upgraded to debian buster and latest opsi bootimage can not be upgraded
Verfasst: 17 Okt 2019, 22:26
Hi all,
I upgraded to debian buster and install all new packages from opsi dor buster. Now i encounter an error. The opsi-linux-bootimage wont upgrade. this is what i get in the terminal:
root@opsi:~# apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/549 MB of archives.
After this operation, 2,331 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 32455 files and directories currently installed.)
Preparing to unpack .../opsi-linux-bootimage_20191015-2_all.deb ...
cp: cannot stat '/tftpboot/linux/pxelinux.cfg/install-grub-x64': No such file or directory
dpkg: error processing archive /var/cache/apt/archives/opsi-linux-bootimage_20191015-2_all.deb (--unpack):
new opsi-linux-bootimage package pre-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any ideas?
Any ideas?
