sgdisk hangs on Intel "fake" RAID
julen
Kontaktdaten:
Beitrag von julen »
I'm trying to deploy opsi for installing the standard win7-x64 on a PC with an ASUSTeK PRIME Q27M-C motherboard.
When setting the on-board "RAID" (Fake-RAID) to RAID1, the miniroot image finds the /dev/md126 (as well as /dev/sda and /dev/sdb), but it is unable to write to it.
The log file hangs on:
[5] [Sep 07 19:37:09] Disk order: (opsisetuplib.py|78)
[5] [Sep 07 19:37:09]  - /dev/md126 (rotational? True) (sizeG 931) (uuid None) (opsisetuplib.py|80)
[5] [Sep 07 19:37:09]  - /dev/sda (rotational? True) (sizeG 931) (uuid None) (opsisetuplib.py|80)
[5] [Sep 07 19:37:09]  - /dev/sdb (rotational? True) (sizeG 931) (uuid None) (opsisetuplib.py|80)
[5] [Sep 07 19:37:09] Using disk device /dev/md126 (setup.py|826)
[5] [Sep 07 19:37:09] Check if disk /dev/md126 is ssd or classic (rotational) HD (opsisetuplib.py|85)
[5] [Sep 07 19:37:09] Disk /dev/md126 is rotational (Classic HD) (opsisetuplib.py|92)
[5] [Sep 07 19:37:09] Clear partition table of /dev/md126 (setup.py|848)
[6] [Sep 07 19:37:09] Executing: /usr/sbin/sgdisk --zap-all /dev/md126 (Posix.py|854)
[6] [Sep 07 19:37:09] Using encoding 'ANSI_X3.4-1968' (Posix.py|887)
From that point on, any attempt to use sgdisk, fdisk, blkid or anything that points to /dev/md126 gets stuck.
It feels like a kernel issue (module missing).
It also gets stuck if I run "dd" before the sgdisk calls, as:
dd if=/dev/zero of=/dev/md126 bs=512 count=1
/dev/disk/by-uuid is missing, and blkid does not display any UUID.
If I boot with a standard recent Debian 9 I don't see any storage devices at all, but with a recent CentOS7 I can run the
without problem.
Maybe the "dmraid=true" option should be passed to the bootloader and the module included in the miniroot image?
And sure... deploying in non-raid mode installs perfectly on /dev/sda. So it really looks like a module is missing.
opsi-linux-bootimage-20180713-1.1.noarch
opsipxeconfd-4.0.7.9-2.2.noarch
opsi-depotserver-4.0.7.3-3.2.noarch
Best regards
Julen
Re: sgdisk hangs on Intel "fake" RAID
the dmraid modules are included in the bootimage
which version of the desired netboot product are you using?
Are you running in EFI mode?
cheers
