unable to load project file inside opsi-setup-detector
gallak
Beitrag von gallak »
Hello
I'm using the fascinating opsi-setup-detector tool.
Everything is fine and thanks to the projet file .osd wich is a simple json, I plan to build a simple CI for make package and push them on a opsi test server.
For that, packager should be able to re open a project.
But , When I try to load a .osd file I got An error :
"Read project file exception. Details: EJSON: Unknown object member: "Items"
As attachement the osd file
opsi-project.txt
renamed with .txt extension
(4.01 KiB) 4224-mal heruntergeladen
I try to delete the "Items" key : no success
I try to open the fiel from local drive : no success
Opsi-setup-detector is the last version 4.2.0.7 on windows 10 workstation
Thank's for all
Antoine
Re: unable to load project file inside opsi-setup-detector
things like that happen by testing undocumented new features ;-)
This should be fixed in 4.2.0.8 which is the stable version right now.
cheers
gallak
Thanks a lot !
Another question , Paquet version could be only an integer ... Is it possible to set this field has a string
It could be useful for tagging package status like testing/stable
My workaround is to tag in in description, but it's a workaround .
By the way I'm a volunteer to test next opsi-setup-detector version if you want !
cheers !
