opsi update from 4.0 to 4.1
a.ahindi
Beitrag von a.ahindi »
after star the update process as the manual steps :
echo "deb http://download.opensuse.org/repositories/home:/uibmz:/opsi:/4.1:/stable/xUbuntu_16.04/ /" > /etc/apt/sources.list.d/opsi.list
wget -nv https://download.opensuse.org/repositories/home:uibmz:opsi:4.1:stable/xUbuntu_16.04/Release.key -O Release.key
apt-key add - < Release.key
update-inetd --remove tftp
apt update
apt install opsi-tftpd-hpa
apt upgrade
apt install opsi-server
opsi-setup --update-mysql
on the next step
i get this error
[2] [Jun 24 12:55:42] Traceback: (Logger.py|798)
[2] [Jun 24 12:55:42] File "/usr/bin/opsi-setup", line 1159, in <module>
main()
(Logger.py|798)
[2] [Jun 24 12:55:42] File "/usr/bin/opsi-setup", line 1115, in main
initializeBackends(ipAddress)
(Logger.py|798)
[2] [Jun 24 12:55:42] File "/usr/lib/python2.7/dist-packages/OPSI/Util/Task/InitializeBackend.py", line 68, in initializeBackends
with BackendManager(**managerConfig) as backend:
(Logger.py|798)
[2] [Jun 24 12:55:42] File "/usr/lib/python2.7/dist-packages/OPSI/Backend/BackendManager.py", line 227, in __init__
self._backend = BackendDispatcher(context=self, **kwargs)
(Logger.py|798)
[2] [Jun 24 12:55:42] File "/usr/lib/python2.7/dist-packages/OPSI/Backend/BackendManager.py", line 327, in __init__
raise BackendConfigurationError(u"Dispatcher not configured")
(Logger.py|798)
[2] [Jun 24 12:55:42] ==>>> Backend configuration error: Dispatcher not configured (opsi-setup|1163)
ERROR: Backend configuration error: Dispatcher not configured
Re: opsi update from 4.0 to 4.1
Could you please post your dispatch.conf? Typically located here:
/etc/opsi/backendManager/dispatch.conf
a.ahindi
ThomasT hat geschrieben:Could you please post your dispatch.conf? Typically located here:
nothing its empty
"dispatch.conf" 0L, 0C
but in the new updated file from the 4.0 to 4.1 (the old one dispatch.conf.defualt the ne one .example )
backend_.* : file, mysql, opsipxeconfd
host_.* : file, opsipxeconfd
configState_.* : file, opsipxeconfd
license.* : mysql
softwareLicense.* : mysql
audit.* : mysql
.* : file
Use the english forums for english threads!
Your dispatch.conf looks broken. I'd suggest using the one from your last working backup instead.
