Windows Client installation
hwassie
Beitrag von hwassie »
I am totaly new to OPSI so this might be a silly question. Opsi looks like a perfect solution for our regular upgrade of software. We downloaded the VM image of the OPSI server and got it running. As I understand from the documentation there is also a client - opsi-winst. After searching on goolge en in the forms I cannot find any place to download it. Is there infact a install for the client on windows or what am I missing here?
Thanks
H
Re: Windows Client installation
You have to download and install the opsi-packages preloginloader and opsi-winst.
The packages are here:
http://download.uib.de/opsi3.3/produkte/essential/
To install the needed products you can run the following commands on your opsi server:
cd /home/opsiproducts
wget -r -l1 -nd -A '*.opsi' http://download.uib.de/opsi3.3/produkte/essential
opsi-package-manager -i *.opsi
After installation of products is completed you can install the opsi agent on a client:
* connect the network share \\<your-server-name>\opt_pcbin to drive p:
* open the folder p:\install\preloginloader
* run service_setup.cmd
hwassie
Thank you for the help, we are downloading now and we will test soon.
H
