I can't pxeboot anymore. Log is growing extremely fast. In about 5 minutes from 0 to 200.000kb.
In opsipxeconfd.log shows this :
(threading.py|545)
[3] [Feb 16 07:57:53] Exception in thread Thread-11:
File "/usr/lib/python2.6/threading.py", line 532, in __bootstrap_inner
self.run()
File "/usr/bin/opsipxeconfd", line 610, in run
self._pipe = os.open(self.pxefile, os.O_WRONLY | os.O_NONBLOCK)
OSError: [Errno 2] No such file or directory: '/tftpboot/linux/pxelinux.cfg/01-d4-be-d9-19-bb-93'
But in /tftpboot/linux/pxelinux.cfg this entry exsists.
This is on config server. I can image from depot
With regards,
Kees...
Cannot pxe boot. Log file very big (SOLVED)
Zuletzt geändert von loggenk am 21 Feb 2017, 16:40, insgesamt 1-mal geändert.
Re: Cannot pxe boot. Log file very big
did you check the rights?
We also offer professional support and trainings. Might come in handy
-Niko
-Niko
import OPSIRe: Cannot pxe boot. Log file very big
Hi Niko,
Thnxs for repying.
Yes, i did check the rights. To me it seems all rights are okay.
A working backup from 2 weeks ago also doesn't work.
And as for the support. I'm trying to get budget for it!!
Greetings,
Kees...
Thnxs for repying.
Greetings,
Kees...
Hi, problem solved. After turning off ipv6 everything works fine
