[solved]winpe failed
Verfasst: 12 Jun 2018, 08:54
beim Versuch ein PE zu erstellen, schlägt opsi-winpe fehl.
64Bit Windows 7 Client. WAIK ist installiert.
Mir scheint es, dass opsi-winpe nur auf WADK prüft und nicht nach WAIK.
Log als der Fehler auftritt.
(135) [6] [Jun 12 08:37:38:256] [opsi-winpe] If
(136) [6] [Jun 12 08:37:38:257] [opsi-winpe] Starting query if file exist ...
(137) [6] [Jun 12 08:37:38:257] [opsi-winpe] "C:\Program Files (x86)\Windows Kits\10\Assessment and Deployment Kit":
(138) [6] [Jun 12 08:37:38:257] [opsi-winpe] FileExists($InstallDir10$) <<< result false
(139) [6] [Jun 12 08:37:38:257] [opsi-winpe] Then
(140) [6] [Jun 12 08:37:38:257] [opsi-winpe] Else
(141) [3] [Jun 12 08:37:38:257] [opsi-winpe] Error: ---------------------------------------------------------------------
(142) [3] [Jun 12 08:37:38:257] [opsi-winpe] Error: ---------------------------------------------------------------------
(143) [3] [Jun 12 08:37:38:257] [opsi-winpe] Error: No Windows Preinstallation Environemt (8.0/10) found in common location.
(144) [3] [Jun 12 08:37:38:257] [opsi-winpe] Error: Please download and install an ADK from Microsoft first
(145) [3] [Jun 12 08:37:38:257] [opsi-winpe] Error: Download Locations:
(146) [3] [Jun 12 08:37:38:257] [opsi-winpe] Error: Windows ADK 8 from https://www.microsoft.com/en-us/downloa ... x?id=30652
(147) [3] [Jun 12 08:37:38:258] [opsi-winpe] Error: or Windows ADK 10 from http://go.microsoft.com/fwlink/p/?LinkId=526740
(148) [3] [Jun 12 08:37:38:258] [opsi-winpe] Error: alternatively use opsi-package ms-winadk10 for installation if available
(149) [3] [Jun 12 08:37:38:258] [opsi-winpe] Error: then use this script to create the custom WinPE for opsi netboot Installations
(150) [3] [Jun 12 08:37:38:258] [opsi-winpe] Error: ---------------------------------------------------------------------
(151) [3] [Jun 12 08:37:38:258] [opsi-winpe] Error: ---------------------------------------------------------------------
(152) [2] [Jun 12 08:37:38:258] [opsi-winpe] Error level set to fatal
(153) [6] [Jun 12 08:37:38:258] [opsi-winpe] Process aborted
