency=medium
* trying to fix a NPE which seems to be caused by a thread problem
* starting with a bundle of new features for software audit table in license
management
opsi-configed (4.1.9.3.3-2) TESTING; urgency=medium
* bundled jre amazon-corretto-8.262.10.1
* and sapmachine-jre-11.0.8_windows-x64_bin
* fixes #4495 installation opsi-configed auf win32: potentieller reboot loop
* on linux make a check if java is installed before installation of openjdk
-- b.wolf <b.wolf@uib.de> Mon, 27 Jul 2020 11:40:46 +0100
winexe (4.13.0.1-1) testing; urgency=medium
* working on all opsi 4.2 supported distributions
-- Mathias Radtke <m.radtke@uib.de> Fri, 08 Jan 2021 08:47:40 +0100
winexe (4.13.0.0-1) testing; urgency=medium
* updated to samba source to 4.13-stable
-- Mathias Radtke <m.radtke@uib.de> Fri, 18 Dec 2020 15:39:06 +0100
opsi-client-agent (4.1.1.29-1) stable; urgency=low
* Update opsiclientd to 4.2.0.66
-- Jan Schneider <j.schneider@uib.de> Wed, 03 Feb 2021 12:07:00 +0100
opsi-client-agent (4.1.1.28-1) stable; urgency=low
* Update opsiclientd to 4.2.0.65
-- Jan Schneider <j.schneider@uib.de> Mon, 26 Jan 2021 23:50:00 +0100
opsi-client-agent (4.1.1.27-1) stable; urgency=low
* Update opsiclientd to 4.2.0.64
-- Jan Schneider <j.schneider@uib.de> Mon, 21 Jan 2021 11:12:00 +0100
opsi-client-agent (4.1.1.26-1) stable; urgency=low
* Update opsiclientd to 4.2.0.63
-- Jan Schneider <j.schneider@uib.de> Mon, 18 Jan 2021 16:45:00 +0100
opsi-client-agent (4.1.1.25-1) stable; urgency=low
* Update opsiclientd to 4.2.0.62
-- Jan Schneider <j.schneider@uib.de> Mon, 13 Jan 2021 22:32:00 +0100
opsi-client-agent (4.1.1.24-1) stable; urgency=low
* Update opsiclientd to 4.2.0.61
* Update opsi-winst to 4.12.4.12
* Remove opsiservicecall_setGeneralConfigValue_clientconfig_configserver_url
-- Jan Schneider <j.schneider@uib.de> Mon, 11 Jan 2021 10:21:00 +0100
opsi-client-agent (4.1.1.23-1) stable; urgency=low
* Update opsiclientd to 4.2.0.59
-- Jan Schneider <j.schneider@uib.de> Mon, 28 Dec 2020 11:11:00 +0100
opsi-client-agent (4.1.1.22-1) stable; urgency=low
* Update opsiclientd to 4.2.0.58
-- Jan Schneider <j.schneider@uib.de> Sat, 19 Dec 2020 18:58:00 +0100
opsi-client-agent (4.1.1.21-1) stable; urgency=low
* Update opsiclientd to 4.2.0.56
* Update kiosk-package to 4.1.1.8-8
-- Jan Schneider <j.schneider@uib.de> Fri, 18 Dec 2020 17:18:00 +0100
opsi-client-agent (4.1.1.20-1) stable; urgency=low
* Update opsiclientd to 4.2.0.55
-- Jan Schneider <j.schneider@uib.de> Thu, 17 Dec 2020 16:58:00 +0100
opsi-client-agent (4.1.1.19-1) stable; urgency=low
* Update opsiclientd to 4.2.0.54
* Update opsi-notifier to 4.1.1.6
* Update kiosk-package to 4.1.1.8-6
-- Jan Schneider <j.schneider@uib.de> Thu, 17 Dec 2020 11:47:00 +0100
opsi-client-agent (4.1.1.18-1) stable; urgency=low
* Update opsiclientd to 4.2.0.51
* Update opsi-notifier to 4.1.1.5
* Update kiosk-package to 4.1.1.7-6
-- Jan Schneider <j.schneider@uib.de> Thu, 10 Dec 2020 17:41:00 +0100
opsi-client-agent (4.1.1.17-2) testing; urgency=low
* Remove kiosk deinstall
-- Jan Schneider <j.schneider@uib.de> Fri, 04 Nov 2020 15:43:00 +0100
opsi-client-agent (4.1.1.17-1) testing; urgency=low
* Update opsiclientd to 4.2.0.48
-- Jan Schneider <j.schneider@uib.de> Tue, 01 Nov 2020 22:15:00 +0200
opsi-directory-connector (36.0-1) testing; urgency=medium
* ldap3v2 fix
-- Fabian Kalweit <f.kalweit@uib.de> Tue, 1 Dez 2020 08:04:48 +0200
opsi-directory-connector (35.0-1) testing; urgency=medium
* automated build process
* updated to ldap3 2
-- Nils Doerrer <n.doerrer@uib.de> Fri, 13 Nov 2020 08:04:48 +0200
opsi-directory-connector (34-1) testing; urgency=medium
* Excluded schema check for default attributes (ucs-fix)
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 10 Nov 2020 21:43:42 +0100
opsi-directory-connector (33-1) testing; urgency=medium
* excluded schema checks for customAttributes
* excluded reference elements, fixed dictionary handling
-- Nils Doerrer <n.doerrer@uib.de> Mon, 09 Nov 2020 14:52:58 +0100
opsi-directory-connector (32-1) testing; urgency=medium
* Excluded identifying attributes from AUTO_ATTRIBUTES_CHECK
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 27 Oct 2020 02:05:55 +0100
hwinvent (4.1.0.1-3) stable; urgendy=low
* corrected typo
-- Mathias Radtke <m.radtke@uib.de> Tue Jan 12 2021 13:30:00 +0100
