Updates for opsi 4.2 in testing and stable
Verfasst: 06 Feb 2023, 17:20
Dear opsi users,
with this release we have published new packages for opsi 4.2 in testing and stable.
We publish the new opsi-Configed 4.2.19.11 to stable and some things changed. The Product-Properties for choosing the Java-Runtime were removed since the opsi-package comes from now on with only one Java-Runtime. We also removed the properties `fallback_tlsv1` and `sqldata_force` since they were outdated or are not used any more. The right side in the windows of "Product configuration" and "Netboot products" has been reworked. There is now a dependency-tree that shows the dependencies of any product recursively (in both directions of the dependency). The fields of product description and product info now support Markdown. You can write Markdown texts into the according fields of the new control.toml-file and they will be shown there. Also the logging of the opsi-Configed has been reworked. It's now in line with our opsi-standards, and the default-level is now level 4 which leads to an increase of performance. In the menu point 'help' under 'validation status of opsi module' you'll find now the status of all opsi-module-licences - which also allows the modular activation of opsi-modules.
Updated packages in opsi 4.2 testing:
Server packages:
* opsi-directory-connector (48.2-1)
* opsi-linux-bootimage (20230127-1)
* opsiconfd (4.2.0.304-1)
Netboot packages:
* ubuntu (4.2.0.4-10)
* debian (4.2.0.3-11)
Localboot packages Windows:
* opsi-setup-detector (4.2.1.14-1)
Localboot packages Linux:
Localboot packages Mac:
* m-opsi-client-kiosk 4.1.1.17-5
Updated packages in opsi 4.2 stable:
Server packages:
* opsi-client-agent (4.2.0.44-1)
* opsi-configed (4.2.19.11-1)
* m-opsi-client-kiosk (4.1.1.17-5)
With kind regards
Server packages:
Netboot packages:
Server packages:
With kind regards
Changelogs:
opsi-configed (4.2.19.11) TESTING; urgency=medium
* Bugfix in clientsearch by failed installation
* Changed directory of java so that old links will work
-- n.otto <n.otto@uib.de> Tue, 20 Jan 2023 11:35:15 +0100
opsi-configed (4.2.19.10) TESTING; urgency=medium
* Another Bugfix in clientsearch
-- n.otto <n.otto@uib.de> Tue, 13 Jan 2023 11:35:15 +0100
opsi-configed (4.2.19.9) EXPERIMENTAL; urgency=medium
-- n.otto <n.otto@uib.de> Tue, 05 Jan 2023 13:14:15 +0100
opsi-configed (4.2.19.8) EXPERIMENTAL; urgency=medium
* fixed problem with starting firefox for looking on the opsiclientd-timeline
opsi-configed (4.2.19.6) EXPERIMENTAL; urgency=medium
* Small buxfixes
opsi-configed (4.2.19.4) EXPERIMENTAL; urgency=medium
* Removed java-properties in opsi-package since java is now always delivered with program
* Removed properties fallback_tlsv1 and sqldata_force
* Clients are now marked after their creation
* Faster creation of clients with CSV-Import
* new Logging (standard-loglevel is now 4, performance is now better)
* Markdown support in advice and description of products
-- n.otto <n.otto@uib.de> Tue, 18 Oct 2022 13:14:15 +0100
opsi-configed (4.2.18.1) EXPERIMENTAL; urgency=medium
* Popup in Seconds for messages sent to clients;
* CSV-Import for creating new clients
opsi-configed (4.2.17.1.1) EXPERIMENTAL; urgency=medium
* New feature dependency tree in product page
opsi-setup-detector (4.2.1.14-1) stable; urgency=low
* osdform: fix mysetup.uninstallProg $installdir$ handling:
use mysetup.uninstallProg un modified for mysetup.uninstallCommandLine (secondary section)
modify it for mysetup.uninstallCheck in order to resolve the variable (primary section)
* functions opsiquotestr, opsiquotelist from parserhelper to osdcreate
* osdcreate: add declarations.opsiinc and sections.opsiinc to list of infiles at channel custom
* osdcreate: patchscript: warning if infile could not be found
-- Detlef Oertel <d.oertel@uib.de> Tue, 24 Jan 2023 : 15:00:00 +0200
opsi-client-agent (4.2.0.45-1) stable; urgency=low
* Rework installation for newer netboot products
* Update opsiclientd to 4.2.0.134
-- Nils Doerrer <n.doerrer@uib.de> Mon, 03 Feb 2023 12:55:00 +0100
opsiconfd (4.2.0.304-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Thu, 02 Feb 2023 18:21:05 +0000
opsiconfd (4.2.0.303-1) stable; urgency=medium
* Feature: health-check --upgrade-check
* Feature: Add upgrade issues to health check
-- uib GmbH <info@uib.de> Thu, 26 Jan 2023 10:34:13 +0000
opsiconfd (4.2.0.302-1) stable; urgency=medium
* Improvement: Rework health-check data structures for opsi-cli table
-- uib GmbH <info@uib.de> Mon, 23 Jan 2023 22:00:58 +0000
opsiconfd (4.2.0.301-1) stable; urgency=medium
-- uib GmbH <info@uib.de> Mon, 23 Jan 2023 11:01:06 +0000
opsiconfd (4.2.0.300-1) stable; urgency=medium
* Bugfix: Fix backend_getInterface
-- uib GmbH <info@uib.de> Sat, 21 Jan 2023 10:10:00 +0000
opsiconfd (4.2.0.299-1) stable; urgency=medium
* Improvement: Force MySQL update on full setup
* Improvement: refactor health-check
* Improvement: overwrite backend_getInterface
-- uib GmbH <info@uib.de> Fri, 20 Jan 2023 07:30:10 +0000
opsi-directory-connector (48.2-1) stable; urgency=medium
* Fix reading of password files
-- uib GmbH <info@uib.de> Tue, 24 Jan 2023 15:27:01 +0100
m-opsi-client-kiosk (4.1.1.17-5) urgency=medium
* fix (package): files copy section in setup.opsiscript: ock_custom folder are now correctly copied
-- Jan Werner <j.werner@uib.de> Tue, 24 January 2023
opsi-client-agent (4.2.0.44-1) stable; urgency=low
* Using DosInAnIcon section for opsiclientd setup
-- Nils Doerrer <n.doerrer@uib.de> Mon, 22 Dec 2022 17:00:00 +0100
opsi-linux-bootimage (20230127-1) testing; urgency=low
* kernel 6.1.8
* updated binaries
--Mathias Radtke <m.radtke@uib.de> Fri, Jan 27 2023 11:00:00 +0100
opsi-linux-bootimage (20230116-1) testing; urgency=low
* kernel 6.1.5
* grub updated to 2.06-7
* updated binaries
-- Mathias Radtke <m.radtke@uib.de> Mon, Jan 16 2023 11:20:00 +0100
debian (4.2.0.3-11) testing; urgency=low
* fixed no_proxy handling when using wget_and_execute
-- Mathias Radtke <m.radtke@uib.de> Wed Feb 01 14:00:00 2023 +0100
debian (4.2.0.4-10) testing; urgency=low
