Debian 9 and repository's signature..
mirkt
Beitrag von mirkt »
Hello,
As written in „Getting started“ manual, I get GPG errors on "Debian 9":
W: GPG error: http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40/Debian_9.0 ./ Release: The following signatures were invalid: 2371C96FC045365D00729A19520B97144DC87421
W: The repository 'http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40/Debian_9.0 ./ Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Suggested method:
One can bypass this message by using the aptitude parameter --allow-unauthenticated. This parameter has to be used every time aptitude is called. For a permanent solution we recommend to disable the GPG check. This can be done by creating a file 99opsi in the directory /etc/apt/apt.conf.d/ with the following content:
APT::Get::AllowUnauthenticated "true";
does not work for me..
Adding options [allow-insecure=yes allow-downgrade-to-insecure=yes] to opsi.list:
deb [allow-insecure=yes allow-downgrade-to-insecure=yes] http://download.opensuse.org/repositori ... Debian_9.0 ./
helps..
What's is the „correct“ way to overcome this issue?
I have tried importing http://download.opensuse.org/repositori ... elease.key into gpg, then exporting to
/usr/share/keyrings/uibmz-archive-keyring.gpg
gpg --export 2371C96FC045365D00729A19520B97144DC87421 > /usr/share/keyrings/uibmz-archive-keyring.gpg
and setting:
deb [signed-by=/usr/share/keyrings/uibmz-archive-keyring.gpg] http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40/Debian_9.0 ./
in opsi.list, but then I get error:
E: The repository 'http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40/Debian_9.0 ./ Release' is not signed.
Now I have to tell APT that I trust key 2371C96FC045365D00729A19520B97144DC87421 ?
# gpg /usr/share/keyrings/uibmz-archive-keyring.gpg
pub   dsa1024 2010-07-23 [SC] [expires: 2019-04-27]
uid           home:uibmz OBS Project <home:uibmz@build.opensuse.org>
# gpg --verify Release.gpg Release
gpg: Signature made Fri 25 Aug 2017 10:14:23 AM EEST
gpg:                using DSA key 520B97144DC87421
gpg: Good signature from "home:uibmz OBS Project <home:uibmz@build.opensuse.org>" [ultimate]
Re: Debian 9 and repository's signature..
thank you for your information.
We are currently replacing the keys and resigning the packages on the opensuse repositories.
As for now we will do this first in experimental, then in testing and finally in stable.
We hope the newly generated key will help with the issue.
Cheers
we are changing the keys to fix the problems regarding the repository signature.
Read here for more information.
Kind regards
mirkt
Beitrag von mirkt »
Thank you :)
dorian.borovina
Beitrag von dorian.borovina »
Install it on Jessie 8.9, it works without any issues.
Best regards,
Dorian Borovina
dorian.borovina hat geschrieben:Install it on Jessie 8.9, it works without any issues.
Why settle on the old horse if all you need to do is to re-import the key? ;)
dorian.borovina
Hahahaha, my "old" Jessie horse is running perfectly, so there is no need for replacement, not yet. :)
Best regards,
Dorian Borovina
At home I still have a debian 4 (etch) server running, still not very old compared to ye olde vaxen ;)
SisterOfMercy hat geschrieben:At home I still have a debian 4 (etch) server running, still not very old compared to ye olde vaxen ;)
Hat's off!
What is the uptime of that machine of yours? :D
It's horribly outdated and uptime isn't great. I have power outages due to a defective earth leakage sensor. The entire fuse-block-thing has to be replaced, it's a long term project.
The uptime of my XP x64 workstation (at work) was 465 days :D
I know someone in austria who still runs his website on a quad pentium pro with windows 2000.
