Updates in opsi 4.2 testing
Verfasst: 22 Feb 2022, 14:38
Dear opsi users,
we just released new packages for opsi 4.2 testing.
Up to now with opsi 4.2 zsync2 has been used for file transfer from HTTPS repositories, because the "original" zsync does not support HTTPS.
Due to some bugs and problems, especially with HTTP proxies, we now replace zsync2 with zsync-curl.
We provide zsync-curl packages for all supported distributions.
Our zsync-curl packages provide the zsync and zsyncmake binaries. Zsync-curl conflicts with zsync, which contains the same binaries.
Due to the changed dependencies, an "apt dist-upgrade" must be performed under Debian / Ubuntu.
Updated packages in testing:
opsi server:
* zsync-curl 0.6.2-1
* opsi-utils 4.2.0.156-1
* opsiconfd 4.2.0.239-1
* opsi-linux-bootimage 20220217-1
With kind regards
Changelogs:
opsi server:
With kind regards
Changelogs:
opsi-utils (4.2.0.156-1) stable; urgency=medium
* Improvement: opsi-setup: do not create default log file /tmp/opsi-setup.log
* Improvement: Update python-opsi 4.2.0.272 -> 4.2.0.273
-- uib GmbH <info@uib.de> Tue, 22 Feb 2022 07:47:14 +0100
opsi-utils (4.2.0.155-1) stable; urgency=medium
* Improvement: Upgrade python and python packages
* Improvement: Build with python 3.10
-- uib GmbH <info@uib.de> Fri, 18 Feb 2022 16:57:21 +0100
opsiconfd (4.2.0.239-1) stable; urgency=medium
* Improvement: Add config admin-interface-terminal-shell
* Improvement: Use configured user shell
-- uib GmbH <info@uib.de> Mon, 21 Feb 2022 16:25:54 +0100
opsiconfd (4.2.0.238-1) stable; urgency=medium
* Improvement: Update python-opsi (4.2.0.272 -> 4.2.0.273)
* Bugfix: Fix nagios disk usage check
-- uib GmbH <info@uib.de> Mon, 21 Feb 2022 11:44:38 +0000
opsiconfd (4.2.0.237-1) stable; urgency=medium
* Improvement: Improve terminal latency
-- uib GmbH <info@uib.de> Fri, 18 Feb 2022 15:52:01 +0000
opsi-linux-bootimage (20220217-1) testing; urgency=low
* kernel 5.16.10
-- Mathias Radtke <m.radtke@uib.de> Thu, 17 Feb 2022 08:23:00 +0200
