Sorry, beim Testen kommt man nicht immer dazu, alles sofort zu machen, die "normalen" Büro-Tätigkeiten sind oft vorzuziehen.
Ich darf einfach mal die ganze Log-Datei hier posten, denn ich weiß nicht, welcher Teil für Sie insbesondere interessant ist.
Hier ist sie:
[5] [Sep 02 08:48:55] [opsiclientd] Now using log-file 'c:\\tmp\\opsiclientd.log' (Logger.pyo|333)
[5] [Sep 02 08:48:56] [opsiclientd] Setting config value cache_service.storage_dir (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:57] [opsiclientd] Setting config value cache_service.backend_manager_config (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:57] [opsiclientd] Setting config value event_daemon_shutdown.active (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:57] [opsiclientd] Setting config value event_daemon_shutdown.type (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:57] [opsiclientd] Setting config value notification_server.interface (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:57] [opsiclientd] Setting config value notification_server.port (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:58] [opsiclientd] Setting config value global.log_level (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:58] [opsiclientd] Setting config value global.wait_for_gui_timeout (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:58] [opsiclientd] Setting config value global.wait_before_reboot (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:58] [opsiclientd] Setting config value global.wait_for_gui_application (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:59] [opsiclientd] Setting config value global.host_id (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:59] [opsiclientd] Setting config value global.opsi_host_key (opsiclientd.pyo|2151)
[5] [Sep 02 08:48:59] [opsiclientd] Setting config value global.wait_before_shutdown (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:00] [opsiclientd] Setting config value global.log_file (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:00] [opsiclientd] Now using log-file 'c:\\tmp\\opsiclientd.log' (Logger.pyo|333)
[5] [Sep 02 08:49:00] [opsiclientd] Setting config value control_server.ssl_server_cert_file (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:00] [opsiclientd] Setting config value control_server.static_dir (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:00] [opsiclientd] Setting config value control_server.ssl_server_key_file (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:01] [opsiclientd] Setting config value control_server.interface (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:01] [opsiclientd] Setting config value control_server.port (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:01] [opsiclientd] Setting config value opsiclientd_rpc.command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:01] [opsiclientd] Setting config value depot_server.url (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:02] [opsiclientd] Setting config value depot_server.drive (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:02] [opsiclientd] Setting config value depot_server.depot_id (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:03] [opsiclientd] Setting config value event_daemon_startup.active (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:03] [opsiclientd] Setting config value event_daemon_startup.type (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:03] [opsiclientd] Setting config value event_gui_startup.cache_products (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:03] [opsiclientd] Setting config value event_gui_startup.use_cached_config (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:03] [opsiclientd] Setting config value event_gui_startup.requires_cached_products (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:03] [opsiclientd] Setting config value event_gui_startup.block_login (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.user_cancelable (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.cache_max_bandwidth (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.lock_workstation (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.sync_config (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.message (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.write_log_to_service (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.update_config_file (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.event_notifier_command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:04] [opsiclientd] Setting config value event_gui_startup.get_config_from_service (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_gui_startup.logoff_current_user (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_gui_startup.action_notifier_command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_gui_startup.action_notifier_desktop (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_gui_startup.action_processor_command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_gui_startup.event_notifier_desktop (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_gui_startup.action_processor_desktop (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_gui_startup.type (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_gui_startup.update_action_processor (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value opsiclientd_notifier.command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value opsiclientd_notifier.block_notifier_command (opsiclientd.pyo|2151)
[3] [Sep 02 08:49:05] [opsiclientd] Refusing to set empty value for config value 'block_notifier_command' of section 'opsiclientd_notifier' (opsiclientd.pyo|2155)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.cache_products (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.write_log_to_service (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.cache_max_bandwidth (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.wql (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.active (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.message (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.update_config_file (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.event_notifier_command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.get_config_from_service (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.action_notifier_command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.warning_time (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.service_options (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.event_notifier_desktop (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.action_processor_desktop (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.action_processor_command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.type (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value event_vpn_startup.action_notifier_desktop (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value action_processor.command (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value action_processor.local_dir (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value action_processor.remote_dir (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value action_processor.run_as_user (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value action_processor.filename (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value config_service.url (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value config_service.server_id (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value config_service.user_cancellable_after (opsiclientd.pyo|2151)
[5] [Sep 02 08:49:05] [opsiclientd] Setting config value config_service.connection_timeout (opsiclientd.pyo|2151)
[4] [Sep 02 08:49:05] [opsiclientd] Config read (opsiclientd.pyo|2227)
[0] [Sep 02 08:49:05] [opsiclientd] Opsiclientd version: 0.5.7 (opsiclientd.pyo|2543)
[0] [Sep 02 08:49:05] [opsiclientd] Commandline: C:\Programme\opsi.org\preloginloader\opsiclientd.exe (opsiclientd.pyo|2544)
[0] [Sep 02 08:49:05] [opsiclientd] Working directory: C:\WINDOWS\system32 (opsiclientd.pyo|2545)
[4] [Sep 02 08:49:05] [opsiclientd] Using host id 'realxpclient1.schulepn.local' (opsiclientd.pyo|2546)
[5] [Sep 02 08:49:05] [opsiclientd] Action processor name 'opsi/winst', version '4.8.6.4' (opsiclientd.pyo|3080)
[4] [Sep 02 08:49:05] [opsiclientd] Starting control pipe (opsiclientd.pyo|2554)
[5] [Sep 02 08:49:05] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[4] [Sep 02 08:49:05] [opsiclientd] Control pipe started (opsiclientd.pyo|2558)
[4] [Sep 02 08:49:05] [opsiclientd] Starting control server (opsiclientd.pyo|2563)
[5] [Sep 02 08:49:05] [control server] ControlServer initiated (opsiclientd.pyo|1691)
[5] [Sep 02 08:49:05] [control server] creating root resource (opsiclientd.pyo|1696)
[4] [Sep 02 08:49:05] [opsiclientd] Control server started (opsiclientd.pyo|2572)
[4] [Sep 02 08:49:05] [opsiclientd] Starting cache service (opsiclientd.pyo|2577)
[4] [Sep 02 08:49:05] [opsiclientd] Cache service started (opsiclientd.pyo|2581)
[4] [Sep 02 08:49:05] [opsiclientd] Starting notification server (opsiclientd.pyo|2586)
[5] [Sep 02 08:49:05] [opsiclientd] cannot send notification 'subjectsChanged', no client connected (Util.pyo|547)
[5] [Sep 02 08:49:05] [notification server] Notification server starting (Util.pyo|588)
[4] [Sep 02 08:49:05] [opsiclientd] Notification server started (opsiclientd.pyo|2604)
Event 'gui_startup' args:
"logoffCurrentUser" : false,
"actionNotifierCommand" : "C:\\Programme\\\\opsi.org\\\\preloginloader\\\\notifier.exe -p 4442 -s notifier\\\\action.ini",
"actionProcessorDesktop" : "current",
"lockWorkstation" : false,
"blockLogin" : true,
"syncConfig" : false,
"eventNotifierDesktop" : "current",
"eventNotifierCommand" : "C:\\Programme\\\\opsi.org\\\\preloginloader\\\\notifier.exe -p 4442 -s notifier\\\\event.ini",
"cacheMaxBandwidth" : 0,
"updateConfigFile" : true,
"actionProcessorCommand" : "%action_processor.command%",
"actionNotifierDesktop" : "current",
"updateActionProcessor" : true,
"getConfigFromService" : true,
"userCancelable" : false,
"useCachedConfig" : false,
"cacheProducts" : false,
"requiresCachedProducts" : false,
"message" : "Starting to process product actions. Attention: the computer may restart. Please save all unsaved data now.",
"writeLogToService" : true
(opsiclientd.pyo|2466)
[4] [Sep 02 08:49:05] [opsiclientd] gui startup event 'gui_startup' created (opsiclientd.pyo|2482)
[4] [Sep 02 08:49:05] [opsiclientd] Event 'daemon_shutdown' is deactivated (opsiclientd.pyo|2397)
[4] [Sep 02 08:49:05] [opsiclientd] Event 'daemon_startup' is deactivated (opsiclientd.pyo|2397)
[4] [Sep 02 08:49:05] [opsiclientd] Event 'vpn_startup' is deactivated (opsiclientd.pyo|2397)
[5] [Sep 02 08:49:05] [event gui_startup] Activating event '<event: gui_startup>' (opsiclientd.pyo|239)
[4] [Sep 02 08:49:05] [opsiclientd] Event '<event: gui_startup>' started (opsiclientd.pyo|2490)
[5] [Sep 02 08:49:05] [event panic] Activating event '<event: panic>' (opsiclientd.pyo|239)
[4] [Sep 02 08:49:05] [control server] Control server is accepting HTTPS requests on port 4441 (opsiclientd.pyo|1703)
[4] [Sep 02 08:49:05] [opsiclientd] Event '<event: panic>' started (opsiclientd.pyo|2490)
[5] [Sep 02 08:49:05] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[4] [Sep 02 08:49:06] [control server] Control server exiting (opsiclientd.pyo|1709)
[4] [Sep 02 08:49:06] [opsiclientd] Waiting for gui startup (timeout: 120 seconds) (opsiclientd.pyo|2615)
[5] [Sep 02 08:49:06] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[5] [Sep 02 08:49:06] [opsiclientd] Starting wait for GUI app (opsiclientd.pyo|2507)
[4] [Sep 02 08:49:06] [opsiclientd] rpc getBlockLogin: blockLogin is 'True' (opsiclientd.pyo|2863)
[5] [Sep 02 08:49:06] [opsiclientd] Searching pids of process name winlogon.exe (only in session id: 0) (Windows.pyo|517)
[5] [Sep 02 08:49:06] [control pipe] Took 0.000s to process getBlockLogin() (opsiclientd.pyo|509)
[5] [Sep 02 08:49:06] [opsiclientd] Found process winlogon.exe with pid 672 in session 0 (Windows.pyo|535)
[4] [Sep 02 08:49:06] [opsiclientd] Executing: C:\Programme\\opsi.org\\preloginloader\\notifier.exe -p 4442 -s notifier\\wait_for_gui.ini (Windows.pyo|653)
[5] [Sep 02 08:49:06] [opsiclientd] Process startet, pid: 188 (Windows.pyo|655)
[5] [Sep 02 08:49:07] [event wait_for_gui] Activating event '<event: wait_for_gui>' (opsiclientd.pyo|239)
[5] [Sep 02 08:49:08] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[5] [Sep 02 08:49:08] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[5] [Sep 02 08:49:08] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[4] [Sep 02 08:49:09] [opsiclientd] rpc getBlockLogin: blockLogin is 'True' (opsiclientd.pyo|2863)
[5] [Sep 02 08:49:09] [control pipe] Took 0.078s to process getBlockLogin() (opsiclientd.pyo|509)
[5] [Sep 02 08:49:10] [notification server] client connection made (Util.pyo|459)
[5] [Sep 02 08:49:10] [notification server] sending notification 'subjectsChanged' to clients (Util.pyo|549)
[5] [Sep 02 08:49:11] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[5] [Sep 02 08:49:11] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[5] [Sep 02 08:49:11] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[4] [Sep 02 08:49:11] [opsiclientd] rpc getBlockLogin: blockLogin is 'True' (opsiclientd.pyo|2863)
[5] [Sep 02 08:49:11] [control pipe] Took 0.079s to process getBlockLogin() (opsiclientd.pyo|509)
[5] [Sep 02 08:49:12] [event wait_for_gui] Searching pids of process name winlogon.exe (only in session id: None) (Windows.pyo|517)
[5] [Sep 02 08:49:12] [event gui_startup] Searching pids of process name winlogon.exe (only in session id: None) (Windows.pyo|517)
[5] [Sep 02 08:49:12] [event wait_for_gui] Found process winlogon.exe with pid 672 in session 0 (Windows.pyo|535)
[5] [Sep 02 08:49:12] [event gui_startup] Found process winlogon.exe with pid 672 in session 0 (Windows.pyo|535)
[5] [Sep 02 08:49:12] [event wait_for_gui] Process 'winlogon.exe' is running on activation of event <event: wait_for_gui> => firing (opsiclientd.pyo|370)
[5] [Sep 02 08:49:12] [event gui_startup] Process 'winlogon.exe' is running on activation of event <event: gui_startup> => firing (opsiclientd.pyo|370)
[5] [Sep 02 08:49:12] [event wait_for_gui] Event '<event: wait_for_gui>' occured (opsiclientd.pyo|241)
[5] [Sep 02 08:49:12] [event gui_startup] Event '<event: gui_startup>' occured (opsiclientd.pyo|241)
[4] [Sep 02 08:49:12] [event wait_for_gui] Firing event '<event: wait_for_gui>' (opsiclientd.pyo|274)
[4] [Sep 02 08:49:12] [event gui_startup] Firing event '<event: gui_startup>' (opsiclientd.pyo|274)
[5] [Sep 02 08:49:12] [event wait_for_gui] Event '<event: wait_for_gui>' now deactivated after 1 occurrences (opsiclientd.pyo|246)
[5] [Sep 02 08:49:12] Terminating wait for GUI app (pid 188) (opsiclientd.pyo|2524)
[5] [Sep 02 08:49:12] [event gui_startup] Event '<event: gui_startup>' now deactivated after 1 occurrences (opsiclientd.pyo|246)
[4] [Sep 02 08:49:12] [opsiclientd] Processing event <event: gui_startup> (opsiclientd.pyo|2685)
[5] [Sep 02 08:49:12] [notification server] sending notification 'messageChanged' to clients (Util.pyo|549)
[4] [Sep 02 08:49:12] [event processing] ============= EventProcessingThread for event '<event: gui_startup>' started ============= (opsiclientd.pyo|1861)
[5] [Sep 02 08:49:12] [opsiclientd] Searching pids of process name winlogon.exe (only in session id: 0) (Windows.pyo|517)
[5] [Sep 02 08:49:12] [opsiclientd] Found process winlogon.exe with pid 672 in session 0 (Windows.pyo|535)
[4] [Sep 02 08:49:12] [opsiclientd] Executing: C:\Programme\\opsi.org\\preloginloader\\opsiclientd_rpc.exe "realxpclient1.schulepn.local" "*** confidential ***" "4441" "setCurrentActiveDesktopName(System.getActiveDesktopName())" (Windows.pyo|653)
[5] [Sep 02 08:49:12] [opsiclientd] Process startet, pid: 936 (Windows.pyo|655)
[4] [Sep 02 08:49:12] [opsiclientd] Gui started (opsiclientd.pyo|2617)
[5] [Sep 02 08:49:12] [notification server] client connection lost (Util.pyo|464)
[5] [Sep 02 08:49:12] [opsiclientd] Waiting for process ending: 936 (Windows.pyo|658)
[5] [Sep 02 08:49:13] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[5] [Sep 02 08:49:13] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[5] [Sep 02 08:49:13] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[5] [Sep 02 08:49:14] [control server] ControlServerResourceJsonRpc: processing POST request (opsiclientd.pyo|769)
[4] [Sep 02 08:49:14] [opsiclientd] rpc getBlockLogin: blockLogin is 'True' (opsiclientd.pyo|2863)
[5] [Sep 02 08:49:14] [control server] Got json-rpc request: {'params': [], 'id': 1, 'method': 'getPossibleMethods_listOfHashes'} (opsiclientd.pyo|902)
[5] [Sep 02 08:49:14] [control pipe] Took 0.015s to process getBlockLogin() (opsiclientd.pyo|509)
[4] [Sep 02 08:49:14] [control server] Authorization request from realxpclient1.schulepn.local@127.0.0.1 (opsiclientd.pyo|930)
[5] [Sep 02 08:49:14] [control server] RPC method: 'getPossibleMethods_listOfHashes' params: '[]' (opsiclientd.pyo|958)
[5] [Sep 02 08:49:14] [control server] Got json-rpc request: {'params': ['Winlogon'], 'id': 1, 'method': 'setCurrentActiveDesktopName'} (opsiclientd.pyo|902)
[5] [Sep 02 08:49:14] [control server] RPC method: 'setCurrentActiveDesktopName' params: '['Winlogon']' (opsiclientd.pyo|958)
[4] [Sep 02 08:49:14] [opsiclientd] rpc setCurrentActiveDesktopName: current active desktop name set to 'Winlogon' (opsiclientd.pyo|2956)
[4] [Sep 02 08:49:14] [opsiclientd] Process ended: 936 (Windows.pyo|661)
[4] [Sep 02 08:49:14] [event processing] Starting notifier application in session '0' on desktop 'Winlogon' (opsiclientd.pyo|1841)
[5] [Sep 02 08:49:14] [event processing] Searching pids of process name winlogon.exe (only in session id: 0) (Windows.pyo|517)
[5] [Sep 02 08:49:14] [event processing] Found process winlogon.exe with pid 672 in session 0 (Windows.pyo|535)
[4] [Sep 02 08:49:14] [event processing] Executing: C:\Programme\\opsi.org\\preloginloader\\notifier.exe -p 4442 -s notifier\\action.ini (Windows.pyo|653)
[5] [Sep 02 08:49:14] [event processing] Process startet, pid: 1032 (Windows.pyo|655)
[5] [Sep 02 08:49:15] [notification server] client connection made (Util.pyo|459)
[5] [Sep 02 08:49:15] [notification server] sending notification 'subjectsChanged' to clients (Util.pyo|549)
[5] [Sep 02 08:49:16] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[5] [Sep 02 08:49:16] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[5] [Sep 02 08:49:16] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[4] [Sep 02 08:49:16] [opsiclientd] rpc getBlockLogin: blockLogin is 'True' (opsiclientd.pyo|2863)
[5] [Sep 02 08:49:16] [control pipe] Took 0.000s to process getBlockLogin() (opsiclientd.pyo|509)
[4] [Sep 02 08:49:17] [opsiclientd] Getting config from service (opsiclientd.pyo|2272)
[5] [Sep 02 08:49:17] [notification server] sending notification 'messageChanged' to clients (Util.pyo|549)
[5] [Sep 02 08:49:17] [opsiclientd] Starting ServiceConnectionThread, timeout is 10 seconds (opsiclientd.pyo|2731)
[4] [Sep 02 08:49:17] [service connection] Connecting to config server 'https://192.168.0.28:4447/rpc' #1 (opsiclientd.pyo|1780)
[5] [Sep 02 08:49:17] [service connection] Opening https connection to 192.168.0.28:4447 (JSONRPC.pyo|172)
[5] [Sep 02 08:49:18] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[5] [Sep 02 08:49:18] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[5] [Sep 02 08:49:18] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[4] [Sep 02 08:49:18] [opsiclientd] rpc getBlockLogin: blockLogin is 'True' (opsiclientd.pyo|2863)
[5] [Sep 02 08:49:18] [control pipe] Took 0.016s to process getBlockLogin() (opsiclientd.pyo|509)
[5] [Sep 02 08:49:18] [notification server] sending notification 'messageChanged' to clients (Util.pyo|549)
[5] [Sep 02 08:49:19] [service connection] Successfully connected to '192.168.0.28:4447' (JSONRPC.pyo|186)
[5] [Sep 02 08:49:19] [notification server] sending notification 'messageChanged' to clients (Util.pyo|549)
[4] [Sep 02 08:49:19] [service connection] Connected to config server 'https://192.168.0.28:4447/rpc' (opsiclientd.pyo|1792)
[5] [Sep 02 08:49:19] [notification server] sending notification 'subjectsChanged' to clients (Util.pyo|549)
[5] [Sep 02 08:49:19] [opsiclientd] Updated config_service.host_id to 'opsiserver.schulepn.local' (opsiclientd.pyo|2766)
[1] [Sep 02 08:49:19] [opsiclientd] Vista module currently disabled (opsiclientd.pyo|2798)
[4] [Sep 02 08:49:19] [opsiclientd] Writing log to service (opsiclientd.pyo|2316)
[2] [Sep 02 08:49:19] [opsiclientd] Failed to get config from service: Vista module currently disabled (opsiclientd.pyo|2312)
[5] [Sep 02 08:49:19] [opsiclientd] rebootRequested: 0 (opsiclientd.pyo|3182)
[5] [Sep 02 08:49:19] [opsiclientd] shutdownRequested: 0 (opsiclientd.pyo|3200)
[2] [Sep 02 08:49:19] [opsiclientd] Failed to write log to service: Not connected to config service (opsiclientd.pyo|2330)
[4] [Sep 02 08:49:19] [event processing] Stopping notifier application (opsiclientd.pyo|1850)
[5] [Sep 02 08:49:19] [opsiclientd] Searching pids of process name winlogon.exe (only in session id: 0) (Windows.pyo|517)
[5] [Sep 02 08:49:19] [opsiclientd] Found process winlogon.exe with pid 672 in session 0 (Windows.pyo|535)
[4] [Sep 02 08:49:19] [opsiclientd] Executing: C:\Programme\\opsi.org\\preloginloader\\opsiclientd_rpc.exe "realxpclient1.schulepn.local" "*** confidential ***" "4441" "exit(); System.closeProcessWindows(processId = 1032)" (Windows.pyo|653)
[5] [Sep 02 08:49:19] [opsiclientd] Process startet, pid: 1764 (Windows.pyo|655)
[5] [Sep 02 08:49:20] [control server] ControlServerResourceJsonRpc: processing POST request (opsiclientd.pyo|769)
[5] [Sep 02 08:49:20] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[5] [Sep 02 08:49:20] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[5] [Sep 02 08:49:20] [control server] Got json-rpc request: {'params': [], 'id': 1, 'method': 'getPossibleMethods_listOfHashes'} (opsiclientd.pyo|902)
[5] [Sep 02 08:49:20] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[4] [Sep 02 08:49:20] [control server] Authorization request from realxpclient1.schulepn.local@127.0.0.1 (opsiclientd.pyo|930)
[4] [Sep 02 08:49:20] [opsiclientd] rpc getBlockLogin: blockLogin is 'True' (opsiclientd.pyo|2863)
[5] [Sep 02 08:49:20] [control server] RPC method: 'getPossibleMethods_listOfHashes' params: '[]' (opsiclientd.pyo|958)
[5] [Sep 02 08:49:20] [control pipe] Took 0.000s to process getBlockLogin() (opsiclientd.pyo|509)
[5] [Sep 02 08:49:22] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[5] [Sep 02 08:49:22] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[5] [Sep 02 08:49:22] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[2] [Sep 02 08:49:22] [event processing] Failed to process event <event: gui_startup>: Vista module currently disabled (opsiclientd.pyo|1981)
[4] [Sep 02 08:49:22] [opsiclientd] rpc getBlockLogin: blockLogin is 'False' (opsiclientd.pyo|2863)
[1] [Sep 02 08:49:22] [event processing] Traceback: (Logger.pyo|647)
[5] [Sep 02 08:49:22] [control pipe] Took 0.000s to process getBlockLogin() (opsiclientd.pyo|509)
[1] [Sep 02 08:49:22] [event processing] line 1952 in 'run' in file 'opsiclientd.pyo' (Logger.pyo|647)
[5] [Sep 02 08:49:23] [notification server] client connection lost (Util.pyo|464)
[1] [Sep 02 08:49:23] [event processing] line 2276 in 'getConfigFromService' in file 'opsiclientd.pyo' (Logger.pyo|647)
[1] [Sep 02 08:49:23] [event processing] line 2773 in 'connectConfigServer' in file 'opsiclientd.pyo' (Logger.pyo|647)
[1] [Sep 02 08:49:23] [event processing] ==>>> Vista module currently disabled (opsiclientd.pyo|1982)
[4] [Sep 02 08:49:23] [event processing] ============= EventProcessingThread for event '<event: gui_startup>' ended ============= (opsiclientd.pyo|1985)
[4] [Sep 02 08:49:23] [opsiclientd] Done processing event '<event: gui_startup>' (opsiclientd.pyo|2696)
[5] [Sep 02 08:49:25] [control pipe] Creating pipe \\.\pipe\opsiclientd (opsiclientd.pyo|644)
[5] [Sep 02 08:49:25] [control pipe] Received rpc from pipe '{"id": 1, "method": "getBlockLogin", "params": []}' (opsiclientd.pyo|603)
[5] [Sep 02 08:49:25] [control pipe] RPC method: 'getBlockLogin' params: '[]' (opsiclientd.pyo|502)
[4] [Sep 02 08:49:25] [opsiclientd] rpc getBlockLogin: blockLogin is 'False' (opsiclientd.pyo|2863)
[5] [Sep 02 08:49:25] [control pipe] Took 0.000s to process getBlockLogin() (opsiclientd.pyo|509)
Im Backend des OPSI verändert sich überhaupt nichts, OPSI hat zwar das LOG-File dort oben geschrieben, tut aber im Backend so, als hätte man überhaupt nichts veranlasst. Der Schalter steht noch auf "setup" und bei "Result" ist nichts eingetragen, nach der obige Vorgang durchgelaufen ist.
