migrate only client to new OPSI
lebourg
Beitrag von lebourg »
I wanted to upgrade opsi from version 4.1 to 4.2 but I encountered several problems.
So I decided to create a new server and therefore to review all my packages. My backend is in mysql and I want to import only the clients and not the packages because I want to update them.
Do you know a method to import only the hosts without the packages?
Best regards.
fkalweit
Re: migrate only client to new OPSI
Beitrag von fkalweit »
Hello,
maybe you could take a opsi-backup and restore the backup on the new server with --new-server-id <fqdn>.
Then you can delete the products you dont want.
After that execute a opsi-setup --cleanup-backend.
Make sure that your 4.1 server packages, client agent and current DB is up to date (opsi-setup --update-mysql)
Regards
Fabian
lebourg
Hello,
Thank you for your feedback. This is indeed the solution I had also found.
But, I wanted to find a solution that avoided me to uninstall the packages to reinstall them in a new version.
In this case, I will try to update the current server again and I will modify my packages as I go along.
Regards
You could try to extract the hostObjects of the old server via
opsi-admin -d method host_getObjects '' '{"type":"OpsiClient"}' > hostobjects.json
Copy the hostobjects.json to your new server and import the Clients via
opsi-admin -d method host_createObjects < hostobjects.json
