Windows 10 BUILD 1903
ittk
Beitrag von ittk »
Die Win10 BUILD 1903 ist endlich offiziell released.
Aber es gibt anscheinend mit der unattended.xml specialize Sektion aus dem win10-x64 Paket 4.1.0.0-15 wohl Probleme, sodass es nicht mehr installiert wird.
Kann das jemand bestätigen?
Re: Windows 10 BUILD 1903
Please look at this topic: viewtopic.php?f=7&t=11112
Aktualisiere dein Netboot-Produkt:
opsi-package-updater --repo uib_windows_experimental --use-inactive-repo -v update win10-x64 win10
ittk
Beitrag von ittk »
Danke, hat funktioniert.
a.ahindi
Beitrag von a.ahindi »
hi all ,
i try opsi-package-updater --repo uib_windows_experimental --use-inactive-repo -v update win10-x64 win10
but the command not worked (-bash: opsi-package-updater: command not found )
i try opsi-product-updater -i -vv and make an update and still the opsi-package-updater still not worked
also i read the manual
4.5. Install the Minimal opsi Products
To deploy software with opsi prepared packages exist. They contain amongst other things the agent that is required for managing clients.
It is possible to install the packages in automated or manual fashion. The automated way is recommended.
For this there is the tool opsi-package-updater. It will automatically retrieve current packages and then install them on the server. The configuration is made in the file /etc/opsi/opsi-package-updater.conf.
You should now download and install the opsi products with the command:
opsi-package-updater -v install
If the opsi-package-updater fails, it may be necessary to add a required proxy to the .repo configuration files under /etc/opsi/package-updater.repos.d/:
[repository_uib_windows]
proxy =
If you want to update installed packages sometime later you can use the following command:
opsi-package-updater -v update
More information on opsi-package-updater can be found in the manual.
and i cant find /etc/opsi/opsi-package-updater.conf file
I assume you are still on opsi4.0, please check if there is a command called opsi-product-updater. If so, please update to 4.1 following the instructions in the release notes.
a.ahindi
ThomasT hat geschrieben:I assume you are still on opsi4.0, please check if there is a command called opsi-product-updater. If so, please update to 4.1 following the instructions in the release notes.
yes i have opsi-product-updater
i do the updates
i search in manual and find this command for the updates what should i do to update opsi to version 4.1
a.ahindi
i do the steps but when i run
apt install opsi-server
i get
The following packages have unmet dependencies:
opsi-server : Depends: opsiconfd (>= 4.1.1) but 4.0.7.13-1 is to be installed
E: Unable to correct problems, you have held broken packages.
install
opsi-depotserver
first and then
opsi-server
Cheers
