today is the day you can try out the new opsi 4.0.7 bootimage
please only try this in a non productive environment.
This bootimage is experimental and not recommended to run on a productive setup
http://download.opensuse.org/repositori ... erimental/
You also need to update your localboot packages to the current testing packages. The install wont success if you are on stable localboot packages.
This bootimage also has the hd audio drivers included.
pleasy reply if your hd audio device gets recognized in lshw
cheers
mathias
HD-audio devices in show_drivers.py [solved]
Re: HD-audio devices in show_drivers.py
- SisterOfMercy
Unfortunately this didn't help... yet. There are some meaningful errors in kern.log, the sound card almost gets detected.
There is nothing being logged to dmesg, though.
Output of lshw
Output of lspci -vvt
Contents of kern.log
Around line 220 it gets interesting. The realtek on-board is indeed an ALC259, so it gets detected initially.
Output of lshw
opsi-client
description: Notebook
product: SATELLITE C660 (PSC1QE-03H00LDU)
vendor: TOSHIBA
version: PSC1QE-03H00LDU
serial: 8B064438K
width: 32 bits
capabilities: smbios-2.6 dmi-2.6 smp-1.4 smp
configuration: boot=normal chassis=notebook cpus=2 family=ABCDEFGHIJKLMNOPQRSTUVWXYZ sku=PSC1QE-03H00LDU uuid=BFF3F5B1-B820-11E0-BDC4-B870F4C9EB03
*-core
description: Motherboard
product: PWWHA
vendor: TOSHIBA
physical id: 0
version: 1.00
serial: 0123456789AB
slot: NULL
*-firmware
description: BIOS
vendor: TOSHIBA
physical id: 0
version: 1.50
date: 12/15/2011
capacity: 1984KiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification
*-cpu:0
description: CPU
product: Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 6.10.7
serial: 0002-06A7-0000-0000-0000-0000
slot: CPU 1
capacity: 3800MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx rdtscp constant_tsc arch_perfmon pebs bts xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave avx lahf_lm arat epb pln pts dtherm tpr_shadow vnmi flexpriority ept vpid xsaveopt
configuration: cores=2 enabledcores=1 id=0 threads=2
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 64KiB
capabilities: internal write-back unified
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 512KiB
capabilities: internal varies unified
*-cache:2 DISABLED
description: L3 cache
physical id: 7
slot: L3-Cache
capacity: 3MiB
capabilities: internal unified
*-logicalcpu:0
description: Logical CPU
physical id: 0.1
width: 64 bits
capabilities: logical
*-logicalcpu:1
physical id: 0.2
width: 64 bits
*-logicalcpu:2
physical id: 0.3
width: 64 bits
*-logicalcpu:3
physical id: 0.4
width: 64 bits
*-logicalcpu:4
physical id: 0.5
width: 64 bits
*-logicalcpu:5
physical id: 0.6
width: 64 bits
*-logicalcpu:6
physical id: 0.7
width: 64 bits
*-logicalcpu:7
physical id: 0.8
width: 64 bits
*-logicalcpu:8
physical id: 0.9
width: 64 bits
*-logicalcpu:9
physical id: 0.a
width: 64 bits
*-logicalcpu:10
physical id: 0.b
width: 64 bits
*-logicalcpu:11
physical id: 0.c
width: 64 bits
*-logicalcpu:12
physical id: 0.d
width: 64 bits
*-logicalcpu:13
physical id: 0.e
width: 64 bits
*-logicalcpu:14
physical id: 0.f
width: 64 bits
*-logicalcpu:15
physical id: 0.10
width: 64 bits
*-memory
description: System Memory
physical id: e
slot: System board or motherboard
*-bank:0
description: SODIMM DDR3 Synchronous 1333 MHz (0.8 ns)
product: M471B5273DH0-CH9
vendor: Samsung
physical id: 0
serial: B1453593
slot: ChannelA-DIMM0
width: 64 bits
clock: 1333MHz (0.8ns)
*-bank:1
description: DIMM [empty]
product: [Empty]
vendor: [Empty]
physical id: 1
serial: [Empty]
slot: ChannelA-DIMM1
*-bank:2
product: [Empty]
vendor: [Empty]
physical id: 2
serial: [Empty]
slot: ChannelB-DIMM0
*-bank:3
product: [Empty]
vendor: [Empty]
physical id: 3
serial: [Empty]
slot: ChannelB-DIMM1
*-cpu:1
physical id: 1
bus info: cpu@1
version: 6.10.7
capabilities: vmx ht
configuration: id=2
*-logicalcpu:0
physical id: 2.1
*-logicalcpu:1
physical id: 2.2
*-logicalcpu:2
physical id: 2.3
*-logicalcpu:3
physical id: 2.4
*-logicalcpu:4
physical id: 2.5
*-logicalcpu:5
physical id: 2.6
*-logicalcpu:6
physical id: 2.7
*-logicalcpu:7
physical id: 2.8
*-logicalcpu:8
physical id: 2.9
*-logicalcpu:9
physical id: 2.a
*-logicalcpu:10
physical id: 2.b
*-logicalcpu:11
physical id: 2.c
*-logicalcpu:12
physical id: 2.d
*-logicalcpu:13
physical id: 2.e
*-logicalcpu:14
physical id: 2.f
*-logicalcpu:15
physical id: 2.10
*-pci
description: Host bridge
product: 2nd Generation Core Processor Family DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 09
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 09
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:24 ioport:e000(size=4096) memory:f6000000-f70fffff ioport:e0000000(size=301989888)
*-display UNCLAIMED
description: VGA compatible controller
product: GT218M [GeForce 315M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
*-multimedia
description: Audio device
product: High Definition Audio Controller
physical id: 0.1
bus info: pci@0000:01:00.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:17 memory:f7080000-f7083fff
*-communication
description: Communication controller
product: 6 Series/C200 Series Chipset Family MEI Controller #1
physical id: 16
bus info: pci@0000:00:16.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: irq:25 memory:f720a000-f720a00f
*-usb:0
description: USB controller
product: 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2
physical id: 1a
bus info: pci@0000:00:1a.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=0
resources: irq:16 memory:f7208000-f72083ff
*-multimedia
product: 6 Series/C200 Series Chipset Family High Definition Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 04
width: 64 bits
clock: 33MHz
resources: irq:28 memory:f7200000-f7203fff
*-pci:1
product: 6 Series/C200 Series Chipset Family PCI Express Root Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: b4
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
resources: irq:16 ioport:d000(size=4096) ioport:f2100000(size=1048576)
*-network
description: Ethernet interface
product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 05
serial: b8:70:f4:c9:eb:03
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=10.23.24.104 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:27 ioport:d000(size=256) memory:f2104000-f2104fff memory:f2100000-f2103fff
*-pci:2
product: 6 Series/C200 Series Chipset Family PCI Express Root Port 2
physical id: 1c.1
bus info: pci@0000:00:1c.1
version: b4
width: 32 bits
clock: 33MHz
resources: irq:17 ioport:c000(size=4096) memory:f7100000-f71fffff
*-network UNCLAIMED
description: Network controller
product: RTL8188CE 802.11b/g/n WiFi Adapter
physical id: 0
bus info: pci@0000:03:00.0
version: 01
width: 64 bits
clock: 33MHz
resources: ioport:c000(size=256) memory:f7100000-f7103fff
*-usb:1
product: 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 04
width: 32 bits
clock: 33MHz
resources: irq:23 memory:f7207000-f72073ff
*-isa
description: ISA bridge
product: HM65 Express Chipset Family LPC Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver=lpc_ich latency=0
resources: irq:0
*-storage
description: SATA controller
product: 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 04
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:26 ioport:f070(size=8) ioport:f060(size=4) ioport:f050(size=8) ioport:f040(size=4) ioport:f020(size=32) memory:f7206000-f72067ff
*-serial UNCLAIMED
description: SMBus
product: 6 Series/C200 Series Chipset Family SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 04
width: 64 bits
clock: 33MHz
resources: memory:f7205000-f72050ff ioport:f000(size=32)
*-scsi:0
physical id: 2
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: KINGSTON SV300S3
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: BBF1
serial: 50026B723A047D69
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 sectorsize=512 signature=61e80618
*-volume
description: Windows NTFS volume
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
version: 3.1
serial: 489d66ae-cd24-f34e-88a2-852c70c32c4a
capacity: 55GiB
capabilities: primary bootable ntfs initialized
configuration: clustersize=4096 created=2016-05-27 23:35:48 filesystem=ntfs label=WINDOWS state=clean
*-scsi:1
physical id: 3
logical name: scsi2
*-cdrom UNCLAIMED
description: SCSI CD-ROM
product: CDDVDW TS-L633F
vendor: TSSTcorp
physical id: 0.0.0
bus info: scsi@2:0.0.0
version: TF01
capabilities: removable
*-scsi:2
physical id: 5
bus info: usb@1:1.3
logical name: scsi8
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk
description: SCSI Disk
physical id: 0.0.0
bus info: scsi@8:0.0.0
logical name: /dev/sdb
configuration: sectorsize=512
*-scsi:3
physical id: 6
bus info: usb@2:1.2
logical name: scsi9
*-disk
physical id: 0.0.0
bus info: scsi@9:0.0.0
logical name: /dev/sdc
configuration: sectorsize=512 signature=103e3de3
*-volume
description: Windows FAT volume
vendor: MSDOS5.0
physical id: 1
bus info: scsi@9:0.0.0,1
logical name: /dev/sdc1
logical name: /mnt
version: FAT32
serial: f4cc-cbfc
capacity: 7399MiB
capabilities: primary fat initialized
configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro state=mounted
*-battery:0
description: Nickel Cadmium Battery
product: BATT 1
vendor: Battery Manufacturer
physical id: 1
version: 01/01/2007
serial: Serial Number
slot: Location of the battery
capacity: 232mWh
configuration: voltage=5.0V
*-battery:1
product: Battery Name
physical id: 2
version: 01/01/2007
*-power UNCLAIMED
description: To Be Filled By O.E.M.
product: To Be Filled By O.E.M.
vendor: To Be Filled By O.E.M.
physical id: 3
version: To Be Filled By O.E.M.
serial: To Be Filled By O.E.M.
capacity: 32768mWh
*-network:0 DISABLED
physical id: 4
logical name: dummy0
serial: 5e:a0:01:e6:21:d1
capabilities: ethernet physical
configuration: broadcast=yes driver=dummy driverversion=1.0
*-network:1 DISABLED
physical id: 5
logical name: bond0
serial: da:a3:ff:14:c8:dd
configuration: autonegotiation=off broadcast=yes driver=bonding driverversion=3.7.1 firmware=2 link=no master=yes multicast=yes
-[0000:00]-+-00.0 Intel Corporation 2nd Generation Core Processor Family DRAM Controller
+-01.0-[01]--+-00.0 NVIDIA Corporation GT218M [GeForce 315M]
| \-00.1 NVIDIA Corporation High Definition Audio Controller
+-16.0 Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1
+-1a.0 Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2
+-1b.0 Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller
+-1c.0-[02]----00.0 Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
+-1c.1-[03]----00.0 Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter
+-1d.0 Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1
+-1f.0 Intel Corporation HM65 Express Chipset Family LPC Controller
+-1f.2 Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller
\-1f.3 Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller
Jun 10 13:07:13 opsi-client kernel: ata1.00: 117231408 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Jun 10 13:07:13 opsi-client kernel: ata1.00: configured for UDMA/133
Jun 10 13:07:13 opsi-client kernel: scsi 0:0:0:0: Direct-Access ATA KINGSTON SV300S3 BBF1 PQ: 0 ANSI: 5
Jun 10 13:07:13 opsi-client kernel: sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.9 GiB)
Jun 10 13:07:13 opsi-client kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 10 13:07:13 opsi-client kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 10 13:07:13 opsi-client kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Jun 10 13:07:13 opsi-client kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 10 13:07:13 opsi-client kernel: sda: sda1
Jun 10 13:07:13 opsi-client kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jun 10 13:07:13 opsi-client kernel: ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jun 10 13:07:13 opsi-client kernel: ata3.00: ATAPI: TSSTcorp CDDVDW TS-L633F, TF01, max UDMA/100
Jun 10 13:07:13 opsi-client kernel: ata3.00: configured for UDMA/100
Jun 10 13:07:13 opsi-client kernel: scsi 2:0:0:0: CD-ROM TSSTcorp CDDVDW TS-L633F TF01 PQ: 0 ANSI: 5
Jun 10 13:07:13 opsi-client kernel: scsi 2:0:0:0: Attached scsi generic sg1 type 5
Jun 10 13:07:13 opsi-client kernel: scsi host7: pata_legacy
Jun 10 13:07:13 opsi-client kernel: ata8: PATA max PIO4 cmd 0x170 ctl 0x376 irq 15
Jun 10 13:07:13 opsi-client kernel: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Jun 10 13:07:13 opsi-client kernel: eql: Equalizer2002: Simon Janes (simon@ncm.com) and David S. Miller (davem@redhat.com)
Jun 10 13:07:13 opsi-client kernel: libphy: Fixed MDIO Bus: probed
Jun 10 13:07:13 opsi-client kernel: tun: Universal TUN/TAP device driver, 1.6
Jun 10 13:07:13 opsi-client kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Jun 10 13:07:13 opsi-client kernel: arcnet: arcnet loaded
Jun 10 13:07:13 opsi-client kernel: arcnet:rfc1201: RFC1201 "standard" (`a') encapsulation support loaded
Jun 10 13:07:13 opsi-client kernel: arcnet:rfc1051: RFC1051 "simple standard" (`s') encapsulation support loaded
Jun 10 13:07:13 opsi-client kernel: arcnet:arc_rawmode: raw mode (`r') encapsulation support loaded
Jun 10 13:07:13 opsi-client kernel: arcnet:capmode: cap mode (`c') encapsulation support loaded
Jun 10 13:07:13 opsi-client kernel: arcnet:com90xx: COM90xx chipset support
Jun 10 13:07:13 opsi-client kernel: S3: No ARCnet cards found.
Jun 10 13:07:13 opsi-client kernel: arcnet:com90io: COM90xx IO-mapped mode support (by David Woodhouse et el.)
Jun 10 13:07:13 opsi-client kernel: arcnet:com90io: E-mail me if you actually test this driver, please!
Jun 10 13:07:13 opsi-client kernel: (unnamed net_device) (uninitialized): No autoprobe for IO mapped cards; you must specify the base address!
Jun 10 13:07:13 opsi-client kernel: arcnet:arc_rimi: RIM I (entirely mem-mapped) support
Jun 10 13:07:13 opsi-client kernel: arcnet:arc_rimi: E-mail me if you actually test the RIM I driver, please!
Jun 10 13:07:13 opsi-client kernel: arcnet:arc_rimi: Given: node 00h, shmem 0h, irq 0
Jun 10 13:07:13 opsi-client kernel: arcnet:arc_rimi: No autoprobe for RIM I; you must specify the shmem and irq!
Jun 10 13:07:13 opsi-client kernel: pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de
Jun 10 13:07:13 opsi-client kernel: Atheros(R) L2 Ethernet Driver - version 2.2.3
Jun 10 13:07:13 opsi-client kernel: Copyright (c) 2007 Atheros Corporation.
Jun 10 13:07:13 opsi-client kernel: cnic: QLogic cnicDriver v2.5.22 (July 20, 2015)
Jun 10 13:07:13 opsi-client kernel: bnx2x: QLogic 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.712.30-0 (2014/02/10)
Jun 10 13:07:13 opsi-client kernel: bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
Jun 10 13:07:13 opsi-client kernel: enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
Jun 10 13:07:13 opsi-client kernel: dmfe: Davicom DM9xxx net driver, version 1.36.4 (2002-01-17)
Jun 10 13:07:13 opsi-client kernel: v1.01-e (2.4 port) Sep-11-2006 Donald Becker <becker@scyld.com>
Jun 10 13:07:13 opsi-client kernel: http://www.scyld.com/network/drivers.html
Jun 10 13:07:13 opsi-client kernel: uli526x: ULi M5261/M5263 net driver, version 0.9.3 (2005-7-29)
Jun 10 13:07:13 opsi-client kernel: vxge: Copyright(c) 2002-2010 Exar Corp.
Jun 10 13:07:13 opsi-client kernel: vxge: Driver version: 2.5.3.22640-k
Jun 10 13:07:13 opsi-client kernel: e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
Jun 10 13:07:13 opsi-client kernel: e100: Copyright(c) 1999-2006 Intel Corporation
Jun 10 13:07:13 opsi-client kernel: e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
Jun 10 13:07:13 opsi-client kernel: e1000: Copyright (c) 1999-2006 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jun 10 13:07:13 opsi-client kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
Jun 10 13:07:13 opsi-client kernel: igb: Copyright (c) 2007-2014 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.0.2-k
Jun 10 13:07:13 opsi-client kernel: igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.2.1-k
Jun 10 13:07:13 opsi-client kernel: ixgbe: Copyright (c) 1999-2015 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: ixgbevf: Intel(R) 10 Gigabit PCI Express Virtual Function Network Driver - version 2.12.1-k
Jun 10 13:07:13 opsi-client kernel: ixgbevf: Copyright (c) 2009 - 2012 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.3.46-k
Jun 10 13:07:13 opsi-client kernel: i40e: Copyright (c) 2013 - 2014 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: ixgb: Intel(R) PRO/10GbE Network Driver - version 1.0.135-k2-NAPI
Jun 10 13:07:13 opsi-client kernel: ixgb: Copyright (c) 1999-2008 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: i40evf: Intel(R) XL710/X710 Virtual Function Network Driver - version 1.3.33
Jun 10 13:07:13 opsi-client kernel: Copyright (c) 2013 - 2015 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: Intel(R) Ethernet Switch Host Interface Driver - version 0.15.2-k
Jun 10 13:07:13 opsi-client kernel: Copyright (c) 2013 Intel Corporation.
Jun 10 13:07:13 opsi-client kernel: jme: JMicron JMC2XX ethernet driver version 1.0.8
Jun 10 13:07:13 opsi-client kernel: sky2: driver version 1.30
Jun 10 13:07:13 opsi-client kernel: myri10ge: Version 1.5.3-1.534
Jun 10 13:07:13 opsi-client kernel: ns83820.c: National Semiconductor DP83820 10/100/1000 driver.
Jun 10 13:07:13 opsi-client kernel: QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.3.63
Jun 10 13:07:13 opsi-client kernel: QLogic/NetXen Network Driver v4.0.82
Jun 10 13:07:13 opsi-client kernel: r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
Jun 10 13:07:13 opsi-client kernel: r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
Jun 10 13:07:13 opsi-client kernel: r8169 0000:02:00.0 eth0: RTL8105e at 0xf8026000, b8:70:f4:c9:eb:03, XID 00a00000 IRQ 27
Jun 10 13:07:13 opsi-client kernel: Solarflare NET driver v4.0
Jun 10 13:07:13 opsi-client kernel: tehuti: Tehuti Networks(R) Network Driver, 7.29.3
Jun 10 13:07:13 opsi-client kernel: tehuti: Options: hw_csum
Jun 10 13:07:13 opsi-client kernel: tlan: ThunderLAN driver v1.17
Jun 10 13:07:13 opsi-client kernel: tlan: 0 devices installed, PCI: 0 EISA: 0
Jun 10 13:07:13 opsi-client kernel: VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k-NAPI
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver catc
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver kaweth
Jun 10 13:07:13 opsi-client kernel: pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver pegasus
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver rtl8150
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver r8152
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver asix
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ax88179_178a
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver cdc_ether
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver cdc_eem
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver dm9601
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver sr9700
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver CoreChips
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver smsc75xx
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver smsc95xx
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver gl620a
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver net1080
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver plusb
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver rndis_host
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver cdc_subset
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver zaurus
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver MOSCHIP usb-ethernet driver
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver int51x1
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver kalmia
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver sierra_net
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver cx82310_eth
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver cdc_ncm
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver huawei_cdc_ncm
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver lg-vl600
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver qmi_wwan
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver cdc_mbim
Jun 10 13:07:13 opsi-client kernel: hv_vmbus: registering driver hv_netvsc
Jun 10 13:07:13 opsi-client kernel: Fusion MPT base driver 3.04.20
Jun 10 13:07:13 opsi-client kernel: Copyright (c) 1999-2008 LSI Corporation
Jun 10 13:07:13 opsi-client kernel: Fusion MPT SPI Host driver 3.04.20
Jun 10 13:07:13 opsi-client kernel: Fusion MPT SAS Host driver 3.04.20
Jun 10 13:07:13 opsi-client kernel: Fusion MPT misc device (ioctl) driver 3.04.20
Jun 10 13:07:13 opsi-client kernel: mptctl: Registered with Fusion MPT base driver
Jun 10 13:07:13 opsi-client kernel: mptctl: /dev/mptctl @ (major,minor=10,220)
Jun 10 13:07:13 opsi-client kernel: aoe: AoE v85 initialised.
Jun 10 13:07:13 opsi-client kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun 10 13:07:13 opsi-client kernel: ehci-pci: EHCI PCI platform driver
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1a.0: debug port 2
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7208000
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
Jun 10 13:07:13 opsi-client kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun 10 13:07:13 opsi-client kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 10 13:07:13 opsi-client kernel: usb usb1: Product: EHCI Host Controller
Jun 10 13:07:13 opsi-client kernel: usb usb1: Manufacturer: Linux 4.4.11 ehci_hcd
Jun 10 13:07:13 opsi-client kernel: usb usb1: SerialNumber: 0000:00:1a.0
Jun 10 13:07:13 opsi-client kernel: hub 1-0:1.0: USB hub found
Jun 10 13:07:13 opsi-client kernel: hub 1-0:1.0: 2 ports detected
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1d.0: debug port 2
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7207000
Jun 10 13:07:13 opsi-client kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Jun 10 13:07:13 opsi-client kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Jun 10 13:07:13 opsi-client kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 10 13:07:13 opsi-client kernel: usb usb2: Product: EHCI Host Controller
Jun 10 13:07:13 opsi-client kernel: usb usb2: Manufacturer: Linux 4.4.11 ehci_hcd
Jun 10 13:07:13 opsi-client kernel: usb usb2: SerialNumber: 0000:00:1d.0
Jun 10 13:07:13 opsi-client kernel: hub 2-0:1.0: USB hub found
Jun 10 13:07:13 opsi-client kernel: hub 2-0:1.0: 2 ports detected
Jun 10 13:07:13 opsi-client kernel: ehci-platform: EHCI generic platform driver
Jun 10 13:07:13 opsi-client kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jun 10 13:07:13 opsi-client kernel: ohci-pci: OHCI PCI platform driver
Jun 10 13:07:13 opsi-client kernel: ohci-platform: OHCI generic platform driver
Jun 10 13:07:13 opsi-client kernel: uhci_hcd: USB Universal Host Controller Interface driver
Jun 10 13:07:13 opsi-client kernel: fotg210_hcd: FOTG210 Host Controller (EHCI) Driver
Jun 10 13:07:13 opsi-client kernel: Warning! fotg210_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver cdc_acm
Jun 10 13:07:13 opsi-client kernel: cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver cdc_wdm
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver uas
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver usb-storage
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-alauda
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-datafab
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-freecom
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-isd200
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-jumpshot
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-onetouch
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-sddr09
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-sddr55
Jun 10 13:07:13 opsi-client kernel: usbcore: registered new interface driver ums-usbat
Jun 10 13:07:13 opsi-client kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Jun 10 13:07:13 opsi-client kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Jun 10 13:07:13 opsi-client kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Jun 10 13:07:13 opsi-client kernel: hv_vmbus: registering driver hyperv_keyboard
Jun 10 13:07:13 opsi-client kernel: mousedev: PS/2 mouse device common for all mice
Jun 10 13:07:13 opsi-client kernel: Driver for 1-wire Dallas network protocol.
Jun 10 13:07:13 opsi-client kernel: md: linear personality registered for level -1
Jun 10 13:07:13 opsi-client kernel: md: raid0 personality registered for level 0
Jun 10 13:07:13 opsi-client kernel: md: raid1 personality registered for level 1
Jun 10 13:07:13 opsi-client kernel: md: raid10 personality registered for level 10
Jun 10 13:07:13 opsi-client kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
Jun 10 13:07:13 opsi-client kernel: md: raid6 personality registered for level 6
Jun 10 13:07:13 opsi-client kernel: md: raid5 personality registered for level 5
Jun 10 13:07:13 opsi-client kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
Jun 10 13:07:13 opsi-client kernel: md: raid4 personality registered for level 4
Jun 10 13:07:13 opsi-client kernel: md: multipath personality registered for level -4
Jun 10 13:07:13 opsi-client kernel: md: faulty personality registered for level -5
Jun 10 13:07:13 opsi-client kernel: device-mapper: uevent: version 1.0.3
Jun 10 13:07:13 opsi-client kernel: device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
Jun 10 13:07:13 opsi-client kernel: device-mapper: multipath: version 1.10.0 loaded
Jun 10 13:07:13 opsi-client kernel: usb 2-1: new high-speed USB device number 2 using ehci-pci
Jun 10 13:07:13 opsi-client kernel: device-mapper: multipath round-robin: version 1.0.0 loaded
Jun 10 13:07:13 opsi-client kernel: device-mapper: multipath queue-length: version 0.1.0 loaded
Jun 10 13:07:13 opsi-client kernel: device-mapper: multipath service-time: version 0.2.0 loaded
Jun 10 13:07:13 opsi-client kernel: device-mapper: dm-log-userspace: version 1.3.0 loaded
Jun 10 13:07:13 opsi-client kernel: device-mapper: raid: Loading target version 1.7.0
Jun 10 13:07:13 opsi-client kernel: device-mapper: cache cleaner: version 1.0.0 loaded
Jun 10 13:07:13 opsi-client kernel: hv_vmbus: registering driver hid_hyperv
Jun 10 13:07:13 opsi-client kernel: dell_wmi: No known WMI GUID found
Jun 10 13:07:13 opsi-client kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=0024
Jun 10 13:07:13 opsi-client kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 10 13:07:13 opsi-client kernel: hub 1-1:1.0: USB hub found
Jun 10 13:07:13 opsi-client kernel: hub 1-1:1.0: 6 ports detected
Jun 10 13:07:13 opsi-client kernel: dell_wmi_aio: No known WMI GUID found
Jun 10 13:07:13 opsi-client kernel: hv_utils: Registering HyperV Utility Driver
Jun 10 13:07:13 opsi-client kernel: hv_vmbus: registering driver hv_util
Jun 10 13:07:13 opsi-client kernel: hv_vmbus: registering driver hv_balloon
Jun 10 13:07:13 opsi-client kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Jun 10 13:07:13 opsi-client kernel: NET: Registered protocol family 10
Jun 10 13:07:13 opsi-client kernel: sit: IPv6 over IPv4 tunneling driver
Jun 10 13:07:13 opsi-client kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=0024
Jun 10 13:07:13 opsi-client kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 10 13:07:13 opsi-client kernel: hub 2-1:1.0: USB hub found
Jun 10 13:07:13 opsi-client kernel: hub 2-1:1.0: 6 ports detected
Jun 10 13:07:13 opsi-client kernel: NET: Registered protocol family 15
Jun 10 13:07:13 opsi-client kernel: NET: Registered protocol family 33
Jun 10 13:07:13 opsi-client kernel: Key type rxrpc registered
Jun 10 13:07:13 opsi-client kernel: Key type rxrpc_s registered
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC259: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
Jun 10 13:07:13 opsi-client kernel: RxRPC: Registered security type 2 'rxkad'
Jun 10 13:07:13 opsi-client kernel: 9pnet: Installing 9P2000 support
Jun 10 13:07:13 opsi-client kernel: Key type dns_resolver registered
Jun 10 13:07:13 opsi-client kernel: Key type ceph registered
Jun 10 13:07:13 opsi-client kernel: libceph: loaded (mon/osd proto 15/24)
Jun 10 13:07:13 opsi-client kernel: microcode: CPU0 sig=0x206a7, pf=0x10, revision=0x23
Jun 10 13:07:13 opsi-client kernel: microcode: CPU1 sig=0x206a7, pf=0x10, revision=0x23
Jun 10 13:07:13 opsi-client kernel: microcode: CPU2 sig=0x206a7, pf=0x10, revision=0x23
Jun 10 13:07:13 opsi-client kernel: microcode: CPU3 sig=0x206a7, pf=0x10, revision=0x23
Jun 10 13:07:13 opsi-client kernel: microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
Jun 10 13:07:13 opsi-client kernel: Using IPI No-Shortcut mode
Jun 10 13:07:13 opsi-client kernel: Btrfs loaded, debug=on
Jun 10 13:07:13 opsi-client kernel: Key type encrypted registered
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_realtek hdaudioC0D0: inputs:
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
Jun 10 13:07:13 opsi-client kernel: usb 1-1.3: new high-speed USB device number 3 using ehci-pci
Jun 10 13:07:13 opsi-client kernel: console [netcon0] enabled
Jun 10 13:07:13 opsi-client kernel: netconsole: network logging started
Jun 10 13:07:13 opsi-client kernel: ALSA device list:
Jun 10 13:07:13 opsi-client kernel: No soundcards found.
Jun 10 13:07:13 opsi-client kernel: Freeing unused kernel memory: 612K (c20ae000 - c2147000)
Jun 10 13:07:13 opsi-client kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input3
Jun 10 13:07:13 opsi-client kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
Jun 10 13:07:13 opsi-client kernel: random: systemd-udevd urandom read with 25 bits of entropy available
Jun 10 13:07:13 opsi-client kernel: Warning: Processor Platform Limit event detected, but not handled.
Jun 10 13:07:13 opsi-client kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input5
Jun 10 13:07:13 opsi-client kernel: ACPI: Lid Switch [LID0]
Jun 10 13:07:13 opsi-client kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input6
Jun 10 13:07:13 opsi-client kernel: ACPI: Power Button [PWRB]
Jun 10 13:07:13 opsi-client kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
Jun 10 13:07:13 opsi-client kernel: ACPI: Power Button [PWRF]
Jun 10 13:07:13 opsi-client kernel: ACPI: AC Adapter [ACAD] (on-line)
Jun 10 13:07:13 opsi-client kernel: Consider compiling CPUfreq support into your kernel.
Jun 10 13:07:13 opsi-client kernel: r8169 0000:02:00.0 enp2s0: renamed from eth0
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPRF) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\_SB_.LDIO) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPRF) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\_SB_.LDIO) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPRF) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\_SB_.LDIO) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
Jun 10 13:07:13 opsi-client kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Jun 10 13:07:13 opsi-client kernel: usb 1-1.3: New USB device found, idVendor=0bda, idProduct=0138
Jun 10 13:07:13 opsi-client kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 10 13:07:13 opsi-client kernel: usb 1-1.3: Product: USB2.0-CRW
Jun 10 13:07:13 opsi-client kernel: usb 1-1.3: Manufacturer: Generic
Jun 10 13:07:13 opsi-client kernel: usb 1-1.3: SerialNumber: 20090516388200000
Jun 10 13:07:13 opsi-client kernel: usb-storage 1-1.3:1.0: USB Mass Storage device detected
Jun 10 13:07:13 opsi-client kernel: scsi host8: usb-storage 1-1.3:1.0
Jun 10 13:07:13 opsi-client kernel: [Firmware Bug]: battery: (dis)charge rate invalid.
Jun 10 13:07:13 opsi-client kernel: ACPI: Battery Slot [BAT1] (battery present)
Jun 10 13:07:13 opsi-client kernel: usb 1-1.4: new high-speed USB device number 4 using ehci-pci
Jun 10 13:07:13 opsi-client kernel: usb 1-1.4: New USB device found, idVendor=04f2, idProduct=b1d6
Jun 10 13:07:13 opsi-client kernel: usb 1-1.4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Jun 10 13:07:13 opsi-client kernel: usb 1-1.4: Product: CNF9055
Jun 10 13:07:13 opsi-client kernel: usb 1-1.4: Manufacturer: Sonix Technology Co., Ltd.
Jun 10 13:07:13 opsi-client kernel: psmouse serio1: synaptics: queried max coordinates: x [..5692], y [..4680]
Jun 10 13:07:13 opsi-client kernel: scsi 8:0:0:0: Direct-Access Generic- Multi-Card 1.00 PQ: 0 ANSI: 0 CCS
Jun 10 13:07:13 opsi-client kernel: sd 8:0:0:0: Attached scsi generic sg2 type 0
Jun 10 13:07:13 opsi-client kernel: sd 8:0:0:0: [sdb] Attached SCSI removable disk
Jun 10 13:07:13 opsi-client kernel: snd_hda_intel 0000:01:00.1: Too many HDMI devices
Jun 10 13:07:13 opsi-client kernel: snd_hda_intel 0000:01:00.1: Consider building the kernel with CONFIG_SND_DYNAMIC_MINORS=y
Jun 10 13:07:13 opsi-client kernel: psmouse serio1: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04733/0xa40000/0xa0000/0x0, board id: 0, fw id: 582762
Jun 10 13:07:13 opsi-client kernel: snd_hda_intel 0000:01:00.1: control 3:0:0:ELD:0 is already present
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_hdmi: probe of hdaudioC1D3 failed with error -16
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_generic hdaudioC1D3: autoconfig for Generic: line_outs=0 (0x0/0x0/0x0/0x0/0x0) type:line
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_generic hdaudioC1D3: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_generic hdaudioC1D3: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_generic hdaudioC1D3: mono: mono_out=0x0
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_generic hdaudioC1D3: dig-out=0x5/0x0
Jun 10 13:07:13 opsi-client kernel: snd_hda_codec_generic hdaudioC1D3: inputs:
Jun 10 13:07:13 opsi-client kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
Jun 10 13:07:13 opsi-client kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
Jun 10 13:07:13 opsi-client kernel: input: HDA NVidia HDMI/DP as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
Jun 10 13:07:13 opsi-client kernel: input: HDA NVidia HDMI as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
Jun 10 13:07:13 opsi-client kernel: ------------[ cut here ]------------
Jun 10 13:07:13 opsi-client kernel: WARNING: CPU: 3 PID: 22 at fs/proc/generic.c:345 proc_register+0xa7/0xc6()
Jun 10 13:07:13 opsi-client kernel: proc_dir_entry 'card1/eld#3.0' already registered
Jun 10 13:07:13 opsi-client kernel: Modules linked in: tpm_tis serio_raw lpc_ich mfd_core battery ac button processor
Jun 10 13:07:13 opsi-client kernel: CPU: 3 PID: 22 Comm: kworker/3:0 Not tainted 4.4.11 #1
Jun 10 13:07:13 opsi-client kernel: Hardware name: TOSHIBA SATELLITE C660/PWWHA, BIOS 1.50 12/15/2011
Jun 10 13:07:13 opsi-client kernel: Workqueue: events azx_probe_work
Jun 10 13:07:13 opsi-client kernel: c1fea374 c132ad32 c1e3d108 00000009 c103884b c113429c f73f3e40 f73f3cec
Jun 10 13:07:13 opsi-client kernel: f70be815 f73f3e95 c1038884 00000009 efd33e48 c1e3d108 efd33e60 c113429c
Jun 10 13:07:13 opsi-client kernel: c1e3d0a0 00000159 c1e3d108 f70be815 f73f3e95 f70be7e8 f73f3e40 c1bf7860
Jun 10 13:07:13 opsi-client kernel: Call Trace:
Jun 10 13:07:13 opsi-client kernel: [<c132ad32>] ? dump_stack+0x44/0x57
Jun 10 13:07:13 opsi-client kernel: [<c103884b>] ? warn_slowpath_common+0x82/0x95
Jun 10 13:07:13 opsi-client kernel: [<c113429c>] ? proc_register+0xa7/0xc6
Jun 10 13:07:13 opsi-client kernel: [<c1038884>] ? warn_slowpath_fmt+0x26/0x2a
Jun 10 13:07:13 opsi-client kernel: [<c1134429>] ? proc_create_data+0x7b/0x8e
Jun 10 13:07:13 opsi-client kernel: [<c19b8f69>] ? snd_info_register+0x78/0xaa
Jun 10 13:07:13 opsi-client kernel: [<c19b8fb5>] ? snd_info_register_recursive+0x1a/0x45
Jun 10 13:07:13 opsi-client kernel: [<c19b8fc4>] ? snd_info_register_recursive+0x29/0x45
Jun 10 13:07:13 opsi-client kernel: [<c19b95ca>] ? snd_info_card_register+0x19/0x71
Jun 10 13:07:13 opsi-client kernel: [<c19b6914>] ? snd_card_register+0x122/0x13c
Jun 10 13:07:13 opsi-client kernel: [<c19c5daa>] ? snd_hda_codec_configure+0xe0/0x110
Jun 10 13:07:13 opsi-client kernel: [<c19e4c9b>] ? azx_probe_work+0x4e6/0x593
Jun 10 13:07:13 opsi-client kernel: [<c1047553>] ? process_one_work+0x182/0x30e
Jun 10 13:07:13 opsi-client kernel: [<c1047f37>] ? worker_thread+0x21b/0x2e6
Jun 10 13:07:13 opsi-client kernel: [<c1047d1c>] ? rescuer_thread+0x233/0x233
Jun 10 13:07:13 opsi-client kernel: [<c104b0ba>] ? kthread+0xa1/0xa6
Jun 10 13:07:13 opsi-client kernel: [<c1adaa29>] ? ret_from_kernel_thread+0x21/0x38
Jun 10 13:07:13 opsi-client kernel: [<c104b019>] ? kthread_worker_fn+0xf7/0xf7
Jun 10 13:07:13 opsi-client kernel: ---[ end trace 1c026904d0a3bfda ]---
Jun 10 13:07:13 opsi-client kernel: input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input2
Jun 10 13:07:43 opsi-client kernel: r8169 0000:02:00.0: Direct firmware load for rtl_nic/rtl8105e-1.fw failed with error -2
Jun 10 13:07:43 opsi-client kernel: r8169 0000:02:00.0 enp2s0: unable to load firmware patch rtl_nic/rtl8105e-1.fw (-2)
Jun 10 13:07:43 opsi-client kernel: r8169 0000:02:00.0 enp2s0: link down
Jun 10 13:07:43 opsi-client kernel: IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
Jun 10 13:07:43 opsi-client kernel: NET: Registered protocol family 17
Jun 10 13:07:45 opsi-client kernel: r8169 0000:02:00.0 enp2s0: link up
Jun 10 13:07:45 opsi-client kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
Jun 10 13:07:49 opsi-client kernel: random: nonblocking pool is initialized
Jun 10 13:33:09 opsi-client kernel: usb 2-1.2: new high-speed USB device number 3 using ehci-pci
Jun 10 13:33:09 opsi-client kernel: usb 2-1.2: New USB device found, idVendor=0930, idProduct=6544
Jun 10 13:33:09 opsi-client kernel: usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 10 13:33:09 opsi-client kernel: usb 2-1.2: Product: TransMemory
Jun 10 13:33:09 opsi-client kernel: usb 2-1.2: Manufacturer: TOSHIBA
Jun 10 13:33:09 opsi-client kernel: usb 2-1.2: SerialNumber: C72DA10297E1CEA1F86031C1
Jun 10 13:33:09 opsi-client kernel: usb-storage 2-1.2:1.0: USB Mass Storage device detected
Jun 10 13:33:09 opsi-client kernel: scsi host9: usb-storage 2-1.2:1.0
Jun 10 13:33:10 opsi-client kernel: scsi 9:0:0:0: Direct-Access TOSHIBA TransMemory 1.00 PQ: 0 ANSI: 4
Jun 10 13:33:10 opsi-client kernel: sd 9:0:0:0: Attached scsi generic sg3 type 0
Jun 10 13:33:10 opsi-client kernel: sd 9:0:0:0: [sdc] 15155200 512-byte logical blocks: (7.76 GB/7.23 GiB)
Jun 10 13:33:10 opsi-client kernel: sd 9:0:0:0: [sdc] Write Protect is off
Jun 10 13:33:10 opsi-client kernel: sd 9:0:0:0: [sdc] Mode Sense: 45 00 00 00
Jun 10 13:33:10 opsi-client kernel: sd 9:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Jun 10 13:33:10 opsi-client kernel: sdc: sdc1
Jun 10 13:33:10 opsi-client kernel: sd 9:0:0:0: [sdc] Attached SCSI removable disk
Well I just integrated some intel HD audio drivers.
I will try tweaking it a bit when I do some kernel stuff the next time.
Until then you can experiment with the experimental bootimage and report back
PS: i strongly dislike Realtek hardware. The drivers are a pain in the a*s
- SisterOfMercy
Everybody does! It's just a bit hard to find a motherboard without a realtek audio chip. Most motherboards without any audio don't have DVI (etc) connections for processor graphics. And a normal 5V PCI slot for a sound card is often not available.m.radtke hat geschrieben:PS: i strongly dislike Realtek hardware. The drivers are a pain in the a*s
The cmedia cards which have a dogber1 driver available are great, when using an external DAC. The original drivers are really, really shite.
- SisterOfMercy
Fixed in 4.0.7!
Re: HD-audio devices in show_drivers.py [solved]
thanks for your feedback
Cheers
Cheers
