Bei dem Versuch den Adobe Reader 10.0.1 zu deinstallieren scheint das Auslesen der Registry nicht ganz hinzuhauen (nach meiner derzeitigen Auffassungsgabe).
; This sourcecode is owned by uib gmbh
; credits: http://www.opsi.org/credits/
DefVar $MsiId$
Message "Deinstalliere Adobe Reader 10 ..."
; Acrobat Reader 10.0 - DEU
Set $MsiId$ = '{AC76BA86-7AD7-1033-7B44-AA0000000001}'
if not (GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\" + $MsiId$ + "] DisplayName") = "")
comment "MSI id " + $MsiId$ + " found in registry, starting msiexec to uninstall"
Winbatch_uninstall_msi
sub_check_exitcode
[Winbatch_uninstall_msi]
msiexec /x $MsiId$ /qb! REBOOT=ReallySuppress "$LogDir$\$ProductId$.delete-adobereader-x-log.txt"
[Sub_check_exitcode]
; http://msdn.microsoft.com/en-us/library/aa372835(VS.85).aspx
if ($ExitCode$ = "0")
else
if ($ExitCode$ = "1605")
comment "ERROR_UNKNOWN_PRODUCT 1605 This action is only valid for products that are currently installed."
else
if ($ExitCode$ = "1641")
comment "ERROR_SUCCESS_REBOOT_INITIATED 1641 The installer has initiated a restart. This message is indicative of a success."
else
if ($ExitCode$ = "3010")
comment "ERROR_SUCCESS_REBOOT_REQUIRED 3010 A restart is required to complete the install. This message is indicative of a success."
else
isFatalError
Was der Testlauf mit winst32.exe ergibt ist Folgendes:
if (GetRegistryStringValue("[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AC76BA86-7AD7-1033-7B44-AA0000000001}]"+"DisplayName") = "Adobe Reader X")
comment "Adobe Reader X" found in registry, starting msiexec to uninstall"
sub_check_exitcode
msiexec /x {AC76BA86-7AD7-1033-7B44-AA0000000001} /qb! REBOOT=ReallySuppress "$LogDir$\$ProductId$.delete-adobereader-x-log.txt"
else
else
else
else
isFatalError
DefVar $MsiId$
sub_check_exitcode
else
comment "MSI id " + $MsiId$ + " not found in registry.
