Updates for opsi 4.2 in testing and stable
Verfasst: 14 Apr 2023, 12:54
Dear opsi users,
with this release we have published new packages for opsi 4.2 in testing and stable.
In the opsi-Configed 4.2.21.1 (testing & stable) released as a hotfix, a number of problems have been fixed.
Updated packages in opsi 4.2 testing:
Localboot packages Windows:
* opsi-configed (4.2.21.1-1)
* opsi-client-agent (4.2.0.53-1)
* opsi-script (4.12.9.0-3)
Localboot packages Linux:
Localboot packages macOS:
Updated packages in opsi 4.2 stable:
Server packages:
* opsiconfd (4.2.0.306-1)
* opsi-utils (4.2.0.201-1)
With kind regards
Server packages:
With kind regards
Changelogs:
opsi-configed (4.2.21.1) EXPERIMENTAL; urgency=medium
* Fix client selection dialog for non MySQL
-- Jan Schneider <j.schneider@uib.de> Wed, 14. Apr 2023 08:00:00 +0200
opsi-configed (4.2.21.0) EXPERIMENTAL; urgency=medium
* Improve messagebus connection handling, auto reconnect
* Improve 2FA handling, add password dialog
* Do not process expired messagebus messages
* Fix SLF4J warnings
* Fix UpdateCommand casting error
* Correct order of action requests in combobox
* Fix boolean table cell renderer (WAN column in client table)
* Do not show essential / devel log messages in GUI
-- Jan Schneider <j.schneider@uib.de> Wed, 12. Apr 2023 17:00:00 +0200
opsi-client-agent (4.2.0.53-1) stable; urgency=low
* Update opsiclientd to 4.2.0.143
-- Jan Schneider <j.schneider@uib.de> Fri, 14 Apr 2023 11:30:00 +0100
opsi-client-agent (4.2.0.52-1) stable; urgency=low
* Update opsiclientd to 4.2.0.142 (improvement in product caching)
* Update opsi-script to 4.12.9.0 (compatibility with opsi 4.3)
* Some improvements in installation procedure rebustness
-- Nils Doerrer <n.doerrer@uib.de> Wed, 12 Apr 2023 13:30:00 +0100
opsi-client-agent (4.2.0.51-1) stable; urgency=low
* Update opsiclientd to 4.2.0.141
-- Jan Schneider <j.schneider@uib.de> Thu, 02 Apr 2023 10:00:00 +0100
opsi-script (4.12.9.0) urgency=medium
Fixes:
remove possible memory leaks
remove TQProgressBar to fix memory leaks
fix in handling profiles, avoid empty string in the profilelist [W]
Changes:
replace deprecated API methods, adaptations for opsi 4.3
-- j.werner <j.werner@uib.de> 11 April 2023
opsiconfd (4.2.0.306-1) stable; urgency=medium
* Improvement: New configed links
-- uib GmbH <info@uib.de> Sat, 11 Mar 2023 09:35:54 +0100
opsi-utils (4.2.0.201-1) stable; urgency=medium
* Improvement: updated opsi-cli to 4.2.0.6
-- uib GmbH <info@uib.de> Tue, 04 Apr 2023 16:00:03 +0200
opsi-utils (4.2.0.200-1) stable; urgency=medium
* No public changes
-- uib GmbH <info@uib.de> Fri, 31 Mar 2023 09:31:46 +0200
opsi-utils (4.2.0.199-1) stable; urgency=medium
* Improvement: change opsi-sever.repo autoUpdate/install to false
-- uib GmbH <info@uib.de> Tue, 28 Mar 2023 15:46:42 +0200
opsi-utils (4.2.0.198-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Tue, 28 Mar 2023 09:04:48 +0000
opsi-utils (4.2.0.197-1) stable; urgency=medium
* Improvement: Use repositoryRemoteUrl for depot connection
* Improvement: updated python-opsi to 4.2.0.320
-- uib GmbH <info@uib.de> Thu, 23 Mar 2023 19:09:52 +0100
