Add product dependencies and parameters
ronin
Beitrag von ronin »
First i want to give credits to author of this great tool.
I made first packages thanks to it.
But i'm just wondering how to add product dependencies and parameters.
For example I want to create add to product silverlight dependencie and parameters to setup.exe:
setup.exe HomeServer=www.example.org
Also I wondering if it's possible to create office 2016 install package (from Office Deployment Tool)
And provide setup.exe variables from configuration.xml file via opsi parameters.
Thank you for any tips
pandel
Re: Add product dependencies and parameters
Beitrag von pandel »
Thread moved to english support forum, because question is not specific to opsi PackageBuilder
Hey ronin!
Many thanks for the kind words! I think, you should probably study the opsi winst manual a bit more in depth. In short, you define product properties via opsi PackageBuilder, which are written into the control file. After that, you use your script to get the property values from the server and use them as desired. Have a look at GetProductProperty routine in opsi winst manual for further information.
Regarding MSO 2016: in the wiki you find a rather complex example of how to get aloong with MSO installation. Sadly, the article itself is in German, but you should be able to get some information out of the scripts you 'll find there:
wiki/doku.php?id=userspace:microsoft_office_2016
Regards,
ronin
Beitrag von ronin »
Thank you, pandel for pointing right direction.
I found newer version of office scripts:
wiki/doku.php?id=userspace:microsoft_office_365
I managed to create office2016 opsi package, made few changes in Christian Streifer's uninstall.opsiscript file.
There was problem with uninstall. I will share my modified code, when i fully test it.
Problem which I cannot solved is in property - Installationsdateien
OPSI/control
[ProductProperty]
type: unicode
multivalue: False
editable: True
description: Speicherort der Installationsdateien
values: ["c:\tmp"]
default: ["c:\tmp"]
After making .opsi package c:\tmp value looks like this (opsi config editor):
https://i.imgur.com/2tRCZ3U.png
It's missing \t, and show instead of few spaces.
When i add manually c:\tmp, everything is ok.
Do you now how to fix this ?
uncle_scrooge
Beitrag von uncle_scrooge »
values: ["c:\tmp"]
default: ["c:\tmp"]
You want to escape the backslash.
This should do the trick.
values: ["c:\\tmp"]
default: ["c:\\tmp"]
ronin
Beitrag von ronin »
Thank you, uncle_scrooge ;)
Btw. Is there new unattend.xml for Windows 10 1803 ?
