Output of lshw
opsi-client
description: Notebook
product: SATELLITE C660 (PSC1QE-03H00LDU)
vendor: TOSHIBA
version: PSC1QE-03H00LDU
serial: 8B064438K
width: 32 bits
capabilities: smbios-2.6 dmi-2.6 smp-1.4 smp
configuration: boot=normal chassis=notebook cpus=2 family=ABCDEFGHIJKLMNOPQRSTUVWXYZ sku=PSC1QE-03H00LDU uuid=BFF3F5B1-B820-11E0-BDC4-B870F4C9EB03
*-core
description: Motherboard
product: PWWHA
vendor: TOSHIBA
physical id: 0
version: 1.00
serial: 0123456789AB
slot: NULL
*-firmware
description: BIOS
vendor: TOSHIBA
physical id: 0
version: 1.50
date: 12/15/2011
capacity: 1984KiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification
*-cpu:0
description: CPU
product: Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 6.10.7
serial: 0002-06A7-0000-0000-0000-0000
slot: CPU 1
capacity: 3800MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx rdtscp constant_tsc arch_perfmon pebs bts xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave avx lahf_lm arat epb pln pts dtherm tpr_shadow vnmi flexpriority ept vpid xsaveopt
configuration: cores=2 enabledcores=1 id=0 threads=2
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 64KiB
capabilities: internal write-back unified
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 512KiB
capabilities: internal varies unified
*-cache:2 DISABLED
description: L3 cache
physical id: 7
slot: L3-Cache
capacity: 3MiB
capabilities: internal unified
*-logicalcpu:0
description: Logical CPU
physical id: 0.1
width: 64 bits
capabilities: logical
*-logicalcpu:1
physical id: 0.2
width: 64 bits
*-logicalcpu:2
physical id: 0.3
width: 64 bits
*-logicalcpu:3
physical id: 0.4
width: 64 bits
*-logicalcpu:4
physical id: 0.5
width: 64 bits
*-logicalcpu:5
physical id: 0.6
width: 64 bits
*-logicalcpu:6
physical id: 0.7
width: 64 bits
*-logicalcpu:7
physical id: 0.8
width: 64 bits
*-logicalcpu:8
physical id: 0.9
width: 64 bits
*-logicalcpu:9
physical id: 0.a
width: 64 bits
*-logicalcpu:10
physical id: 0.b
width: 64 bits
*-logicalcpu:11
physical id: 0.c
width: 64 bits
*-logicalcpu:12
physical id: 0.d
width: 64 bits
*-logicalcpu:13
physical id: 0.e
width: 64 bits
*-logicalcpu:14
physical id: 0.f
width: 64 bits
*-logicalcpu:15
physical id: 0.10
width: 64 bits
*-memory
description: System Memory
physical id: e
slot: System board or motherboard
*-bank:0
description: SODIMM DDR3 Synchronous 1333 MHz (0.8 ns)
product: M471B5273DH0-CH9
vendor: Samsung
physical id: 0
serial: B1453593
slot: ChannelA-DIMM0
width: 64 bits
clock: 1333MHz (0.8ns)
*-bank:1
description: DIMM [empty]
product: [Empty]
vendor: [Empty]
physical id: 1
serial: [Empty]
slot: ChannelA-DIMM1
*-bank:2
product: [Empty]
vendor: [Empty]
physical id: 2
serial: [Empty]
slot: ChannelB-DIMM0
*-bank:3
product: [Empty]
vendor: [Empty]
physical id: 3
serial: [Empty]
slot: ChannelB-DIMM1
*-cpu:1
physical id: 1
bus info: cpu@1
version: 6.10.7
capabilities: vmx ht
configuration: id=2
*-logicalcpu:0
physical id: 2.1
*-logicalcpu:1
physical id: 2.2
*-logicalcpu:2
physical id: 2.3
*-logicalcpu:3
physical id: 2.4
*-logicalcpu:4
physical id: 2.5
*-logicalcpu:5
physical id: 2.6
*-logicalcpu:6
physical id: 2.7
*-logicalcpu:7
physical id: 2.8
*-logicalcpu:8
physical id: 2.9
*-logicalcpu:9
physical id: 2.a
*-logicalcpu:10
physical id: 2.b
*-logicalcpu:11
physical id: 2.c
*-logicalcpu:12
physical id: 2.d
*-logicalcpu:13
physical id: 2.e
*-logicalcpu:14
physical id: 2.f
*-logicalcpu:15
physical id: 2.10
*-pci
description: Host bridge
product: 2nd Generation Core Processor Family DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 09
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 09
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:24 ioport:e000(size=4096) memory:f6000000-f70fffff ioport:e0000000(size=301989888)
*-display UNCLAIMED
description: VGA compatible controller
product: GT218M [GeForce 315M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
*-multimedia UNCLAIMED
description: Audio device
product: High Definition Audio Controller
physical id: 0.1
bus info: pci@0000:01:00.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
resources: memory:f7080000-f7083fff
*-communication UNCLAIMED
description: Communication controller
product: 6 Series/C200 Series Chipset Family MEI Controller #1
physical id: 16
bus info: pci@0000:00:16.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
resources: memory:f720a000-f720a00f
*-usb:0
description: USB controller
product: 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2
physical id: 1a
bus info: pci@0000:00:1a.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=0
resources: irq:16 memory:f7208000-f72083ff
product: 6 Series/C200 Series Chipset Family High Definition Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 04
width: 64 bits
clock: 33MHz
resources: memory:f7200000-f7203fff
*-pci:1
product: 6 Series/C200 Series Chipset Family PCI Express Root Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: b4
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
resources: irq:16 ioport:d000(size=4096) ioport:f2100000(size=1048576)
*-network
description: Ethernet interface
product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 05
serial: b8:70:f4:c9:eb:03
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=10.23.20.184 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:26 ioport:d000(size=256) memory:f2104000-f2104fff memory:f2100000-f2103fff
*-pci:2
product: 6 Series/C200 Series Chipset Family PCI Express Root Port 2
physical id: 1c.1
bus info: pci@0000:00:1c.1
version: b4
width: 32 bits
clock: 33MHz
resources: irq:17 ioport:c000(size=4096) memory:f7100000-f71fffff
*-network UNCLAIMED
description: Network controller
product: RTL8188CE 802.11b/g/n WiFi Adapter
physical id: 0
bus info: pci@0000:03:00.0
version: 01
width: 64 bits
clock: 33MHz
resources: ioport:c000(size=256) memory:f7100000-f7103fff
*-usb:1
product: 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 04
width: 32 bits
clock: 33MHz
resources: irq:23 memory:f7207000-f72073ff
*-isa
description: ISA bridge
product: HM65 Express Chipset Family LPC Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver=lpc_ich latency=0
resources: irq:0
*-storage
description: SATA controller
product: 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 04
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:25 ioport:f070(size=8) ioport:f060(size=4) ioport:f050(size=8) ioport:f040(size=4) ioport:f020(size=32) memory:f7206000-f72067ff
*-serial UNCLAIMED
description: SMBus
product: 6 Series/C200 Series Chipset Family SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 04
width: 64 bits
clock: 33MHz
resources: memory:f7205000-f72050ff ioport:f000(size=32)
*-scsi:0
physical id: 2
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: KINGSTON SV300S3
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: BBF1
serial: 50026B723A047D69
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 sectorsize=512 signature=61e80618
*-volume
description: Windows NTFS volume
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
version: 3.1
serial: 489d66ae-cd24-f34e-88a2-852c70c32c4a
capacity: 55GiB
capabilities: primary bootable ntfs initialized
configuration: clustersize=4096 created=2016-05-27 23:35:48 filesystem=ntfs label=WINDOWS state=clean
*-scsi:1
physical id: 3
logical name: scsi2
*-cdrom UNCLAIMED
description: SCSI CD-ROM
product: CDDVDW TS-L633F
vendor: TSSTcorp
physical id: 0.0.0
bus info: scsi@2:0.0.0
version: TF01
capabilities: removable
*-scsi:2
physical id: 5
bus info: usb@1:1.3
logical name: scsi8
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk
description: SCSI Disk
physical id: 0.0.0
bus info: scsi@8:0.0.0
logical name: /dev/sdb
configuration: sectorsize=512
*-scsi:3
physical id: 6
bus info: usb@2:1.1
logical name: scsi9
*-disk
physical id: 0.0.0
bus info: scsi@9:0.0.0
logical name: /dev/sdc
configuration: sectorsize=512 signature=103e3de3
*-volume
description: Windows FAT volume
vendor: MSDOS5.0
physical id: 1
bus info: scsi@9:0.0.0,1
logical name: /dev/sdc1
logical name: /mount
version: FAT32
serial: f4cc-cbfc
capacity: 7399MiB
capabilities: primary fat initialized
configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro state=mounted
*-battery:0
description: Nickel Cadmium Battery
product: BATT 1
vendor: Battery Manufacturer
physical id: 1
version: 01/01/2007
serial: Serial Number
slot: Location of the battery
capacity: 232mWh
configuration: voltage=5.0V
*-battery:1
product: Battery Name
physical id: 2
version: 01/01/2007
*-power UNCLAIMED
description: To Be Filled By O.E.M.
product: To Be Filled By O.E.M.
vendor: To Be Filled By O.E.M.
physical id: 3
version: To Be Filled By O.E.M.
serial: To Be Filled By O.E.M.
capacity: 32768mWh
*-network:0 DISABLED
physical id: 4
logical name: dummy0
serial: 7a:35:3a:62:c8:bf
capabilities: ethernet physical
configuration: broadcast=yes driver=dummy driverversion=1.0
*-network:1 DISABLED
physical id: 5
logical name: bond0
serial: e6:ec:4b:bf:19:93
configuration: autonegotiation=off broadcast=yes driver=bonding driverversion=3.7.1 firmware=2 link=no master=yes multicast=yes
Output of lspci -vvt
-[0000:00]-+-00.0 Intel Corporation 2nd Generation Core Processor Family DRAM Controller
+-01.0-[01]--+-00.0 NVIDIA Corporation GT218M [GeForce 315M]
| \-00.1 NVIDIA Corporation High Definition Audio Controller
+-16.0 Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1
+-1a.0 Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2
+-1b.0 Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller
+-1c.0-[02]----00.0 Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
+-1c.1-[03]----00.0 Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter
+-1d.0 Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1
+-1f.0 Intel Corporation HM65 Express Chipset Family LPC Controller
+-1f.2 Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller
\-1f.3 Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller
/var/log/dmesg
pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
pci_bus 0000:00: resource 13 [mem 0xd0000000-0xfeafffff window]
pci_bus 0000:00: resource 14 [mem 0xfed40000-0xfed44fff window]
pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf70fffff]
pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
pci_bus 0000:02: resource 2 [mem 0xf2100000-0xf21fffff 64bit pref]
pci_bus 0000:03: resource 0 [io 0xc000-0xcfff]
pci_bus 0000:03: resource 1 [mem 0xf7100000-0xf71fffff]
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
NET: Registered protocol family 1
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
pci 0000:01:00.0: Video device with shadowed ROM
PCI: CLS 64 bytes, default 64
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 85472K (f2486000 - f77fe000)
clocksource tsc: mask: 0xffffffffffffffff max_cycles: 0x1e33f018a84, max_idle_ns: 440795242248 ns
RAPL PMU detected, API unit is 2^-32 Joules, 3 fixed counters 163840 ms ovfl timer
hw unit of domain pp0-core 2^-16 Joules
hw unit of domain package 2^-16 Joules
hw unit of domain pp1-gpu 2^-16 Joules
microcode: CPU0 sig=0x206a7, pf=0x10, revision=0x23
microcode: CPU1 sig=0x206a7, pf=0x10, revision=0x23
microcode: CPU2 sig=0x206a7, pf=0x10, revision=0x23
microcode: CPU3 sig=0x206a7, pf=0x10, revision=0x23
microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
futex hash table entries: 1024 (order: 3, 32768 bytes)
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(1464610664.731:1): initialized
HugeTLB registered 4 MB page size, pre-allocated 0 pages
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Key type cifs.spnego registered
Key type cifs.idmap registered
ntfs: driver 2.1.32 [Flags: R/W].
romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
fuse init (API version 7.23)
NET: Registered protocol family 38
Key type asymmetric registered
bounce: pool size: 64 pages
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
cpcihp_zt5550: ZT5550 CompactPCI Hot Plug Driver version: 0.2
cpcihp_generic: Generic port I/O CompactPCI Hot Plug Driver version: 0.1
cpcihp_generic: not configured, disabling.
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
acpiphp_ibm: ibm_acpiphp_init: acpi_walk_namespace failed
hv_vmbus: registering driver hyperv_fb
vesafb: mode is 1024x768x16, linelength=2048, pages=1
vesafb: protected mode interface info at c000:cfa0
vesafb: pmi: set display start = c00cd003, set palette = c00cd05e
vesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
vesafb: framebuffer at 0xf1000000, mapped to 0xf8400000, using 3072k, total 14336k
Console: switching to colour frame buffer device 128x48
fb0: VESA VGA frame buffer device
intel_idle: MWAIT substates: 0x21120
intel_idle: v0.4 model 0x2A
intel_idle: lapic_timer_reliable_states 0xffffffff
ipmi message handler version 39.2
ipmi device interface
IPMI System Interface driver.
ipmi_si: Unable to find any System Interface(s)
IPMI Watchdog: driver initialized
Copyright (C) 2004 MontaVista Software - IPMI Powerdown via sys_reboot.
input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
ACPI: Lid Switch [LID0]
input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
ACPI: Power Button [PWRB]
input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
ACPI: Power Button [PWRF]
ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
acpi device:0a: registered as cooling_device0
acpi device:0e: registered as cooling_device1
input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:08/LNXVIDEO:00/input/input3
Non-volatile memory driver v1.3
Linux agpgart interface v0.103
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
HP CISS Driver (v 3.6.26)
MM: desc_per_page = 128
nbd: registered device at major 43
mtip32xx Version 1.3.1
null: module loaded
Loading iSCSI transport class v2.0-870.
Loading Adaptec I2O RAID: Version 2.4 Build 5go
Detecting Adaptec I2O RAID controllers...
Adaptec aacraid driver 1.2-1[40709]-ms
aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
isci: Intel(R) C600 SAS Controller Driver - version 1.2.0
scsi: <fdomain> Detection failed (no card)
iscsi: registered transport (qla4xxx)
QLogic iSCSI HBA Driver
megasas: 06.806.08.00-rc1
mpt2sas version 20.100.00.00 loaded
mpt3sas version 04.100.00.00 loaded
GDT-HA: Storage RAID Controller Driver. Version: 3.05
3ware Storage Controller device driver for Linux v1.26.02.003.
3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
nsp32: loading...
ipr: IBM Power RAID SCSI Device Driver version: 2.6.1 (March 12, 2015)
RocketRAID 3xxx/4xxx Controller driver v1.8
stex: Promise SuperTrak EX Driver version: 4.6.0000.4
libcxgbi:libcxgbi_init_module: tag itt 0x1fff, 13 bits, age 0xf, 4 bits.
libcxgbi:ddp_setup_host_page_size: system PAGE 4096, ddp idx 0.
Chelsio T3 iSCSI Driver cxgb3i v2.0.0 (Jun. 2010)
iscsi: registered transport (cxgb3i)
Chelsio T4/T5 iSCSI Driver cxgb4i v0.9.4
iscsi: registered transport (cxgb4i)
QLogic NetXtreme II iSCSI Driver bnx2i v2.7.10.1 (Jul 16, 2014)
iscsi: registered transport (bnx2i)
esas2r: driver will not be loaded because no ATTO esas2r devices were found
VMware PVSCSI driver - version 1.0.5.0-k
hv_vmbus: registering driver hv_storvsc
ahci 0000:00:1f.2: version 3.0
ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ems apst
scsi host0: ahci
scsi host1: ahci
scsi host2: ahci
scsi host3: ahci
scsi host4: ahci
scsi host5: ahci
ata1: SATA max UDMA/133 abar m2048@0xf7206000 port 0xf7206100 irq 25
ata2: DUMMY
ata3: SATA max UDMA/133 abar m2048@0xf7206000 port 0xf7206200 irq 25
ata4: DUMMY
ata5: DUMMY
ata6: DUMMY
scsi host6: pata_legacy
ata7: PATA max PIO4 cmd 0x1f0 ctl 0x3f6 irq 14
ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
ata1.00: ATA-8: KINGSTON SV300S37A60G, 505ABBF1, max UDMA/133
ata1.00: 117231408 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access ATA KINGSTON SV300S3 BBF1 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.8 GiB)
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI disk
ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata3.00: ATAPI: TSSTcorp CDDVDW TS-L633F, TF01, max UDMA/100
ata3.00: configured for UDMA/100
scsi 2:0:0:0: CD-ROM TSSTcorp CDDVDW TS-L633F TF01 PQ: 0 ANSI: 5
scsi 2:0:0:0: Attached scsi generic sg1 type 5
scsi host7: pata_legacy
ata8: PATA max PIO4 cmd 0x170 ctl 0x376 irq 15
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
eql: Equalizer2002: Simon Janes (simon@ncm.com) and David S. Miller (davem@redhat.com)
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
arcnet loaded.
arcnet: RFC1201 "standard" (`a') encapsulation support loaded.
arcnet: RFC1051 "simple standard" (`s') encapsulation support loaded.
arcnet: raw mode (`r') encapsulation support loaded.
arcnet: cap mode (`c') encapsulation support loaded.
arcnet: COM90xx chipset support
S3: No ARCnet cards found.
arcnet: COM90xx IO-mapped mode support (by David Woodhouse et el.)
E-mail me if you actually test this driver, please!
arc%d: No autoprobe for IO mapped cards; you must specify the base address!
arcnet: RIM I (entirely mem-mapped) support
E-mail me if you actually test the RIM I driver, please!
Given: node 00h, shmem 0h, irq 0
No autoprobe for RIM I; you must specify the shmem and irq!
arcnet: COM20020 PCI support
pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de
Atheros(R) L2 Ethernet Driver - version 2.2.3
Copyright (c) 2007 Atheros Corporation.
cnic: QLogic cnicDriver v2.5.21 (January 29, 2015)
bnx2x: Broadcom NetXtreme II 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.710.51-0 (2014/02/10)
QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
enic: Cisco VIC Ethernet NIC Driver, ver 2.1.1.83
dmfe: Davicom DM9xxx net driver, version 1.36.4 (2002-01-17)
v1.01-e (2.4 port) Sep-11-2006 Donald Becker <becker@scyld.com>
http://www.scyld.com/network/drivers.html
uli526x: ULi M5261/M5263 net driver, version 0.9.3 (2005-7-29)
vxge: Copyright(c) 2002-2010 Exar Corp.
vxge: Driver version: 2.5.3.22640-k
e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
e100: Copyright(c) 1999-2006 Intel Corporation
e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
e1000: Copyright (c) 1999-2006 Intel Corporation.
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
igb: Intel(R) Gigabit Ethernet Network Driver - version 5.2.15-k
igb: Copyright (c) 2007-2014 Intel Corporation.
igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.0.2-k
igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.0.1-k
ixgbe: Copyright (c) 1999-2014 Intel Corporation.
ixgbevf: Intel(R) 10 Gigabit PCI Express Virtual Function Network Driver - version 2.12.1-k
ixgbevf: Copyright (c) 2009 - 2012 Intel Corporation.
i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.3.2-k
i40e: Copyright (c) 2013 - 2014 Intel Corporation.
ixgb: Intel(R) PRO/10GbE Network Driver - version 1.0.135-k2-NAPI
ixgb: Copyright (c) 1999-2008 Intel Corporation.
i40evf: Intel(R) XL710/X710 Virtual Function Network Driver - version 1.2.25
Intel(R) Ethernet Switch Host Interface Driver - version 0.15.2-k
Copyright (c) 2013 Intel Corporation.
jme: JMicron JMC2XX ethernet driver version 1.0.8
sky2: driver version 1.30
myri10ge: Version 1.5.3-1.534
ns83820.c: National Semiconductor DP83820 10/100/1000 driver.
QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.3.62
QLogic/NetXen Network Driver v4.0.82
r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
r8169 0000:02:00.0 eth0: RTL8105e at 0xf8026000, b8:70:f4:c9:eb:03, XID 00a00000 IRQ 26
Solarflare NET driver v4.0
tehuti: Tehuti Networks(R) Network Driver, 7.29.3
tehuti: Options: hw_csum
tlan: ThunderLAN driver v1.17
tlan: 0 devices installed, PCI: 0 EISA: 0
VMware vmxnet3 virtual NIC driver - version 1.3.5.0-k-NAPI
hv_vmbus: registering driver hv_netvsc
Fusion MPT base driver 3.04.20
Copyright (c) 1999-2008 LSI Corporation
Fusion MPT SPI Host driver 3.04.20
Fusion MPT SAS Host driver 3.04.20
Fusion MPT misc device (ioctl) driver 3.04.20
mptctl: Registered with Fusion MPT base driver
mptctl: /dev/mptctl @ (major,minor=10,220)
aoe: AoE v85 initialised.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ehci-pci 0000:00:1a.0: EHCI Host Controller
ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
ehci-pci 0000:00:1a.0: debug port 2
ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7208000
ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.1.0 ehci_hcd
usb usb1: SerialNumber: 0000:00:1a.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-pci 0000:00:1d.0: EHCI Host Controller
ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
ehci-pci 0000:00:1d.0: debug port 2
ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7207000
ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 4.1.0 ehci_hcd
usb usb2: SerialNumber: 0000:00:1d.0
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ehci-platform: EHCI generic platform driver
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-pci: OHCI PCI platform driver
ohci-platform: OHCI generic platform driver
uhci_hcd: USB Universal Host Controller Interface driver
fusbh200_hcd: FUSBH200 Host Controller (EHCI) Driver
Warning! fusbh200_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
fotg210_hcd: FOTG210 Host Controller (EHCI) Driver
\x014Warning! fotg210_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver uas
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-onetouch
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver ums-usbat
i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 KBD port at 0x60,0x64 irq 1
usb 1-1: new high-speed USB device number 2 using ehci-pci
serio: i8042 AUX port at 0x60,0x64 irq 12
hv_vmbus: registering driver hyperv_keyboard
mousedev: PS/2 mouse device common for all mice
Driver for 1-wire Dallas network protocol.
md: linear personality registered for level -1
md: raid0 personality registered for level 0
md: raid1 personality registered for level 1
md: raid10 personality registered for level 10
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
md: multipath personality registered for level -4
input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
md: faulty personality registered for level -5
device-mapper: uevent: version 1.0.3
usb 2-1: new high-speed USB device number 2 using ehci-pci
device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: dm-devel@redhat.com
device-mapper: multipath: version 1.9.0 loaded
device-mapper: multipath round-robin: version 1.0.0 loaded
device-mapper: multipath queue-length: version 0.1.0 loaded
usb 1-1: New USB device found, idVendor=8087, idProduct=0024
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 6 ports detected
device-mapper: multipath service-time: version 0.2.0 loaded
device-mapper: dm-log-userspace: version 1.3.0 loaded
device-mapper: raid: Loading target version 1.6.0
device-mapper: cache-policy-mq: version 1.3.0 loaded
device-mapper: cache cleaner: version 1.0.0 loaded
hv_vmbus: registering driver hid_hyperv
dell_wmi: No known WMI GUID found
dell_wmi_aio: No known WMI GUID found
hv_utils: Registering HyperV Utility Driver
hv_vmbus: registering driver hv_util
hv_vmbus: registering driver hv_balloon
NET: Registered protocol family 15
usb 2-1: New USB device found, idVendor=8087, idProduct=0024
usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 6 ports detected
NET: Registered protocol family 33
Key type rxrpc registered
Key type rxrpc_s registered
RxRPC: Registered security type 2 'rxkad'
9pnet: Installing 9P2000 support
Key type dns_resolver registered
Key type ceph registered
libceph: loaded (mon/osd proto 15/24)
Using IPI No-Shortcut mode
Btrfs loaded, debug=on
Key type encrypted registered
console [netcon0] enabled
netconsole: network logging started
Freeing unused kernel memory: 636K (c20cd000 - c216c000)
systemd-udevd[2441]: starting version 204
usb 1-1.3: new high-speed USB device number 3 using ehci-pci
ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20150410/utaddress-254)
ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
ACPI: AC Adapter [ACAD] (on-line)
ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPRF) (20150410/utaddress-254)
ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\_SB_.LDIO)
usb 2-1.2: new low-speed USB device number 3 using ehci-pci
usb 1-1.3: New USB device found, idVendor=0bda, idProduct=0138
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.3: Product: USB2.0-CRW
usb 1-1.3: Manufacturer: Generic
usb 1-1.3: SerialNumber: 20090516388200000
usb-storage 1-1.3:1.0: USB Mass Storage device detected
scsi host8: usb-storage 1-1.3:1.0
ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150410/utaddress-254)
usb 1-1.4: new high-speed USB device number 4 using ehci-pci
ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPRF) (20150410/utaddress-254)
ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\_SB_.LDIO) (20150410/utaddress-254)
ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150410/utaddress-254)
ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPRF) (20150410/utaddress-254)
ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\_SB_.LDIO) (20150410/utaddress-254)
ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150410/utaddress-254)
lpc_ich: Resource conflict(s) found affecting gpio_ich
usb 2-1.2: New USB device found, idVendor=045e, idProduct=00cb
usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 2-1.2: Product: Microsoft Basic Optical Mouse v2.0
usb 2-1.2: Manufacturer: Microsoft
input: Microsoft Microsoft Basic Optical Mouse v2.0 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:045E:00CB.0001/input/input7
hid-generic 0003:045E:00CB.0001: input: USB HID v1.11 Mouse [Microsoft Microsoft Basic Optical Mouse v2.0 ] on usb-0000:00:1d.0-1.2/input0
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usb 1-1.4: New USB device found, idVendor=04f2, idProduct=b1d6
usb 1-1.4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
usb 1-1.4: Product: CNF9055
usb 1-1.4: Manufacturer: Sonix Technology Co., Ltd.
[Firmware Bug]: battery: (dis)charge rate invalid.
ACPI: Battery Slot [BAT1] (battery present)
random: init urandom read with 26 bits of entropy available
systemd-udevd[2671]: starting version 204
scsi 8:0:0:0: Direct-Access Generic- Multi-Card 1.00 PQ: 0 ANSI: 0 CCS
sd 8:0:0:0: Attached scsi generic sg2 type 0
sd 8:0:0:0: [sdb] Attached SCSI removable disk
psmouse serio1: synaptics: queried max coordinates: x [..5692], y [..4680]
init: failsafe main process (2893) killed by TERM signal
psmouse serio1: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04733/0xa40000/0xa0000, board id: 0, fw id: 582762
init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
init: udev-fallback-graphics main process (2991) terminated with status 1
input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input6
Output of dmidecode
# dmidecode 2.12
SMBIOS 2.6 present.
52 structures occupying 2665 bytes.
Table at 0xCF521018.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: TOSHIBA
Version: 1.50
Release Date: 12/15/2011
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 2048 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 1.50
Firmware Revision: 1.80
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: TOSHIBA
Product Name: SATELLITE C660
Version: PSC1QE-03H00LDU
Serial Number: 8B064438K
UUID: B1F5F3BF-20B8-E011-BDC4-B870F4C9EB03
Wake-up Type: Power Switch
SKU Number: PSC1QE-03H00LDU
Family: ABCDEFGHIJKLMNOPQRSTUVWXYZ
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Product Name: PWWHA
Version: 1.00
Serial Number: 0123456789AB
Asset Tag: NULL
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: NULL
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Version: N/A
Serial Number: None
Asset Tag: *
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000020
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: CPU 1
Type: Central Processor
Family: Core 2 Duo
Manufacturer: Intel
ID: A7 06 02 00 FF FB EB BF
Signature: Type 0, Family 6, Model 42, Stepping 7
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz
Voltage: 0.0 V
External Clock: 100 MHz
Max Speed: 3800 MHz
Current Speed: 2100 MHz
Status: Populated, Enabled
Upgrade: Other
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 2
Core Enabled: 1
Thread Count: 2
Characteristics:
64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 64 kB
Maximum Size: 64 kB
Supported SRAM Types:
Other
Installed SRAM Type: Other
Speed: Unknown
Error Correction Type: None
System Type: Unified
Associativity: 8-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Operational Mode: Varies With Memory Address
Installed Size: 512 kB
Maximum Size: 512 kB
Other
Speed: Unknown
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3-Cache
Configuration: Disabled, Not Socketed, Level 3
Operational Mode: Unknown
Installed Size: 3072 kB
Maximum Size: 3072 kB
Other
Speed: Unknown
Associativity: Other
Handle 0x0008, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: PS2Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0009, DMI type 8, 9 bytes
External Reference Designator: Keyboard
Port Type: Keyboard Port
Handle 0x000A, DMI type 9, 17 bytes
System Slot Information
Designation: J6B2
Type: x16 PCI Express
Current Usage: In Use
Length: Long
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Bus Address: 0000:00:01.0
Handle 0x000B, DMI type 10, 6 bytes
On Board Device Information
Type: Sound
Status: Disabled
Description: Realtek HDA-00
Handle 0x000C, DMI type 11, 5 bytes
OEM Strings
String 1: PSC1QE-03H00LDU,SSC1Q03H00LDU
String 2: mzRxjzHsFkyWI
String 3: hAf94rUayE3tJ
String 4: 5QPNYcyC8-vpr
Handle 0x000D, DMI type 12, 5 bytes
System Configuration Options
Option 1: SMI:00B2C102
Option 2: DSN:0520B627A340D796
Option 3: DSN:M471B5273DH0-CH9 B1453593
Option 4: DSN:A62B
Handle 0x0036, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Abbreviated
Installable Languages: 3
eng
jpn
fra
Currently Installed Language: eng
Handle 0x000E, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Maximum Capacity: 32 GB
Error Information Handle: 0x000F
Number Of Devices: 4
Handle 0x0010, DMI type 17, 28 bytes
Memory Device
Array Handle: 0x000E
Error Information Handle: 0x0012
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: ChannelA-DIMM0
Bank Locator: BANK 0
Type: DDR3
Type Detail: Synchronous
Speed: 1333 MHz
Manufacturer: Samsung
Serial Number: B1453593
Asset Tag: 9876543210
Part Number: M471B5273DH0-CH9
Rank: Unknown
Handle 0x0013, DMI type 17, 28 bytes
Memory Device
Error Information Handle: No Error
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: ChannelA-DIMM1
Bank Locator: BANK 1
Type: Unknown
Type Detail: None
Speed: Unknown
Manufacturer: [Empty]
Serial Number: [Empty]
Part Number: [Empty]
Rank: Unknown
Handle 0x0014, DMI type 17, 28 bytes
Memory Device
Error Information Handle: 0x0015
Data Width: Unknown
Form Factor: DIMM
Set: None
Locator: ChannelB-DIMM0
Bank Locator: BANK 2
Type: Unknown
Type Detail: None
Speed: Unknown
Rank: Unknown
Handle 0x0016, DMI type 17, 28 bytes
Memory Device
Data Width: Unknown
Form Factor: DIMM
Set: None
Locator: ChannelB-DIMM1
Bank Locator: BANK 3
Type: Unknown
Type Detail: None
Speed: Unknown
Rank: Unknown
Handle 0x000F, DMI type 18, 23 bytes
32-bit Memory Error Information
Type: Unknown
Granularity: Unknown
Operation: Unknown
Vendor Syndrome: Unknown
Memory Array Address: Unknown
Device Address: Unknown
Resolution: Unknown
Handle 0x0012, DMI type 18, 23 bytes
Type: Unknown
Operation: Unknown
Resolution: Unknown
Handle 0x0015, DMI type 18, 23 bytes
Type: Unknown
Operation: Unknown
Resolution: Unknown
Handle 0x0018, DMI type 18, 23 bytes
Type: Unknown
Operation: Unknown
Resolution: Unknown
Handle 0x001B, DMI type 18, 23 bytes
Type: Unknown
Operation: Unknown
Resolution: Unknown
Handle 0x0017, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Array Handle: 0x000E
Partition Width: 4
Handle 0x0011, DMI type 20, 19 bytes
Memory Device Mapped Address
Range Size: 4 GB
Physical Device Handle: 0x0010
Memory Array Mapped Address Handle: 0x0017
Partition Row Position: Unknown
Interleave Position: 1
Interleaved Data Depth: 1
Handle 0x001D, DMI type 22, 26 bytes
Portable Battery
Manufacturer: Battery Manufacturer
Manufacture Date: 01/01/2007
Serial Number: Serial Number
Chemistry: Nickel Cadmium
Design Capacity: 232 mWh
Design Voltage: 5000 mV
SBDS Version: 01.12.912
Maximum Error: Unknown
OEM-specific Information: 0x12345678
Handle 0x001E, DMI type 22, 26 bytes
Portable Battery
Design Capacity: Unknown
Design Voltage: Unknown
SBDS Version: SBDS Version Number
Handle 0x0023, DMI type 26, 22 bytes
Voltage Probe
Description: LM78A
Status: <OUT OF SPEC>
Maximum Value: Unknown
Minimum Value: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
OEM-specific Information: 0x00000000
Nominal Value: Unknown
Handle 0x0029, DMI type 27, 14 bytes
Cooling Device
Temperature Probe Handle: 0x0026
Type: <OUT OF SPEC>
Cooling Unit Group: 1
Nominal Speed: Unknown Or Non-rotating
Handle 0x002C, DMI type 27, 14 bytes
Cooling Device
Type: <OUT OF SPEC>
Handle 0x0026, DMI type 28, 22 bytes
Temperature Probe
Description: LM78A
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x002F, DMI type 29, 22 bytes
Electrical Current Probe
Description: ABC
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x0021, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0022, DMI type 34, 11 bytes
Management Device
Description: LM78-1
Type: LM78
Address: 0x00000000
Address Type: I/O Port
Handle 0x0025, DMI type 35, 11 bytes
Management Device Component
Description: To Be Filled By O.E.M.
Management Device Handle: 0x0022
Component Handle: 0x0022
Threshold Handle: 0x0023
Handle 0x0028, DMI type 35, 11 bytes
Component Handle: 0x0025
Threshold Handle: 0x0026
Handle 0x002B, DMI type 35, 11 bytes
Component Handle: 0x0028
Threshold Handle: 0x0029
Handle 0x002E, DMI type 35, 11 bytes
Component Handle: 0x002B
Threshold Handle: 0x002C
Handle 0x0031, DMI type 35, 11 bytes
Component Handle: 0x002E
Handle 0x0024, DMI type 36, 16 bytes
Management Device Threshold Data
Lower Non-critical Threshold: 1
Upper Non-critical Threshold: 2
Lower Critical Threshold: 3
Upper Critical Threshold: 4
Lower Non-recoverable Threshold: 5
Upper Non-recoverable Threshold: 6
Handle 0x0027, DMI type 36, 16 bytes
Handle 0x002A, DMI type 36, 16 bytes
Handle 0x002D, DMI type 36, 16 bytes
Handle 0x0030, DMI type 36, 16 bytes
Handle 0x0032, DMI type 39, 22 bytes
System Power Supply
Power Unit Group: 1
Name: To Be Filled By O.E.M.
Manufacturer: To Be Filled By O.E.M.
Model Part Number: To Be Filled By O.E.M.
Revision: To Be Filled By O.E.M.
Max Power Capacity: Unknown
Status: Not Present
Type: <OUT OF SPEC>
Input Voltage Range Switching: <OUT OF SPEC>
Plugged: Yes
Hot Replaceable: No
Input Voltage Probe Handle: 0x0023
Cooling Device Handle: 0x0029
Input Current Probe Handle: 0x002F
Handle 0x0033, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Onboard IGD
Type: Video
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:02.0
Handle 0x0034, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Onboard LAN
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:19.0
Handle 0x0035, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Onboard 1394
Type: Other
Status: Enabled
Type Instance: 1
Bus Address: 0000:03:1c.2
Handle 0x0037, DMI type 131, 64 bytes
OEM-specific Type
Header and Data:
83 40 37 00 31 00 00 00 00 00 00 00 00 00 00 00
F8 00 49 1C FF FF FF FF 01 00 00 00 00 00 07 00
AD 04 04 00 00 00 00 00 C8 00 FF FF 00 00 00 00
00 00 00 00 D2 00 00 00 76 50 72 6F 00 00 00 00
Handle 0x0038, DMI type 127, 4 bytes
End Of Table
There's also no /proc/asound directory. I can't seem to find much about not detecting any sound hardware. Most issues are with getting the sound working, but we only have to detect the type of card.
