Windows 10: opsi-client-agent 4.1.0.0-40 startet nicht
Verfasst: 12 Jun 2020, 21:14
seit dem Update auf opsi-client-agent 4.1.0.0-40 startet dieser nicht mehr richtig:
Eine Reinstallation hat nur temporär geholfen.
Viele Grüße,
Stefan
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.log_file (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.log_level (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.host_id (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.opsi_host_key (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.verify_server_cert (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.verify_server_cert_by_ca (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.wait_for_gui_timeout (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.block_login_notifier (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.proxy_mode (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.proxy_url (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.base_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.locale_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.log_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.server_cert_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.state_file (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value global.timeline_db (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value config_service.url (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value config_service.connection_timeout (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value config_service.user_cancelable_after (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value config_service.sync_time_from_service (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value depot_server.depot_id (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value depot_server.url (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value depot_server.drive (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value depot_server.username (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value cache_service.product_cache_max_size (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value cache_service.exclude_product_group_ids (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value cache_service.include_product_group_ids (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value cache_service.extension_config_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value cache_service.storage_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value control_server.interface (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value control_server.port (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value control_server.ssl_server_cert_file (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value control_server.ssl_server_key_file (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value control_server.static_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value control_server.max_authentication_failures (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value notification_server.interface (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value notification_server.start_port (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value notification_server.popup_port (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value notification_server.port (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value opsiclientd_notifier.command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value opsiclientd_rpc.command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value action_processor.local_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value action_processor.remote_dir (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value action_processor.filename (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value action_processor.command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value action_processor.create_environment (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value action_processor.create_user (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value action_processor.delete_user (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value action_processor.run_as_user (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.interval (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.max_repetitions (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.activation_delay (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.notification_delay (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.event_notifier_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.event_notifier_desktop (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.block_login (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.lock_workstation (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.logoff_current_user (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.get_config_from_service (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.update_config_file (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.write_log_to_service (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.reboot (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.exclude_product_group_ids (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.include_product_group_ids (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.working_window (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.sync_config_to_server (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.sync_config_from_server (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.post_sync_config_to_server (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.post_sync_config_from_server (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.use_cached_config (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.cache_products (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.cache_max_bandwidth (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.cache_dynamic_bandwidth (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.use_cached_products (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_warning_time (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_notifier_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_notifier_desktop (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_message (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_message[de] (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_message[fr] (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_user_cancelable (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.process_actions (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.update_action_processor (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.pre_action_processor_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_processor_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_processor_desktop (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.action_processor_timeout (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.post_action_processor_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.trusted_installer_check (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.process_shutdown_requests (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown_warning_time (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown_notifier_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown_notifier_desktop (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown_warning_message (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown_warning_message[de] (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown_warning_message[fr] (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown_user_cancelable (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_default.shutdown_warning_repetition_time (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_gui_startup.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_gui_startup.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_gui_startup.name (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_gui_startup.block_login (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_gui_startup.active (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_on_demand.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_on_demand.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_on_demand.name (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_software_on_demand.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_software_on_demand.shutdown_warning_time (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_software_on_demand.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync.process_actions (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync.event_notifier_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync.sync_config_to_server (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync.sync_config_from_server (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync.cache_products (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync.cache_dynamic_bandwidth (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_timer.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_timer.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_timer.active (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_timer.interval (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_net_connection.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_net_connection.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_net_connection.active (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_net_connection.wql (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync_completed.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync_completed.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync_completed.event_notifier_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync_completed.process_actions (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync_completed.get_config_from_service (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_sync_completed.write_log_to_service (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.action_type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.active (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.action_message (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.action_message[de] (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.action_message[fr] (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.block_login (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.process_shutdown_requests (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.get_config_from_service (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.update_config_file (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.write_log_to_service (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.update_action_processor (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.event_notifier_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.event_notifier_desktop (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.action_processor_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.action_processor_desktop (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_user_login.action_processor_timeout (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_on_shutdown.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_on_shutdown.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_on_shutdown.name (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_on_shutdown.active (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.name (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.event_notifier_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.process_shutdown_requests (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.action_processor_command (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.action_processor_desktop (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.action_processor_timeout (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_silent_install.action_processor_productids (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_timer_silentinstall.super (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_timer_silentinstall.type (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_timer_silentinstall.active (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value event_timer_silentinstall.interval (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value precondition_user_logged_in.user_logged_in (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value precondition_cache_ready.config_cached (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value precondition_cache_ready.products_cached (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value precondition_cache_ready_user_logged_in.user_logged_in (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value precondition_cache_ready_user_logged_in.config_cached (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value precondition_cache_ready_user_logged_in.products_cached (Config.pyo|204)
[6] [Jun 12 21:09:48] [ opsiclientd ] Setting config value precondition_installation_pending.installation_pending (Config.pyo|204)
[5] [Jun 12 21:09:48] [ opsiclientd ] Config read (Config.pyo|335)
[5] [Jun 12 21:09:48] [ opsiclientd ] Setting locale dir to 'C:\\Program Files (x86)\opsi.org\opsi-client-agent\locale' (Localization.pyo|59)
[5] [Jun 12 21:09:48] [ opsiclientd ] Loading translation for language 'de' (Localization.pyo|61)
[1] [Jun 12 21:09:48] [ opsiclientd ] Opsiclientd version: 4.0.99 (full) (Opsiclientd.pyo|234)
[1] [Jun 12 21:09:48] [ opsiclientd ] Commandline: C:\\Program Files (x86)\opsi.org\opsi-client-agent\opsiclientd.exe (Opsiclientd.pyo|239)
[1] [Jun 12 21:09:48] [ opsiclientd ] Working directory: C:\WINDOWS\system32 (Opsiclientd.pyo|241)
[5] [Jun 12 21:09:48] [ opsiclientd ] Using host id 'mlwinadmin.informatik.privat' (Opsiclientd.pyo|243)
[5] [Jun 12 21:09:48] [ opsiclientd ] Block login now set to 'True' (Opsiclientd.pyo|109)
[6] [Jun 12 21:09:48] [ opsiclientd ] Starting block login notifier app (Opsiclientd.pyo|119)
[6] [Jun 12 21:09:48] [ opsiclientd ] Searching pids of process name winlogon.exe (session id: 1) (Windows.pyo|1447)
[6] [Jun 12 21:09:48] [ opsiclientd ] Found process winlogon.exe with matching name (pid 596, session 1) (Windows.pyo|1470)
[5] [Jun 12 21:09:48] [ opsiclientd ] Executing: 'C:\\Program Files (x86)\opsi.org\opsi-client-agent\\notifier.exe -s notifier\\block_login.ini' in session '1' on desktop 'winsta0\winlogon' (Windows.pyo|1634)
[6] [Jun 12 21:09:48] [ opsiclientd ] Process startet, pid: 780 (Windows.pyo|1637)
[5] [Jun 12 21:09:48] [ opsiclientd ] Starting reactor (Opsiclientd.pyo|249)
[5] [Jun 12 21:09:49] [ opsiclientd ] Starting control pipe (Opsiclientd.pyo|262)
[6] [Jun 12 21:09:49] [ control pipe ] Creating pipe \\.\pipe\opsiclientd (ControlPipe.pyo|251)
[5] [Jun 12 21:09:49] [ opsiclientd ] Control pipe started (Opsiclientd.pyo|266)
[5] [Jun 12 21:09:49] [ opsiclientd ] Starting control server (Opsiclientd.pyo|271)
[6] [Jun 12 21:09:49] [ control server ] ControlServer initiated (ControlServer.pyo|358)
[5] [Jun 12 21:09:49] [ opsiclientd ] Control server started (Opsiclientd.pyo|280)
[6] [Jun 12 21:09:49] [ control server ] creating root resource (ControlServer.pyo|365)
[5] [Jun 12 21:09:49] [ opsiclientd ] Starting cache service (Opsiclientd.pyo|288)
[5] [Jun 12 21:09:49] [ opsiclientd ] Cache service started (Opsiclientd.pyo|292)
[2] [Jun 12 21:09:49] [ control server ] Traceback: (Logger.pyo|757)
[2] [Jun 12 21:09:49] [ control server ] File "ocdlib\ControlServer.pyo", line 371, in run
(Logger.pyo|757)
[2] [Jun 12 21:09:49] [ control server ] File "twisted\internet\posixbase.pyo", line 505, in listenSSL
(Logger.pyo|757)
[2] [Jun 12 21:09:49] [ control server ] File "twisted\internet\posixbase.pyo", line 478, in listenTCP
(Logger.pyo|757)
[2] [Jun 12 21:09:49] [ control server ] File "twisted\internet\tcp.pyo", line 983, in startListening
(Logger.pyo|757)
[2] [Jun 12 21:09:49] [ control server ] ==>>> Couldn't listen on any:4441: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (ControlServer.pyo|377)
[5] [Jun 12 21:09:49] [ control server ] Control server exiting (ControlServer.pyo|378)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'timer' is deactivated (Events.pyo|920)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'user_login' is deactivated (Events.pyo|920)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'net_connection' is deactivated (Events.pyo|920)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'timer_silentinstall' is deactivated (Events.pyo|920)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator 'gui_startup' created (Events.pyo|1092)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator 'silent_install' created (Events.pyo|1092)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator 'on_shutdown' created (Events.pyo|1092)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator 'on_demand' created (Events.pyo|1092)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator 'sync_completed' created (Events.pyo|1092)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator 'software_on_demand' created (Events.pyo|1092)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'gui_startup' added to event generator 'gui_startup' (Events.pyo|1110)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'silent_install' added to event generator 'silent_install' (Events.pyo|1110)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'on_shutdown' added to event generator 'on_shutdown' (Events.pyo|1110)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'on_demand' added to event generator 'on_demand' (Events.pyo|1110)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'sync_completed' added to event generator 'sync_completed' (Events.pyo|1110)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event config 'software_on_demand' added to event generator 'software_on_demand' (Events.pyo|1110)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator '<CustomEventGenerator on_demand>' started (Opsiclientd.pyo|305)
[6] [Jun 12 21:09:49] [ event generator on_demand ] Initializing event generator '<CustomEventGenerator on_demand>' (Events.pyo|477)
[6] [Jun 12 21:09:49] [ event generator on_demand ] Activating event generator '<CustomEventGenerator on_demand>' (Events.pyo|485)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Initializing event generator '<GUIStartupEventGenerator gui_startup>' (Events.pyo|477)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator '<GUIStartupEventGenerator gui_startup>' started (Opsiclientd.pyo|305)
[6] [Jun 12 21:09:49] [ event generator on_demand ] Getting next event... (Events.pyo|487)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Activating event generator '<GUIStartupEventGenerator gui_startup>' (Events.pyo|485)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator '<CustomEventGenerator silent_install>' started (Opsiclientd.pyo|305)
[6] [Jun 12 21:09:49] [ event generator silent_install] Initializing event generator '<CustomEventGenerator silent_install>' (Events.pyo|477)
[6] [Jun 12 21:09:49] [ event generator on_demand ] Nothing to watch for (Events.pyo|571)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Getting next event... (Events.pyo|487)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator '<CustomEventGenerator on_shutdown>' started (Opsiclientd.pyo|305)
[6] [Jun 12 21:09:49] [ event generator on_shutdown ] Initializing event generator '<CustomEventGenerator on_shutdown>' (Events.pyo|477)
[6] [Jun 12 21:09:49] [ event generator silent_install] Activating event generator '<CustomEventGenerator silent_install>' (Events.pyo|485)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Searching pids of process name LogonUI.exe (session id: None) (Windows.pyo|1447)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator '<SyncCompletedEventGenerator sync_completed>' started (Opsiclientd.pyo|305)
[6] [Jun 12 21:09:49] [ event generator sync_completed] Initializing event generator '<SyncCompletedEventGenerator sync_completed>' (Events.pyo|477)
[6] [Jun 12 21:09:49] [ event generator silent_install] Getting next event... (Events.pyo|487)
[6] [Jun 12 21:09:49] [ event generator on_shutdown ] Activating event generator '<CustomEventGenerator on_shutdown>' (Events.pyo|485)
[6] [Jun 12 21:09:49] [ event generator software_on_demand] Initializing event generator '<SwOnDemandEventGenerator software_on_demand>' (Events.pyo|477)
[6] [Jun 12 21:09:49] [ event generator on_shutdown ] Getting next event... (Events.pyo|487)
[6] [Jun 12 21:09:49] [ event generator silent_install] Nothing to watch for (Events.pyo|571)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator '<SwOnDemandEventGenerator software_on_demand>' started (Opsiclientd.pyo|305)
[6] [Jun 12 21:09:49] [ event generator sync_completed] Activating event generator '<SyncCompletedEventGenerator sync_completed>' (Events.pyo|485)
[6] [Jun 12 21:09:49] [ event generator software_on_demand] Activating event generator '<SwOnDemandEventGenerator software_on_demand>' (Events.pyo|485)
[6] [Jun 12 21:09:49] [ event generator on_shutdown ] Nothing to watch for (Events.pyo|571)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Found process logonui.exe with matching name (pid 2668, session 1) (Windows.pyo|1470)
[6] [Jun 12 21:09:49] [ event generator software_on_demand] Getting next event... (Events.pyo|487)
[6] [Jun 12 21:09:49] [ event generator panic ] Initializing event generator '<PanicEventGenerator panic>' (Events.pyo|477)
[5] [Jun 12 21:09:49] [ opsiclientd ] Event generator '<PanicEventGenerator panic>' started (Opsiclientd.pyo|305)
[6] [Jun 12 21:09:49] [ event generator sync_completed] Getting next event... (Events.pyo|487)
[6] [Jun 12 21:09:49] [ event generator panic ] Activating event generator '<PanicEventGenerator panic>' (Events.pyo|485)
[5] [Jun 12 21:09:49] [ opsiclientd ] Waiting for gui startup (timeout: 120 seconds) (Opsiclientd.pyo|312)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Firing event '<ocdlib.Events.GUIStartupEvent object at 0x02878F70>' (Events.pyo|445)
[6] [Jun 12 21:09:49] [ event generator panic ] Getting next event... (Events.pyo|487)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Initializing event generator '<GUIStartupEventGenerator wait_for_gui>' (Events.pyo|477)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Event info: (Events.pyo|446)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Activating event generator '<GUIStartupEventGenerator wait_for_gui>' (Events.pyo|485)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Starting FireEventThread for listeners: [<OpsiclientdNT61(Thread-1, started daemon 3200)>] (Events.pyo|469)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Getting next event... (Events.pyo|487)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Searching pids of process name LogonUI.exe (session id: None) (Windows.pyo|1447)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Calling processEvent on listener <OpsiclientdNT61(Thread-1, started daemon 3200)> (Events.pyo|464)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Event generator '<GUIStartupEventGenerator gui_startup>' now deactivated after 1 event occurrences (Events.pyo|491)
[5] [Jun 12 21:09:49] [ opsiclientd ] Processing event <ocdlib.Events.GUIStartupEvent object at 0x02878F70> (Opsiclientd.pyo|384)
[6] [Jun 12 21:09:49] [ event generator gui_startup ] Event generator '<GUIStartupEventGenerator gui_startup>' exiting (Events.pyo|502)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Found process logonui.exe with matching name (pid 2668, session 1) (Windows.pyo|1470)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Testing preconditions of configs: [<EventConfig: wait_for_gui>] (Events.pyo|405)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Firing event '<ocdlib.Events.GUIStartupEvent object at 0x02878FF0>' (Events.pyo|445)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Event info: (Events.pyo|446)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Starting FireEventThread for listeners: [<ocdlib.Opsiclientd.WaitForGUI object at 0x02878C50>] (Events.pyo|469)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Event generator '<GUIStartupEventGenerator wait_for_gui>' now deactivated after 1 event occurrences (Events.pyo|491)
[6] [Jun 12 21:09:49] [ event processing gui_startup ] Session id set to 1 (EventProcessing.pyo|175)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Calling processEvent on listener <ocdlib.Opsiclientd.WaitForGUI object at 0x02878C50> (Events.pyo|464)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Event generator '<GUIStartupEventGenerator wait_for_gui>' exiting (Events.pyo|502)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] GUI started (Opsiclientd.pyo|168)
[5] [Jun 12 21:09:49] [ event processing gui_startup ] ============= EventProcessingThread for occurrcence of event 'gui_startup' started ============= (EventProcessing.pyo|1153)
[5] [Jun 12 21:09:49] [ event processing gui_startup ] Starting notification server on port 44003 (EventProcessing.pyo|196)
[6] [Jun 12 21:09:49] [ event generator wait_for_gui ] Notification server starting (Message.pyo|594)
[2] [Jun 12 21:09:49] [ event generator wait_for_gui ] Traceback: (Logger.pyo|757)
[2] [Jun 12 21:09:49] [ event generator wait_for_gui ] File "OPSI\Util\Message.pyo", line 599, in run
(Logger.pyo|757)
[2] [Jun 12 21:09:49] [ event generator wait_for_gui ] File "twisted\internet\posixbase.pyo", line 478, in listenTCP
(Logger.pyo|757)
[5] [Jun 12 21:09:49] [ opsiclientd ] Done waiting for GUI (Opsiclientd.pyo|314)
[2] [Jun 12 21:09:49] [ event generator wait_for_gui ] File "twisted\internet\tcp.pyo", line 983, in startListening
(Logger.pyo|757)
[2] [Jun 12 21:09:49] [ event generator wait_for_gui ] ==>>> Couldn't listen on 127.0.0.1:44003: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (Message.pyo|607)
[3] [Jun 12 21:09:50] [ event processing gui_startup ] Failed to start notification server: Couldn't listen on 127.0.0.1:44003: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (EventProcessing.pyo|228)
[6] [Jun 12 21:09:50] [ opsiclientd ] Notification server starting (Message.pyo|594)
[2] [Jun 12 21:09:50] [ opsiclientd ] Traceback: (Logger.pyo|757)
[2] [Jun 12 21:09:50] [ opsiclientd ] File "OPSI\Util\Message.pyo", line 599, in run
(Logger.pyo|757)
[2] [Jun 12 21:09:50] [ opsiclientd ] File "twisted\internet\posixbase.pyo", line 478, in listenTCP
(Logger.pyo|757)
[2] [Jun 12 21:09:50] [ opsiclientd ] File "twisted\internet\tcp.pyo", line 983, in startListening
(Logger.pyo|757)
[2] [Jun 12 21:09:50] [ opsiclientd ] ==>>> Couldn't listen on 127.0.0.1:44004: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (Message.pyo|607)
[3] [Jun 12 21:09:51] [ event processing gui_startup ] Failed to start notification server: Couldn't listen on 127.0.0.1:44004: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (EventProcessing.pyo|228)
[6] [Jun 12 21:09:51] [ event generator wait_for_gui ] Notification server starting (Message.pyo|594)
[2] [Jun 12 21:09:51] [ event generator wait_for_gui ] Traceback: (Logger.pyo|757)
[2] [Jun 12 21:09:51] [ event generator wait_for_gui ] File "OPSI\Util\Message.pyo", line 599, in run
(Logger.pyo|757)
[2] [Jun 12 21:09:51] [ event generator wait_for_gui ] File "twisted\internet\posixbase.pyo", line 478, in listenTCP
(Logger.pyo|757)
[2] [Jun 12 21:09:51] [ event generator wait_for_gui ] File "twisted\internet\tcp.pyo", line 983, in startListening
(Logger.pyo|757)
[2] [Jun 12 21:09:51] [ event generator wait_for_gui ] ==>>> Couldn't listen on 127.0.0.1:44005: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (Message.pyo|607)
[3] [Jun 12 21:09:52] [ event processing gui_startup ] Failed to start notification server: Couldn't listen on 127.0.0.1:44005: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (EventProcessing.pyo|228)
[5] [Jun 12 21:09:52] [ event processing gui_startup ] Writing log to service (EventProcessing.pyo|259)
[4] [Jun 12 21:09:52] [ event processing gui_startup ] Cannot write log to service: not connected (EventProcessing.pyo|262)
[5] [Jun 12 21:09:52] [ opsiclientd ] Shutdown request in Registry: 0 (Windows.pyo|327)
[5] [Jun 12 21:09:52] [ opsiclientd ] Reboot request in Registry: 0 (Windows.pyo|311)
[5] [Jun 12 21:09:52] [ opsiclientd ] Block login now set to 'False' (Opsiclientd.pyo|109)
[6] [Jun 12 21:09:52] [ opsiclientd ] Terminating block login notifier app (pid 780) (Opsiclientd.pyo|146)
[6] [Jun 12 21:09:52] [ event processing gui_startup ] Stopping notification server (EventProcessing.pyo|237)
[6] [Jun 12 21:09:52] [ event generator wait_for_gui ] Notification server stopped (Message.pyo|636)
[3] [Jun 12 21:09:52] [ event processing gui_startup ] Failed to process event <ocdlib.Events.GUIStartupEvent object at 0x02878F70>: Failed to start notification server: Couldn't listen on 127.0.0.1:44005: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (EventProcessing.pyo|1303)
[2] [Jun 12 21:09:52] [ event processing gui_startup ] Traceback: (Logger.pyo|757)
[2] [Jun 12 21:09:52] [ event processing gui_startup ] File "ocdlib\EventProcessing.pyo", line 1170, in run
(Logger.pyo|757)
[2] [Jun 12 21:09:52] [ event processing gui_startup ] File "ocdlib\EventProcessing.pyo", line 231, in startNotificationServer
(Logger.pyo|757)
[2] [Jun 12 21:09:52] [ event processing gui_startup ] ==>>> Failed to start notification server: Couldn't listen on 127.0.0.1:44005: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted. (EventProcessing.pyo|1304)
[5] [Jun 12 21:09:52] [ event processing gui_startup ] ============= EventProcessingThread for event 'gui_startup' ended ============= (EventProcessing.pyo|1313)
[5] [Jun 12 21:09:52] [ opsiclientd ] Done processing event '<ocdlib.Events.GUIStartupEvent object at 0x02878F70>' (Opsiclientd.pyo|419)
[5] [Jun 12 21:09:54] [ opsiclientd ] No events processing, unblocking login (Opsiclientd.pyo|320)
[5] [Jun 12 21:09:54] [ opsiclientd ] Block login now set to 'False' (Opsiclientd.pyo|109)
Viele Grüße,
Stefan
