Opsi-Client service not running
Verfasst: 01 Mai 2018, 13:13
Hello
I am having problem with getting opsi-client working on my workstation.
I have tried uninstalling and reinstalling it, but it only works for a short while...
Client OS: Windows 10 [10.0.16299.371]
Opsi-client-agent 4.0.7.24-3
I have tried:
"Execute now" from opsi-configed does not work.
When Windows 10 boots up the login screen is not displayed for about 2 minutes.. no lockpad in the corner.
Any ideas? I have tried several reinstalls..
I have tried:
- Uninstall "opsi-client-agent" from Windows Add/Remove Programs.
- Deleted folders "C:\opsi.org" and "Program Files(x86)\opsi.org\opsi-client-agent"
- Run script "service-setup.cmd" from the opsi_depot_rw share (successfully).
- Client Agent is installed and software-packages waiting for installation are installed.
- After reboot there seems to be no connection.
