no splash screen for bootimage
- SisterOfMercy
I like being able to see what the bootimage is doing (i.e. not hanging), and previously this was easily set by removing the 'splash' from the append line in the tftp configuration.
However, recent bootimages seem to have been changed, and now it shows a splash screen again. I think this one is different from the one set in the append line, this one happens later in the startup.
Re: no splash screen for bootimage
the opsi 4.1 bootimage has a splash screen
the splash screen was removed in opsi 4.0.6 because of size limitations of the tftpd.
However opsi 4.1 uses the tftpd-hpa, which doesnt have this restriction. Also opsi 4.0 experimental repositories have a opsi 4.1 bootimage along with a patched opsi-atftpd which also doesnt have the size limitation.
as it was the default in opsi 4.0.5 we wanted to return tro this default. A lot of people had issues with the missing splash screen becasue they saw some errors and were insecure about if everything is correct.
You can disable the splash screen by removing 'splash' from the pipe templates.
Cheers
Cheers
- SisterOfMercy
If these are the ones in /tftpboot/linux/pxelinux.cfg/, I have done that. It seemed to remove the first part of the splash screen but it comes on after booting the kernel. Hm, I will unpack a bootimage and look if I can find what it is doing or I will record the startup with and without splash in the tftp configuration.m.radtke hat geschrieben:You can disable the splash screen by removing 'splash' from the pipe templates.
- SisterOfMercy
The bootimage has this file: /etc/systemd/system/display.service
I think this shows the 'second' splash screen I was talking about.
[Unit]
DefaultDependencies=no
After=local-fs.target
Conflicts=getty@tty1.service
[Service]
StandardInput=tty
StandardOutput=tty
ExecStart=/usr/bin/fbi -d /dev/fb0\
--once --noverbose --autozoom /etc/opsi.png
[Install]
WantedBy=sysinit.target
