SMB1 enebling on windows workstation (winexe)
Verfasst: 26 Okt 2020, 14:32
von nockdown
We have Opsi server 4.0.7.1-1 on Ubuntu server 16.04 with updated winexe 1.00.1-1.
As I understand, winexe is required only during installing the opsi-client-agent to client workstation.
But Microsoft (windows 10) doesn't install SMB1 by default since 2017 year.
Is there some way to install the opsi-client-agent to client workstation without enabling SMB1 on client workstation?
Server role: ROLE_STANDALONE
server max protocol = SMB3
max protocol = SMB3
protocol = SMB3
ServerName ShareName UserName Credential Dialect NumOpens
opsi IPC$ WORKSTATION\user opsi\pcpatch 3.1.1 0
opsi opsi_workbench WORKSTATION\user opsi\pcpatch 3.1.1 0
Re: SMB1 enebling on windows workstation (winexe)
Verfasst: 26 Okt 2020, 15:24
von m.radtke
if your server is up to date you should have gotten the latest winexe provided by us.
However, here it is
https://download.opensuse.org/repositor ... _amd64.deb
Regards
Verfasst: 26 Okt 2020, 15:30
von nockdown
m.radtke,
Thank you very much! I'll try to update winexe package.
Verfasst: 26 Okt 2020, 16:05
von nockdown
I have updated winexe to version 4.8.0.0-44. And I'm getting such error now:
sudo /var/lib/opsi/depot/opsi-client-agent/opsi-deploy-client-agent -v -u "SPEECH.LOC\\username" -f /home/admin/hostname --reboot --smbclient
Password is required for deployment.
Password:
Starting deployment to host u'noname.speech.loc'
Querying for ip address of host u'noname.speech.loc'
Got ip address '192.168.251.206' from syscall
Pinging host '192.168.251.206' ...
Host 192.168.251.206 is up
Getting hardware ethernet address of host u'noname.speech.loc'
Found hardware ethernet address '44:8a:5b:88:c9:a1'
Creating client u'noname.speech.loc'
Testing winexe
Patching config.ini
Copying installation files
Deployment to u'noname.speech.loc' failed: Command '/usr/bin/smbclient //noname.speech.loc/c$ -U 'SPEECH.LOC\username%*** confidential ***' -c 'prompt; recurse; md tmp; cd tmp; md opsi-client-agent_inst; cd opsi-client-agent_inst; mput files; mput utils; cd files\opsi\cfg; lcd /tmp; put CmI9Iy9VgJ_config.ini config.ini; exit;'' failed (1):
WARNING: The "syslog" option is deprecated
protocol negotiation failed: NT_STATUS_CONNECTION_RESET
Verfasst: 27 Okt 2020, 04:31
von SisterOfMercy
nockdown hat geschrieben:I have updated winexe to version 4.8.0.0-44.
Have you also upgraded the rest of your server? IE: the rest of the opsi packages, and have you used opsi-package-updater?
What is the output of these commands?
Verfasst: 27 Okt 2020, 09:27
von nockdown
SisterOfMercy hat geschrieben:
Thank you for reply! No, I just updated only winexe package. As I understand, you offer to upgrade whole opsi server from 4.0 to 4.1
https://download.uib.de/opsi4.1/documen ... -migration
dpkg -l | grep opsi
ii opsi-atftpd 0.7.dfsg-6 amd64 advanced TFTP server - opsi version with pcre, fifo and max-blksize patches
ii opsi-configed 4.0.7.5.22-2 all OPSI config editor
ii opsi-depotserver 4.0.7.1-1 all opsi depotserver configuration package
ii opsi-linux-bootimage 20170508-1 amd64 opsi bootimage for netboot tasks.
ii opsi-utils 4.0.7.7-3 all utilites for working with opsi.
ii opsiconfd 4.0.7.9-1 all opsi configuration service
ii opsipxeconfd 4.0.7.5-3 all opsi pxe configuration daemon
ii python-opsi 4.0.7.40-1 all opsi python library
opsi-package-manager -l
- opsi.speechnew.local -
Product ID Version Name
3dsmax2019 21.0.0.845-1 3dsMax2019
3dsmax2019atiles2.52 2.52-1 3dsMax2019ATiles2.52
3dsmax2019coronarenderer5.2.0 5.2.0-1 3dsMax2019CoronaRenderer5.2.0
3dsmax2019coronarenderer6.0.0 6.0.0-1 3dsMax2019CoronaRenderer6.0.0
3dsmax2019deadline10.1.9.2 10.1.9.2-1 3dsMax2019Deadline10.1.9.2
3dsmax2019deadline10.1.9.2rendernode 10.1.9.2-1 3dsMax2019Deadline10.1.9.2Rend
3dsmax2019forestpack6.3.1 6.3.1-1 3dsMax2019ForestPack6.3.1
3dsmax2019forestpack6.3.1rendernode 6.3.1-1 3dsMax2019ForestPack6.3.1Rende
3dsmax2019plugins 1.0-1 3dsMax2019Plugins
3dsmax2019railclonelite4.1.0.507 4.1.0.507-1 3dsMax2019RailCloneLite4.1.0.5
3dsmax2019rendermask5.90.0 5.90.0-1 3dsMax2019RenderMask5.90.0
3dsmax2019settings 1.0-1 3dsMax2019Settings
3dsmax2019soulburnscripts110 110-1 3dsMax2019SoulBurnScripts110
3dsmax2019substancein3dsmax2.2.0 2.2.0-1 3dsMax2019SubstanceIn3dsMax2.2
3dsmax2019update3 21.3.0.3250-1 3dsMax2019Update3
3dsmax2019vraynext4.30.02 4.30.02-1 3dsMax2019VrayNext4.30.02
3dsmax2019vraynextsettings 1.0-1 3dsMax2019VrayNextSettings
3dsmax2020 22.0.0.757-1 3dsMax2020
3dsmax2020atiles2.62 2.62-1 3dsMax2020ATiles2.62
3dsmax2020coronarenderer5.2.0 5.2.0-1 3dsMax2020CoronaRenderer5.2.0
3dsmax2020forestpack6.2.2 6.2.2-1 3dsMax2020ForestPack6.2.2
3dsmax2020forestpack6.2.2rendernode 6.2.2-1 3dsMax2020ForestPack6.2.2Rende
3dsmax2020plugins 1.0-1 3dsMax2020Plugins
3dsmax2020railclonelite4.2.0.519 4.2.0.519-1 3dsMax2020RailCloneLite4.2.0.5
3dsmax2020rendermask5.90.0 5.90.0-1 3dsMax2020RenderMask5.90.0
3dsmax2020soulburnscripts111 111-1 3dsMax2020SoulBurnScripts111
3dsmax2020substancein3dsmax2.3.2 2.3.2-1 3dsMax2020SubstanceIn3dsMax2.3
3dsmax2020update3 22.3.0.3165-1 3dsMax2020Update3
3dsmax2020vraynext4.30.02 4.30.02-1 3dsMax2020VrayNext4.30.02
3dsmax2021 23.2.0.2215-1 3dsMax2021
3dsmax2021atiles2.62 2.62-1 3dsMax2021ATiles2.62
3dsmax2021coronarenderer5.2.0 5.2.0-1 3dsMax2021CoronaRenderer5.2.0
3dsmax2021coronarenderer6.0.0 6.0.0-1 3dsMax2021CoronaRenderer6.0.0
3dsmax2021deadline10.1.9.2 10.1.9.2-1 3dsMax2021Deadline10.1.9.2
3dsmax2021deadline10.1.9.2rendernode 10.1.9.2-1 3dsMax2021Deadline10.1.9.2Rend
3dsmax2021forestpack6.3.1 6.3.1-1 3dsMax2021ForestPack6.3.1
3dsmax2021forestpack6.3.1rendernode 6.3.1-1 3dsMax2021ForestPack6.3.1Rende
3dsmax2021plugins 1.0-1 3dsMax2021Plugins
3dsmax2021railclonelite4.2.1 4.2.1-1 3dsmax2021railclonelite4.2.1
3dsmax2021soulburnscripts111 111-1 3dsMax2021SoulBurnScripts111
3dsmax2021vraynext4.30.02 4.30.02-1 3dsMax2021VrayNext4.30.02
7zip18.01 18.1.0.0-1 7Zip18.01
accessruntime2016 16.0.4288.1001-1 AccessRuntime2016
acrobatdc18.011.20055 18.011.20055-1 AcrobatDC18.011.20055
acrobatdc20.9.20067.57037 20.9.20067.57037-1 AcrobatDC20.9.20067.57037
acrobatpro11.0.23.22 11.0.23.22-1 AcrobatPro11.0.23.22
activate-win 1.0-9 Windows Activation
aftereffectscc2018 15.1.2.69-1 AfterEffectsCC2018
aftereffectscc2018rendernode 1.0-1 AfterEffectsCC2018RrenderMode
archicad15.0.0.3006 15.0.0.3006-1 ArchiCAD15.0.0.3006
archicad1516171819 1.0-1 archicad1516171819
archicad15update4056 15.0.0.4056-1 Archicad15Update4056
archicad16.0.0.3006 16.0.0.3006-1 ArchiCAD16.0.0.3006
archicad16update4010 16.0.0.4010-1 Archicad16Update4010
archicad17.0.0.3002 17.0.0.3002-1 ArchiCAD17.0.0.3002
archicad17update8000 17.0.0.8000-1 Archicad17Update8000
archicad18.0.0.3006 18.0.0.3006-1 ArchiCAD18.0.0.3006
archicad18update9019 18.0.0.9019-1 Archicad18Update9019
archicad19.0.0.3003 19.0.0.3003-1 ArchiCAD19.0.0.3003
archicad19update9001 19.0.0.9001-1 Archicad19Update9001
archicad20.0.0.3012 20.0.0.3012-1 ArchiCAD20.0.0.3012
archicad20remove 20.0.0.3012-1 ArchiCAD20Remove
archicad20update8005 20.0.0.8005-1 ArchiCAD20Update8005
archicad21.0.0.3005 21.0.0.3005-1 ArchiCAD21.0.0.3005
archicad21.22corona4.28.06.19 4.0.0.0-1 archicad21.22corona4.28.06.19
archicad21library5555 21.0.0.5555-1 ArchiCAD21Library5555
archicad21twinmotiondirectlink1.5.3 1.5.3-1 archicad21twinmotiondirectlink
archicad21update8002 21.0.0.8002-1 ArchiCAD21Update8002
archicad21zonesumid 1.0-1 ArchiCAD21ZoneSumID
archicad22.0.0.3006 22.0.0.3006-1 ArchiCAD22.0.0.3006
archicad22.0.0.3006grasshopperconnection4027 22.0.0.4027-1 ArchiCAD22.0.0.3006Grasshopper
archicad22apartmentstamp 1.0-1 ArchiCAD22ApartmentStamp
archicad22library4029 22.0.0.4029-1 ArchiCAD22Library4029
archicad22twinmotiondirectlink1.5.3 1.5.3-1 archicad22twinmotiondirectlink
archicad22update7000 22.0.0.7000-1 Archicad22Update7000
archicad22zonesumid 1.0-1 ArchiCAD22ZoneSumID
archicad23.0.0.3003 23.0.0.3003-1 archicad23.0.0.3003
archicad23.0.0.3003grasshopperconnection3007 23.0.0.3007-1 Archicad23.0.0.3003Grasshopper
archicad23apartmentstamp 1.0-1 ArchiCAD23ApartmentStamp
archicad23twinmotiondirectlink1.5.3 1.5.3-1 archicad23twinmotiondirectlink
archicad23update5005 23.0.0.5005-1 Archicad23Update5005
archicad23update5010 23.0.0.5010-1 Archicad23Update5010
archicad24.0.0.3008 24.0.0.3008-1 archicad24.0.0.3008
archicad24.0.0.3008grasshopperconnection3008 24.0.0.3008-1 Archicad24.0.0.3008Grasshopper
archicad24update3022 24.0.0.3022-1 ArchiCAD24Update3022
artlantis2019.2.17649 8.0.2.17649-1 Artlantis2019.2.17649
artlantis2019update19251 8.0.2.19251-1 Artlantis2019Update19251
autocad2019 29.0.46.0-1 Autocad2019
autocad2019geonics2019 19.0.0.5-1 Autocad2019GeoniCS2019
autocad2019russianlanguagepack 23.0.46.0-1 AutoCAD2019RussianLanguagePack
autocad2019spds2 23.0.91.0-1 Autocad2019SPDS2
autocad2019update1.2 29.0.161.0-1 Autocad2019Update1.2
autocad2019update1.2csh 29.0.162.4-1 Autocad2019Update1.2CSH
autocad2019vba 23.0.46.0-1 Autocad2019VBA
autocad2020 29.1.47.0-1 AutoCAD2020
autocad2020russianlanguagepack 23.1.47.0-1 AutoCAD2020RussianLanguagePack
autocad2020spds 23.1.47.0-1 Autocad2020SPDS
autocad2020update1.3 29.1.111.0-1 AutoCAD2020Update1.3
autocad2020vba 23.1.47.0-1 Autocad2020VBA
autocad2021 30.0.47.0-1 AutoCAD2021
autocad2021geonics2021 21.0.0.0-1 Autocad2021GeoniCS2021
autocad2021update1 30.0.118.0-1 Autocad2021Update1
autocadarchitecture2019 29.0.46.0-1 AutocadArchitecture2019
autocadarchitecture2019.0.2 8.1.70.0-1 AutocadArchitecture2019.0.2
autocadarchitecture2019ruslp 8.1.48.0-1 AutocadArchitecture2019RusLP
autocadarchitecture2019update1.2 29.0.162.0-1 AutocadArchitecture2019Update1
autocadarchitecture2019update1.2csh 29.0.162.4-1 AutocadArchitecture2019Update1
autocadarchitecture2020 29.1.47.0-1 AutocadArchitecture2020
autocadarchitecture2020.0.2 8.2.70.0-1 AutocadArchitecture2020.0.2
autocadarchitecture2020ruslp 8.2.47.0-1 AutocadArchitecture2020RusLP
autocadarchitecture2020update1.3 29.1.111.0-1 AutocadArchitecture2020Update1
autocadarchitecture2021 30.0.47.0-1 AutocadArchitecture2021
autocadarchitecture2021.0.1 8.3.61.0-1 AutocadArchitecture2021.0.1
autocadarchitecture2021ruslp 8.3.53.0-1 AutocadArchitecture2021RusLP
autocadarchitecture2021update1 30.0.118.0-1 AutocadArchitecture2021Update1
autocadarchitecture2021vba 24.0.47.0-1 AutocadArchitecture2021VBA
autodeskdesktoplicensingservice9.2.2.2501 9.2.2.2501-1 autodeskdesktoplicensingservic
autodeskdesktoplicensingservice9.4.0.2899 9.4.0.2899-1 autodeskdesktoplicensingservic
autologonlastuser 1.0-1 autologonlastuser
bimvision2.24.4.0 2.24.4.0-1 BIMVision2.24.4.0
callofduty2 1.5.0.0-1 CallOfDuty2
camtasia18.0.7.4045 18.0.7.4045-1 Camtasia18.0.7.4045
centos70 4.0.7.2-1 CentOS Linux 7.0 64Bit
comodocav11.0.0.6606 11.0.0.6606-1 ComodoCAV11.0.0.6606
comodoopsiexclusion 1.0-1 ComodoOpsiExclusion
config-win-base 4.0.1-1 Windows Customizing
config-win10 4.0.7-6 Configure Windows 10
config-win81-desktop 4.0.5-3 Windows Customizing for Win8.1
davinciresolve16.0.0017 16.0.0017-1 DavinciResolve16.0.0017
debian 4.0.7.2-1 Linux Debian 32/64 Bit
debian7 4.0.7.2-1 Linux Debian 7
debian8 4.0.7.2-1 Linux Debian 8
designreview2018 2018-1 DesignReview2018
designreview2018update2 14.0.2.191-1 DesignReview2018Update2
dotnet4.8.03761 4.8.03761-1 DotNet4.8.03761
dropbox83.4.152 83.4.152-1 Dropbox83.4.152
dwgtrueview2019 29.0.46.0-1 DwgTrueView2019
dwgtrueview2020 29.1.48.0-1 DwgTrueView2020
dwgtrueview2021 30.0.47.0-1 DwgTrueView2021
greenshot1.2.10.6 1.2.10.6-1 Greenshot1.2.10.6
hwaudit 4.0.6.1-6 Client Hardwareinventarisierun
hwinvent 4.0-1 Hardware Inventarisierung
illustratorcc2018 22.1.0.312-1 IllustratorCC2018
indesigncc2018 13.1.0.76-1 IndesignCC2018
infraworks2019 19.3.23.0-1 InfraWorks2019
infraworks2019russianfacadesstyleslibrary 1.0-1 InfraWorks2019RussianFacadesSt
infraworks2019update3.2 19.3.41.0-1 InfraWorks2019Update3.2
inventor2019 23.0.13600.0-1 Inventor2019
inventor2019update2 23.20.26500.0-1 Inventor2019Update2
jabber2.5 2.5.0.0-1 Jabber2.5
javavm 1.8.0.101or1.8.0.102-1 Oracle Java Runtime Environmen
jedit 5.3.0-2 jEdit programmer's text editor
l-desktop 4.0.6.1-1 Desktop for Linux
l-hwaudit 4.0.7-5 Linux Client Hardwareinventory
l-jedit 5.3-6 jEdit for Linux 5.3
l-opsi-server 4.0.7.1-10 Installs opsi
l-os-postinst 4.0.5.1-4 Linux post bootimage install
l-ssh-root-login 1.0-1 l-ssh-root-login
l-swaudit 4.0.6-1 Client software inventory
l-system-update 4.0.7.1-4 Linux System Update
l-virtualbox 5.0-1 l-virtualbox
lightshot5.5.0.4 5.5.0.4-1 LightShot5.5.0.4
lumion8.5 8.5-1 Lumion8.5
lumionviewer8.3 8.3-1 LumionViewer8.3
mediaencodercc2018 12.1.2.69-1 MediaEncoderCC2018
memtest86 5.01-1 Memtest86+
microsoftnetcoresdk3.1.302.15188 3.1.302.15188-1 MicrosoftNETCoreSDK3.1.302.151
moosprojectviewer3.2.1 3.2.1-1 MoosProjectViewer3.2.1
moses 2.0-1 moses
moses3 3.0-1 Moses3
mosesforprinter 1.0-1 mosesforprinter
navisworksfreedom2019 16.0.1326.55-1 NavisworksFreedom2019
navisworksfreedom2019update5 16.5.1348.21-1 NavisworksFreedom2019Update5
navisworksfreedom2020 17.0.1336.83-1 NavisworksFreedom2020
navisworksfreedom2020update3 17.3.1351.52-1 NavisworksFreedom2020update3
navisworksfreedom2021 18.0.1347.51-1 NavisworksFreedom2021
navisworksmanage2019 16.0.1326.55-1 NavisworksManage2019
navisworksmanage2019autosearchset1.0.5 1.0.5-1 NavisworksManage2019AutoSearch
navisworksmanage2019update5 16.5.1348.21-1 NavisworksManage2019update5
navisworksmanage2020 17.0.1336.83-1 NavisworksManage2020
navisworksmanage2020update3 17.3.1351.52-1 NavisworksManage2020update3
navisworksmanage2021 18.0.1347.51-1 NavisworksManage2021
navisworksmanage2021update1 18.1.1354.62-1 NavisworksManage2021update1
networklocation 1.0-1 networklocation
notepadplusplus7.3.2 7.3.2.0-1 NotepadPlusPlus7.3.2
nvidiadrivers451.48 451.48-1 nvidiadrivers451.48
office2019prowep 16.0.10342.20010-1 Office2019ProWEP
office2019prowepa 16.0.10342.20010-1 Office2019ProWEPA
office2019prowepas 16.0.10342.20010-1 Office2019ProWEPAS
office2019standardwep 16.0.10342.20010-1 Office2019StandardWEP
office2019standardwepo 16.0.10342.20010-1 Office2019StandardWEPO
opensuse13-2 4.0.7.1-3 OpenSuse 13.2
opensusel42-1 4.0.7.2-2 OpenSuse Leap 42.1
opensusel42-2 4.0.7.2-2 OpenSuse Leap 42.2
opsi-client-agent 4.0.7.15-1 opsi.org client agent
opsi-clonezilla 4.0.7.2-3 Clonezilla over opsi
opsi-configed 4.0.7.5.22-2 opsi configed
opsi-linux-client-agent 4.0.7.6-1 opsi.org client agent for Linu
opsi-logviewer 2.2-2 opsi logfile viewer
opsi-set-win-uac 1.0-2 opsi set Windows UAC
opsi-setup-detector 4.0.6.132-1 opsiSetupDetector
opsi-template 4.0.6-1 opsi template product
opsi-template-with-admin 4.0.6-1 opsi template for installs wit
opsi-uefi-netboot 4.0.5-3 opsi-uefi-netboot
opsi-wan-config-off 4.0.1-1 opsi-wan-config-off
opsi-wan-config-on 4.0.1-1 opsi-wan-config-off
opsi-wim-capture 4.0.7.1-3 opsi-wim-capture
opsi-wim-delete 4.0.7.1-1 opsi-wim-delete
opsi-wim-info 4.0.7.2-1 opsi-wim-info
opsi-winpe 1.0-1 WinPE patching tool
opsi-winst 4.11.6.12-1 winst
opsi-winst-test 4.11.6.4-1 opsi-winst test
pathcopycopy15.0 15.0-1 PathCopyCopy15.0
pdfcreator1.7.0.3 1.7.0.3-1 PDFCreator1.7.0.3
photoshop21.2.0.225 21.2.0.225-1 Photoshop21.2.0.225
photoshopcc2018 19.1.4.56638-1 PhotoshopCC2018
photoshopcs5 12.0.1.0-1 PhotoshopCS5
premiercc2018 12.1.2.69-1 PremierCC2018
projectlavina0.4.1 0.4.1-1 projectlavina0.4.1
qgis3.10.10 3.10.10-1 QGIS3.10.10
recap2019 5.0.4.17-1 ReCap2019
redhat70 4.0.7.2-1 RedHat Enterprise Linux 7.0 64
revit2017 17.0.416.0-1 Revit2017
revit2017coinautosectionbox 5.0.0.0-1 Revit2017CoinAutoSectionBox
revit2017ctcbimprojectsuite19.0.0 19.0.0.0-1 Revit2017CTCBimProjectSuite19.
revit2017dblink17.0.456.0 17.0.456.0-1 Revit2017DBLink17.0.456.0
revit2017dyno0.6.4.1054 0.6.4.1054-1 Revit2017Dyno0.6.4.1054
revit2017exportschedule1.3.1 1.3.1.0-1 Revit2017ExportSchedule1.3.1
revit2017formit16.1.240.0 16.1.240.0-1 Revit2017FormIt16.1.240.0
revit2017hatchkit2.1.2.2017 2.1.2.2017-1 Revit2017Hatchkit2.1.2.2017
revit2017importexportexcel17.0.1 17.0.1.0-1 Revit2017ImportExportExcel17.0
revit2017modelcheckerconfigurator2.0.6000.25053 2.0.6000.25053-1 Revit2017ModelCheckerConfigura
revit2017modelcheckershell6.0.6296.20630 6.0.6296.20630-1 Revit2017ModelCheckerShell6.0.
revit2017pyrevit 1.0-1 Revit2017pyRevit
revit2017roombook7.0.0.2513 7.0.0.2513-1 Revit2017Roombook7.0.0.2513
revit2017roomfinishing1.5.0 1.5.0-1 Revit2017RoomFinishing1.5.0
revit2017update2.4 17.0.1158.0-1 Revit2017Update2.4
revit2017worksharingmonitor 17.0.476.0-1 Revit2017WorksharingMonitor
revit2018 18.0.0.420-1 Revit2018
revit2018coinautosectionbox5.5.0.0 5.5.0.0-1 Revit2017CoinAutoSectionBox5.5
revit2018ctcbimprojectsuite19.0.0 19.0.0.0-1 Revit2018CTCBimProjectSuite19.
revit2018dragdropinterface2018 2018.17.05.16-1 Revit2018DragDropInterface2018
revit2018dyno0.6.6.1613 0.6.6.1613-1 Revit2018Dyno0.6.6.1613
revit2018dyno0.7 0.7.0.3026-1 Revit2018Dyno0.7
revit2018exportschedule1.3.2 1.3.2-1 Revit2018ExportSchedule1.3.2
revit2018ifc18.3.1 18.3.1-1 Revit2018IFC18.3.1
revit2018ifc18.4.0 18.4.0-1 Revit2018IFC18.4.0
revit2018importexportexcel18.0.0 18.0.0.0-1 Revit2018ImportExportExcel18.0
revit2018lumionlivesync3.50 3.50-1 Revit2018LumionliveSync3.50
revit2018pyrevit 1.0-1 Revit2018pyRevit
revit2018roombook8.0.0.2810 8.0.0.2810-1 Revit2018Roombook8.0.0.2810
revit2018roomfinishing1.5.0 1.5.0-1 Revit2018RoomFinishing1.5.0
revit2018update3.2 18.3.2.7-1 Revit2018Update3.2
revit2019 19.0.0.405-1 Revit2019
revit2019align1.4.0 1.4.0-1 Revit2019Align1.4.0
revit2019alignviews1.1.0 1.1.0-1 revit2019alignviews1.1.0
revit2019artlantisexporter1.0.0.1 1.0.0.1-1 Revit2019ArtlantisExporter1.0.
revit2019autodeskenhanceddwgexporter10.1 10.1.0.0-1 revit2019autodeskenhanceddwgex
revit2019coinautosectionbox6.0.0.0 6.0.0.0-1 Revit2019CoinAutoSectionBox6.0
revit2019ctcbimprojectsuite19.0.2 19.0.2.0-1 Revit2019CTCBimProjectSuite19.
revit2019dynamo2.0.3.8811 2.0.3.8811-1 Revit2019Dynamo2.0.3.8811
revit2019dyno0.7.1 0.7.1.3026-1 Revit2019Dyno0.7.1
revit2019elementselectorpro1.0.2 1.0.2-1 Revit2019ElementSelectorPro1.0
revit2019exportschedule1.3.2 1.3.2-1 Revit2019ExportSchedule1.3.2
revit2019formit17.4.0.0 17.4.0.0-1 Revit2017FormIt17.4.0.0
revit2019grevit1.2.0 1.2.0-1 Revit2019Grevit1.2.0
revit2019ifc19.1.0 19.1.0-1 Revit2019IFC19.1.0
revit2019ifcmodelexchange4018 22.0.0.4018-1 Revit2019IFCModelExchange4018
revit2019importexportexcel19.0.0 19.0.0.0-1 Revit2019ImportExportExcel19.0
revit2019lumionlivesync3.51 3.51-1 Revit2019LumionliveSync3.51
revit2019navisworksexporters 16.5.1348.21-1 Revit2019NavisworksExporters
revit2019pyrevit1.2 1.2-1 Revit2019pyRevit1.2
revit2019rautosave1.4.5 1.4.5-1 Revit2019RAutoSave1.4.5
revit2019revitpythonshell2019 2019.0-1 Revit2019RevitPythonShell2019
revit2019roomfinishing1.6.0 1.6.0-1 Revit2019RoomFinishing1.6.0
revit2019rquickselect1.0.7 1.0.7-1 revit2019rquickselect1.0.7
revit2019twinmotiondirectlink2019.46.5410.20 2019.46.5410.20-1 revit2019twinmotiondirectlink2
revit2019update2.2 19.2.20.24-1 Revit2019Update2.2
revit2020 20.0.0.377-1 Revit2020
revit2020artlantisexporter1.0.0.0 1.0.0.0-1 Revit2020ArtlantisExporter1.0.
revit2020biminteroperabilitytoolsforrevit7.1.7159.0 7.1.7159.0-1 Revit2020BIMInteroperabilityTo
revit2020ifc20.1.0.1 20.1.0.1-1 Revit2020IFC20.1.0.1
revit2020ifcmodelexchange3706 23.0.0.3706-1 Revit2020IFCModelExchange3706
revit2020importexportexcel20.0.0 20.0.0.0-1 Revit2020ImportExportExcel20.0
revit2020lumionlivesync3.60 3.60-1 Revit2020LumionliveSync3.60
revit2020pyrevit1.2 1.2-1 Revit2020pyRevit1.2
revit2020twinmotiondirectlink2019.46.5410.21 2019.46.5410.21-1 revit2019twinmotiondirectlink2
revit2020update2 20.2.0.48-1 Revit2020Update2
revit2020update2.2 20.2.20.31-1 Revit2020Update2.2
revit2020update2.3 20.2.30.42-1 Revit2020Update2.3
revit2021 21.1.1.109-1 Revit2021
revit2021align1.5.0 1.5.0-1 Revit2021Align1.5.0
revit2021colorsplasher21.0.0 21.0.0-1 Revit2021ColorSplasher21.0.0
revit2021elementselectorpro1.0.2 1.0.2-1 Revit2021ElementSelectorPro1.0
revit2021ifc21.1.0.0 21.1.0.0-1 Revit2021IFC21.1.0.0
revit2021importexportexcel21.0.0 21.0.0.0-1 Revit2021ImportExportExcel21.0
revit2021lumionlivesync3.60.539 3.60.539-1 Revit2021LumionLiveSync3.60.53
revit2021pyrevit1.2 1.2-1 Revit2021pyRevit1.2
revit2021update1.1 21.1.10.26-1 Revit2021Update1.1
rhinoceros5.13.60913.21340 5.13.60913.21340-1 Rhinoceros5.13.60913.21340
rhinoceros5grasshopper0.9.76.0 0.9.76.0-1 Rhinoceros5Grasshopper0.9.76.0
rhinoceros5update5.14.00522.08390 5.14.00522.08390-1 Rhinoceros5Update5.14.00522.08
rhinoceros6.13.19058.00371 6.7.18199.22081-1 Rhinoceros6.13.19058.00371
rhinoceros6.13.19058.00371humanui0.8 0.8.0.0-1 Rhinoceros6.13.19058.00371Huma
rhinoceros6.18.19266.14201 6.18.19266.14201-1 Rhinoceros6.18.19266.14201
screencast3.6 3.6.0.0-1 Screencast3.6
setdhcpdns 1.0-1 setdhcpdns
shutdownwanted 1.0-5 shutdown wanted
sketchup2017 17.1.174.0-1 SketchUp2017
sketchup2018 18.0.16975.0-1 SketchUp2018
sketchup2018vray3.60.03 3.60.03-1 SketchUp2018Vray3.60.03
sketchup2019 19.0.685.20289-1 SketchUp2019
sketchup2019twinmotiondirectlink2019.57.5470.38 2019.57.5470.38-1 sketchup2019twinmotiondirectli
sketchup2020.1 20.1.235.67-1 SketchUp2020.1
skype8.27.0.85 8.27.0.85-1 skype8.27.0.85
sles11sp4 4.0.7.2-1 SuSE Linux Enterprise Server (
sles12 4.0.7.2-1 SuSE Linux Enterprise Server (
sles12sp1 4.0.7.2-1 SuSE Linux Enterprise Server (
sles12sp2 4.0.7.2-1 SuSE Linux Enterprise Server (
solaris8.10.0.19380 8.10.0.19380-1 Solaris8.10.0.19380
solibri9.10.0.129 9.10.0.129-1 Solibri9.10.0.129
solibriifcoptimizer2.7.1 2.7.1-1 SolibriifcOptimizer2.7.1
swaudit 4.0.7.4-2 Client software inventory
synologychat1.1.1.57 1.0-1 SynologyChat1.1.1.57
thunderbird52.5.0.6534 52.5.0.6534-1 Thunderbird52.5.0.6534
twinmotion2019.5 4.19.2.0-1 TwinMotion2019.5
twinmotionmaxexporter4.22.1.0 4.22.1.0-1 TwinMotionMaxExporter4.22.1.0
twinmotionrevitexporter4.22.1.0 4.22.1.0-1 TwinMotionRevitExporter4.22.1.
twinmotionsketchupexporter4.22.1.0 4.22.1.0-1 TwinMotionSketchupExporter4.22
ubuntu 4.0.7.2-1 Linux Ubuntu 32/64 Bit
ubuntu14-04 4.0.7.2-1 Linux Ubuntu 14-04 (trusty tah
ubuntu16-04 4.0.7.2-1 Linux Ubuntu 16-04 (Xenial Xer
ucs41 4.0.7.2-1 Univention Corporate Server 4.
ultravnc1.2.22 1.2.22-1 UltraVNC 1.2.22
ultravncviewer1.2.22 1.2.22-1 UltraVNCViewer1.2.22
usbimviewer9.0.2.23071 9.0.2.23071-1 usBIMviewer9.0.2.23071
win10 4.0.7.1-7 Windows 10
win10-captured 4.0.7.1-7 Windows 10
win10-x64 4.0.7.1-7 Windows 10 x64
win10-x64-captured 4.0.7.1-7 Windows 10 x64
win2008-r2 4.0.7.1-6 Windows Server 2008 R2 - x64
win2012 4.0.7.1-6 Windows Server 2012
win2012-r2 4.0.7.1-6 Windows Server 2012
win2016 4.0.7.1-6 Windows Server 2016
win7 4.0.7.1-6 Windows 7 - x86
win7-captured 4.0.7.1-6 Windows 7 - x86
win7-x64 4.0.7.1-6 Windows 7 - x64
win7-x64-captured 4.0.7.1-6 Windows 7 - x64
win81 4.0.7.1-6 Windows
win81-captured 4.0.7.1-6 Windows
win81-x64 4.0.7.1-6 Windows
win81-x64-captured 4.0.7.1-6 Windows
windomain 1.0-8 Join NT/AD Domain
winlogbeat7.8.1 7.8.1-1 Winlogbeat7.8.1
wipedisk 1.0-2 Festplatte oder Partitionen lo
Verfasst: 27 Okt 2020, 10:22
von SisterOfMercy
nockdown hat geschrieben:Thank you for reply! No, I just updated only winexe package. As I understand, you offer to upgrade whole opsi server from 4.0 to 4.1
Yes, I would strongly recommend that. That will probably fix all your issues. (ymmv)
